This is the answer that I should give you:
Hello Vinayak185
I have not had or manufacture these wiring looms for a long time, neither for BCM adaptation nor for automatic lights, I no longer have the necessary materials to make them.
So sorry.
You should have bought it earlier when this was possible.
I have for sale a wiring for automatic lights, which is for Europe 2010, 2011, 2012 models with the appropriate BCM and RLS, and therefore this sale is still open.
And this is the answer that I give you:
Take the images I need from your car to be able to make your wiring looms and post them in your personal thread.
https://www.uk-polos.net/viewtopic.php?f=56&t=70180
Then I will review the material that I have available and I will tell you in your personal thread if all this is possible.
In the event that it is possible, the conditions will be the same as for all the users who made this same wiring adaptation.
We will discuss this matter in your personal thread.
Please do not reply to this thread, it will be fully closed shortly.
Note:
This is a personal favor due to the years you have been registered in the forum.
I wouldn't if you were a new user.
☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼ ...CLOSED!
Both in this sale and in all the sales that I have had open, as in all the requests that I have received through the forums during all these years, it has been a real pleasure and a luxury for me that all of you gave me the opportunity of transforming a huge number of cars of the different models of the VW PQ25 platform all over the world.
The sole objective of these sales was to share knowledge at all levels ... it has been an experience close to the divine!
Eternally thank you!
Fernando
Fernando
December, 2024
It's been 4 years since the last time, and for reasons that would make no sense to explain I'm putting the wiring harness for automatic lights on the 6R back on sale.
At the moment I only plan to make 5 wiring harnesses and put them on sale at the beginning of December 2024.
Please, see all the information in the first post, thanks.
- Drives: Polo 6R 1.2TDI 2012
Hello Ciclo,
I would like to purchase a loom, but I cannot send you a PM.
I have a 2012 RHD Polo with BCM Max.
Rory
Rory
Hello Rory.
I'm sending you a private message with my email so you can contact me, please check your inbox in a few minutes.
I'll need you to send me an Autoscan to give you full technical support. Thanks.
Note: Forum private messaging is available after 10 posts.
- omerkartal
- Drives: SkodaRapid
Hi ciclo
I have a 2014 model Skoda rapid. I want to install an automatic headlight sensor. I want to contact you about the subject. Can you send me an e-mail at xxxx@xxxxxxxxxx.xxx.xx
Edited by ciclo: email deleted.
Reason: user protection measures.
Hi omerkartal, welcome.
I sincerely appreciate you contacting me, but these wiring are only for VW POLO 6R and maybe other VWs, they are not useful for Skoda Rapid or Skoda models.
Please, if you want, post here a recent VCDS Autoscan of your 2014 Skoka Rapid in case I can advise you what you should do.
If you cannot post the Autoscan on the forum, which is highly likely due to not having 10 posts, please upload it to a server or any place and post the link here so I can see it.
We did the automatic lights for a Skoda Fabia and Citigo here on the forum a long time ago (100% OEM, Perfect!), but we had to make several additional modifications to the original wiring. I will provide you with the links when I see your Autoscan.
Depending on the Autoscan I can advise you in the right direction to install the automatic lights on your Skoda Rapid 2014.
If you just want to know how to install the automatic headlight sensor (RLS), this is not the place to ask, please ask your questions in any section of the forum other than the sales section. Thanks.
I would like to let you know that unfortunately I no longer do diagram studies for models other than VW, I don't even know if I still have the Skoda models diagrams available.
- omerkartal
Hello Ciclociclo wrote: ↑Thu Dec 05, 2024 6:24 pm Hi omerkartal, welcome.
First of all, thank you very much for your answer.
My vehicle's Auto Scan information is available in the link. I updated the BCM unit in your previous topics. We made the headlight switch from 17 pin to 10 pin using the document you shared for the polo. But we couldn't turn on the headlights. There is no signal from BCM to the Headlight switch. I turn on the headlights manually but the headlights do not turn on. Fuse box, headlight socket, everything is as in your documentation. Could you please review the documents I shared?
https://drive.google.com/drive/folders/ ... sp=sharing
None of my installation guides (a lot) for 'VW POLO 6R' BCM Max Adaptation will be entirely useful for your Skoda Rapid.
It is highly likely that the electrical wiring installation you have done in your Skoda Rapid will not be completely correct. There are significant differences in the 6R depending on the factory equipment, and even more differences in other PQ25 VW group models that are not the 6R (SEAT, Skoda).
Without knowing the wiring installations you have done on your Skoda Rapid, and lacking to see an Autoscan with the BCM Max installed in order to code it correctly...
What would happen if you install a new 0.5mm2 wire from T17/11 or T10/1 ---> to T73b/52.
It is highly probable that this is the main problem you are having, in addition to the BCM Max coding...
Please do not reply to my sales thread again, you will force me to take moderation action regarding this.
What is happening in the world today? Does nobody respect anyone anymore?
Please open a thread in the corresponding section of the forum if you want technical support. Thanks!!!!
