So I have a 6C style carbon fibre steering wheel which is a bit cold in the cold winter. Have found one that looks the same as mine, but also has the heated function. Would this kit work with the steering wheel (but obviously wouldn't need to use the heated mat) ?:
https://www.aliexpress.com/item/1005004 ... AuNjAuMC4w
And would I be able to use a 6C style heated steering wheel button with that kit and steering wheel? :
https://www.aliexpress.com/item/1005004 ... 26447%21XZ
Has anyone fitted a heated steering wheel yet
- Drives: 2013 Polo Blue GT
Re: Has anyone fitted a heated steering wheel yet
It's a lot of DIY but sure you can make it work
So the heated steering wheel 6C style button arrived yesterday, but typically it was in a proper black colour whereas all the 6C original buttons that I have are in the off black colour, so it doesn't match!
It seems whatever button I want, comes in the colour I don't want and doesn't match the others that I have!
Does anyone know if all 6C buttons are in the off black or come in the straight black finish too?
