StewyL's 6n2 GTI Now With Air
slarner
StewyL's 6n2 GTI
Post by slarner »
Gave the old girl a quick clean today!!
I've also got on the band wagon and ordered a 99. Relay for wipers!!
Joycey
Re: StewyL's 6n2 GTI
Post by Joycey »
looking good buddy, someones gotta get on this 1.8t conversion lark :)
slarner
StewyL's 6n2 GTI
Post by slarner »
Well not much has changed as its winter now!!
I've brought a few goodies one being a typhoon air filter. But I don't think it's a good idea putting it on in this weather might act like a dyson!! Lol
Also this
I've wanted one for so long! Someone on club lupo was selling it so I snapped it up. They have Bodged the wiring a bit though!! Pics to follow once I've installed it!
Aquavalver
Drives: 2013 Polo Blue GT
Post by Aquavalver »
slarner wrote:Well not much has changed as its winter now!!
Also this
Nice! Looks like someone's been spending their pennies! :D
slarner
StewyL's 6n2 GTI
Post by slarner »
Also this
It was £280 that's cheap!! And it's sort of already modified!! They are like 600 brand new
kimbo
Post by kimbo »
What type of wheel is that? Will it bolt straight on?
slarner
Post by slarner »
kimbo wrote:What type of wheel is that? Will it bolt straight on?
its a scirocco steering wheel. The actual wheel bolts straight on. But the slip ring for the horn and airbag is not the same.
You have to drill 3 holes in the new wheel and mount the old slipring from the original steering wheel on. And then connect the wires up. Quite easy really. And i can also confim the airbag in the new wheel is single ignite so it should work.
Im yet to fit it i will let everyone know how i get on!
slarner
Post by slarner »
Well here is some winter updates.
I have finally got round to fitting my K&N Typhoon air filter. It sounds awesome and seams to have made the car a bit more torquey. It was not to bad to fit just the bottom clamp which is where the horn goes was a bit of a pain.
Here is the pic of it fitted :
At 4,000 RPM and over it just sounds brilliant!
Then up next was my mate works at a scrap yard. and was breaking this.
So i went down and had a look at it there was nothing wrong with it at all had 125,000Miles on it! Was only taken off the road because of being caught without insurance!
I have been looking out for some BBS RXII's and this so happened to have some on it. So i snapped them up. £100 for the set and got rid of the shagged out RA's
They do need a refurb but thats not an issue for me. Here they are.
And fitted sorry about the state of the car. I havent had chance to clean it!
Then next up was the steering wheel.
I brought a scirocco wheel a little while ago. So i went ahead and fitted it.
I couldn't believe how much of an arse the original steering wheel was to get off mostly the Airbag!
Anyway after a few hours of pissing about i got it fitted here is the results.
I have got a problem with the slip ring i think as the airbag light is on and the fault is Airbag Resistance To High.
Thats all for now!
Piers0930
Post by Piers0930 »
Nice GTI Mate, was the steering wheel a straight swap? take some more pics? cheers
slarner
StewyL's 6n2 GTI
Post by slarner »
Piers0930 wrote:Nice GTI Mate, was the steering wheel a straight swap? take some more pics? cheers
The actual steering wheel yes. The splines are the same it bolts straight on.
The slipring for the horn and airbag no. I having issues with that already!
Aquavalver
Looks great! Hope you get the probs sorted soon!
I need some inside door tweeter speaker covers/inside wing mirror covers (as want to spray some dark grey, but still have ones in the original colour as spare or if ever decide to go back to standard) and engine cover in good knick if they are still on that on that is being broken?
slarner
Post by slarner »
Aquavalver wrote:Looks great! Hope you get the probs sorted soon!
I need some inside door tweeter speaker covers/inside wing mirror covers (as want to spray some dark grey, but still have ones in the original colour as spare or if ever decide to go back to standard) and engine cover in good knick if they are still on that on that is being broken!
I got the engine cover off that one being broken and also he is gunna see what state the engine tray is in. As i put a hole through mine!!
Endi_GTI
Post by Endi_GTI »
Looks good man 8)
Aquavalver
slarner wrote:Well here is some winter updates.
Are there fixing points along the route of the ducting? Looks like there is one at the bottom right where it goes down in front of the grill?
Piers0930
Post by Piers0930 »
it would be sick if you could get the steering wheel buttons work!
did you buy it new?
horny should be easy?
air bag, but a resistor across it to take out light?
