RLS "retrofit" continue
Its coding time...
I have a VCDS cable so i follow this procedure:
BLOCK 09.
Coding, long coding. Turn on the following bits:
Byte 6, bit 1 – rain and light sensor installed on the windshield
Byte 6, bit 3 – light switch with the Auto position set to
Byte 7, bit 0 and bit 1 – the Coming/Leaving Home function is turned on
Byte 7, bit 5 – activation of the low beam control assistant
Byte 13, bit 5 — rain sensor installed
Byte 20, bit 0 — door and interior sensors connected to the LIN3 bus
Press Exit, write the coding.
After this process, the RLS sensor appeared in the list of block 09 options. This was a good sign.
My sensor is the 5Q0 955 559B
Again, coding, lond coding
Byte 0 - nothing
Byte 1 - 33DD model: VW Polo (6C)
It was time to test the functionality and of course the installation.
I threw water on the windshield all happy, but nothing.
I try the lever for the wipers again, nothing, they work as they did before, manual style.
I check the coding, everything was fine.
I looked at my notes, the programming didn't end there.
Apart from coding, I also had to enter adaptations
Adaptations:
Turn on the ignition, enter the 9th Block in the adaptation and set:
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,
activated
after that, i did the test again.
Successfully, the windshield wipers responded to the water I threw.
Looks like everything went well.
Some more changes to the adaptations channels had to be made according to the instructions I found on the internet.
Adaptations:
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,
Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,
automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,
Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,
100
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,
72.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,
Enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,
active
IDE04926-ENG126570-Comfort illumination-lho_zeit,
10 seconds
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,
10 seconds
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,
active
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,
active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,
2000 ms
IDE08786-ENG142177-Assistance light functions-Assistance_lighting_sensitivity_adjustable,
present
DONE.
Wednesday,04,September,2024,20:00:43:16365
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY308378 License Plate:[b] RLS retrofit[/b]
Mileage: 71767km-44593mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378 Mileage: 71767km-44593miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000 CVN: DA6EEF6D
Coding: 01110012020400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 6597B189C5E238F2BC5-8030
VINID: 9E69EAAAA1A2A97A430080C720BAB66964
Readiness: 0000 0000
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08512057160424
Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
Shop #: WSC 49716 005 1048576
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 372B2BC12FCE7A62DE9-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 C HW: 6C0 820 045 C
Component: AC Manuell H03 0202
Serial number: 1605161B-0418 Dataset Number: 6C0032v____ 0012
Coding: 200000000000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1F1BE361A73E2222369-804A
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-090-V1.clb
Part No SW: 6C0 937 090 E HW: 6C0 937 090
Component: BCM PQ26 HiKR H10 0101
Serial number: 006738042497
Coding: 0000084040530A7B4F844000402707000001580053010000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCMA0 006004
ROD: EV_BCMA0_006_VW26.rod
VCID: 2A0D02B5EC7CD78A517-807E
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S5Y18M04D20H02M34S14
Coding: 0038DD
Driver door control module:
Subsystem 2 - Part No SW: 6R0 959 801 DG HW: 6R0 959 801 DG Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU012051661335260
Coding: 0000A0
Front passenger door control module:
Subsystem 3 - Part No SW: 6R0 959 802 DL HW: 6R0 959 802 DL Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU030041661212448
Coding: 1000A0
Subsystem 4 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU028041661198823
Coding: 0000A0
Subsystem 5 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU002051661233279
Coding: 1000A0
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00A 002 0380
Revision: -------- Serial number: 003TH006KLNX Dataset Number: 6C0003V____ 0581
Coding: 88C0C000000000005C000000000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2D32F51CDC670A217-806E
Subsystem 1 - Part No SW: ----------- HW: 410 820 305 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00A520BDDD2520R
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 410 821 104 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A5209A1C310AF
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1FACC94822/
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12060D61520W
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 740 C HW: 6C0 920 740 C
Component: KOMBI 201 1420
Coding: 070409002100000811082A000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 221DEA95944C0FCA197-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 090
Component: GW MQB A0 H10 0101
Revision: -------- Serial number: 006738042497
Coding: 01010008200A640071000000000000000001010000000000000000000000
Shop #: WSC 12345 123 12345
GVL: 01403C0000000000400000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2615F685F864F3EA75F-8072
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT X03 X014
Serial number: 13/11/2013 PV000031
Coding: 2C0000
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: PG5Q1139 Dataset Number: 6C0074V____ 0548
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6D87C9A91D1200B2F45-8038
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 869 F HW: 6C0 035 869 F
Component: MU-E--ER 050 7064
Serial number: 10061600012129 Dataset Number: V03935247LK 0001
Coding: 026200003C00000041110001010000001F0000940000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2E050EA5D094BBAA8DF-807A
End----------(Elapsed Time: 00:38, VBatt start/end: 12.4V/12.4V)-----------
