2010 polo SE 1.2 POWER STEERING FAIL
Have had a warning light on the dash for power steering that comes on and off intermittently alongside heavy steering that comes on and off. Have done all the relevant checks wiring etc, and everything leads to the pump failing, which I know they are common for. So I brought a second-hand pump off eBay removed the old one and fitted the new one and was told it should be plug and play but the light is still on the dash and the steering is still heavy. I was just wondering whether this needs to be re-coded through OBD or can be done another way as I have heard doing lock to lock 3-5 times should code the pump to the vehicle. Any help would be much appreciated.
Re: 2010 polo SE 1.2 POWER STEERING FAIL
Hi Alf19, welcome to the forum!
No, lock-to-lock won't code the pump, that only calibrates the G85 steering angle sensor once the pump is already working.
A second-hand pump usually needs to be coded via VCDS/OBD to match your 6R.
Here are the 3 quick things to check:
1. Coding: Second-hand pumps often come coded for older 9N/9N3 models (G250 rack sensor, e.g., 10110), triggering fault 00816.
Go into Address 44: Steering Assist (must be done with ignition ON, engine OFF) and check the coding.
For a 6R (G85 column sensor), it should be 11250 (or 11260). Clear faults afterwards.
2. Strip Fuse -since the original fault was intermittent-: Double-check the 50A metal strip fuse (SA4) on top of the battery.
They often get invisible hairline cracks that drop voltage under load. Also check SB26 (10A) in the dash fuse box.
3. Middle Plug & Fluid: Make sure the middle 3-pin port on the pump has its blanking cap fitted (6R doesn't use it) and that it's topped up.
Post a VCDS Autoscan (or the fault codes from Module 44) here if you have access to one, and we'll pinpoint it right away.
CarbonChaos
Strip fuse on the battery is my bet , mine did the same thing worked one day nothing the next .
Cheap and easy to replace
