MIH11MI6
Drives: 6J FR 2.0TFSI CDLJ AWD
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Post by MIH11MI6 »
iichel wrote: Mon May 15, 2023 2:54 pm You can set the steering feedback 'programme' via VCDS. On the fly adjustment is not as easy.
I'll just have to set it as "GTI sport", doesnt sound like the dynamic adjustment is an easy task. and I dont want to install the DCC to then put resistors in place just to get the dynamic steering adjustment, doesn't seem worth it!
Thank iichel. ECU is currently at the auto electricians getting the immo corrected, cluster has been done so ABS coding soon :)
Good job. Looking forward to your progress.
Vinayak185
Drives: 6R Polo GT 1.6 TDI
Post by Vinayak185 »
Hi iichel sir. I have installed electric seats in my polo 6R. For coding in vcds I cannot find seat memory option in vcds in can gateway installation list. Can you please tell how to solve that problem? I have BCM max installed 7H0937090D.
It's adress 36
Vinayak185
The address 36 isn't showing in can gateway installation list. How to add it?
I guess you can't then.
Vinayak185
Why is it not showing?? Anyway to make it work
Because your gateway doesn't have the right software to have address 36 in the installation list.
GW installation list. 7E0937090B
so...
Vinayak185
So ny BCM is not supporting that feature?
It seems so, you will have to install a BCM 7E0 instead of your 7H0.
If the wiring looms that I sent you are the ones currently installed, it is a direct swap, you just have to transfer the coding (GW Inst list, GW, BCM) and match the keys, and if any issue arises with the installation of another BCM, I will help you by email.
I seem to remember, but I'm not sure, that you have two MAX BCMs, 7H0 and 7E0, right?
Vinayak185
No sir. I only have 7H0 BCM. Is there any possibility of flashing software of 7E0 into 7H0?
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
Vinayak185 wrote: Tue Jan 09, 2024 4:26 pm No sir. I only have 7H0 BCM. Is there any possibility of flashing software of 7E0 into 7H0?
If you have 7H0....D with 725 software you could try the updated 726 file, I did it in the past but I do not remember what functions updated.
There is also a 7E0937090 736 file available but I do not know if this is even possible on 7H0 hardware. Even if it is possible you will lose the tpms antenna address.
If you have the right tools and you take the risk to do it let us know what happened.
Vinayak185
Unfortunately I don't have tools and no experience in flashing BCM software. I will need help and information about it. Please help
