Locked
Andrea 6r
Drives: 6r
Post by Andrea 6r »
Hi ciclo
This terminal toolImage It can be right? especially for the port connection
Inviato dal mio iPad utilizzando Tapatalk
grem
Post by grem »
Ah I can see the difference much clearer there!
thanks ciclo
Andrea 6r wrote:Hi ciclo
This terminal tool http://pages.ebay.com/link/?nav=item.vi ... 1171376685 It can be right? especially for the port connection
Hi Andrea, yes, it is a good tool for removing terminals. I have two, one of which I've modified for smaller terminals (micro timer) this way: https://www.youtube.com/watch?v=bbW9Yc36RPE
micro timer:
http://www.a4-freunde.com/attachment.ph ... 1416145360
http://www.a4-freunde.com/attachment.ph ... 1415040345
http://www.a4-freunde.com/showwiki.php? ... zu+gehoert
grem wrote:Ah I can see the difference much clearer there!
thanks ciclo
:wink:
Andrea 6r
Drives: 6r
Post by Andrea 6r »
Ok thanks ciclo ;)
Bachecco
Drives: Polo 1.2
Post by Bachecco »
ciclo wrote:Hi grem, in the next picture I think the trims does not have the same shape in the area of buttons.
So it will not be a straight swap.
hi ciclo, if I buy also the knobs of the polo 6c then I can install it in my polo or the connector doesn't fit?
I don't know. :roll:
grem
Post by grem »
I was also thinking the same but was unsure if it would be plug and play or not.
If you do go for it please post pics or update as I think It would be a great little mod
Andrea 6r
Drives: 6r
Post by Andrea 6r »
Hi ciclo,
The terminal tool it's arrived..Image
I test and it is perfect...
I bought your own (old) control to the mirror along with the relay. When I come around I'll ask you more information about mounting
as promised i would let you know:
the RHD central locking switch face plate will fit on a LHD mechanism :) easy swap, full function.
(first mod on the BlueGT)
Andrea 6r wrote: I bought your own (old) control to the mirror along with the relay. When I come around I'll ask you more information about mounting
At your disposal. :wink:
iichel wrote:as promised i would let you know:
8) Thank you for reporting iichel.
CNK
Drives: 6R
Post by CNK »
I tried remove luggage compartment cover side, but..
Do I have to remove the backseat?
no that will not be necessary :)
CNK
Drives: 6R
Post by CNK »
So how can I remove material from luggage cover side near the seat? It is under fastening seat.
You only have to unlock the outside ring of the back rest very shortly in order to remove the side cover.
And the seat part, you can simply lift that up and tilt forward
CNK, look at all pictures of this link, perhaps this will help. :wink:
Locked
