Guys
Ive worked with a friend to make replacement parts for the headlight leveller brackets that often break on 6N2 headlights. This is what causes the beam to point to the floor, and is responsible for a variety of MOT failures.
It can happen over time, or if the headlight experiences any kind of knock or shock, this can cause it too.
This can save a costly replacement headlight from being purchased. The new ones are made out of aluminium as pictured below and are a direct swap for the inferior plastic items used from the factory. They are easily fitted by removing the back of the headlight and unscrewing the damaged bracket, then screwing the replacement bracket in.
These are the brackets that the leveller motor ball connects into
They can be purchased from Gregg via eBay here
http://www.ebay.co.uk/itm/Audi-A3-S3-VW ... 3a97327cbc
If the aluminium ones are unavailable, another company reproduces them in a stronger plastic which wont break, plus they give a lifetime warranty
See here http://www.ebay.co.uk/itm/Audi-A3-S3-VW ... 1441932085
And also available now from here
http://www.ebay.co.uk/itm/Volkswagen-Po ... 33a8df31ee
Replacement 6N2 Headlight Leveller Brackets
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
Re: Replacement 6N2 Headlight Leveller Brackets
Alex,
Apologies for digging up an old thread but i've purchased one of these, is there a DIY on how to fit it? Slightly concerned as the plastic levelling screw seems to have been lost but at least I can adjust with the headlight out
Oh dear. Are you talking about the levelling screw in the middle or on the end?
There is no guide as such - its a case of headlights out, remove xenon bulb and levelling motor, unscrew old levelling bracket, fit new levelling bracket, screw in (only goes on one way)
slide levelling motor ball into levelling bracket - it will NOT pop in
Job done
Job done
Can these brackets still be obtained? I'd be interested in buying 4
Sorry but my two clips have broken on each side on my gti headlights and I’m going to buy the plastic levelling clips off eBay. Has anyone got any pics of where they would fit. VERY URGANT
You can see them once you remove the covers on the back of the headlights
For this to be easy you need to have the headlights off the car
Ive just had to replace one of these Auto dip adjusters, These guys have them instock... https://www.ebay.co.uk/itm/324884244920
