UK-POLOS.NET - THE VW Polo Forum • ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝 - Page 8
Page 8 of 333
Posted: Sun Nov 10, 2013 5:42 pm
by greypolo9n3
Thanks you are goood guy!
i like the price of the RVC..i may be able to install it myself using the guide you posted on this forum. it doesnt look very hard at all.
Do i need to change BCM for DIS? also for cruise? im not sure
Posted: Sun Nov 10, 2013 6:14 pm
by ciclo
For the onboard computer does not need to change the BCM.
For cruise control, tell me the reference number of your BCM and we will see if you need to change or not.
6R0 937 084Basis
6R0 937 085Low / medium
6R0 937 086Medium
6R0 937 087High
6R0 937 088High with start / stop operation
7H0 937 089High daytime running light, driving light assistant and Coming Home Function
7H0 937 090Max
Translated from German:
base
terminal control
load management
Control brake light, parking and parking lights and interior light
Control indicators and hazard warning lights
Wiper control, front and rear
Control horn
Control defogger rear
Control door control devices
tailgate release
Diagnosis interface for data bus
CAN drive and diagnostics
medium
Central locking (control locks, doors and flaps)
Released Seat heating and Schiebeausstelldach
Driving wheel cleaning system
Control windscreen heater
Control LIN data bus door
Control LIN data bus roof (rain sensor, interior surveillance, inclination sensor, panoramic sunroof)
Heated door mirrors
CAN comfort
medium
Wireless remote (integrated in the control unit antenna)
High
Shift lock, starter interlock
Cruise control
Control LIN data theft alarm system
Drive reverse light, static cornering lights, fog lights
BCM
Plug Pin Cross-section Cable color Terminal
A 1 - - High beam relay output (Kl.56b) (When retrofitting high beam assist system)
A 2 2.5 ge / sw Left low beam output (Kl.56bL) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
A 3 - - Battery cut-off relay output
A 4 0.35 br / sw Output signal Interior light, door contact switch
A 5 0.5 gr Lamp for LED daytime running light right
A 5 1.0 ge / br Lamp daytime running light right
A 6 1.0 gr / ws Output rear fog lamp (only for vehicles with automatic stop-start system or retrofit headlights)
A 7 1.5 wh / ye / ye Input signal switch for fog lights
A 8 - - Output isolation relays for CAN-bus drive
A 9 - - -
A 10 0.5 gray / red Output motor for tailgate
A 11 1.5 vi / ws Output motor for central locking "lock" for all doors
A 12 1.0 vi / gr Output motor for central locking, driver's door
A 13 1.5 br / rt Output motor for central locking "safe" for all doors
A 14 2.5 br Input signal mass (31), Central
A 15 1.0 vi / ye Output motor for central locking, passenger door and rear doors
A 16 2.5 rt Input supply (30), Central
A 17 0.5 gn / rd Input unit for central locking, rear left door
A 18 0.5 gn / gr Input unit for central locking, rear right door
A 19 0.35 br / ye Input signal drivers side door switch
A 20 0.35 br / rt Door switch input signal, passenger side
A 21 0.5 green / yellow Input unit for central locking, passenger door
A 22 0.5 gn / bl Input unit for central locking, driver's door
A 23 0.5 vi / ws Input signal button for unlocking in the tailgate handle
A 24 0.5 green / yellow Central input signal, the driver's door
A 25 0.35 br / gn Input signal Interior Locking Button
A 26 0.5 br / ws Door switch input signal, rear right door
A 27 0.5 sw / gn Input signal bonnet contact switch
A 28 0.5 bl / ye Input signal hazard light button
A 29 0.35 br / sw Input signal horn activation
A 30 0.5 gn / bl Input signal tailgate lock, position 2
A 31 0.5 bl / rd Input tailgate lock, position 1
A 32 0.35 sw / gn Input signal indicator switch right
A 33 0.35 black / white Input signal indicator switch left
A 34 0.35 br / gr Door switch input signal, rear left door
A 35 - - Output control unit for sliding roof
A 36 0.5 rd / ye Signal off seat heating
A 37 - - Input signal switch for automatic light control (Kl.AFL)
A 38 1.0 bl / bl Output heated exterior mirrors
A 39 - - Input signal ground (terminal 31)
A 40 0.5 gray / red Output signal lamps for parking light right (Kl.58R)
A 41 0.5 gr / sw Output signal lamps for parking light left (Kl.58L)
A 42 0.5 bl / br Input supply (Kl.86s) for Ignition
A 43 0.35 black / red Input signal brake pedal position sensor
A 44 0.5 bl / bl / black / yellow Input, plus compound 2 (Kl.15a) in interior wiring harness
A 45 0.5 gr / ye Input signal for parking light, light switch position "parking light" and "headlight" / (Kl.58_in)
A 46 - - -
A 47 - - -
A 48 - - Output control unit for sliding roof
A 49 0.5 vi Output relay for headlight washer system
A 50 - - -
A 51 - - Output relay for entry-level and footwell lights
A 52 0.5 bl / ye Output relay for fuel supply
A 53 - - -
A 54 0.5 black / red Input supply (75a) for Zündanlassschalter1)
A 55 0.5 vi / gr Output relay for starter interlock (only vehicles with automatic transmission)
A 56 0.35 gr / bl Output signal indicator for warning lights
A 57 0.35 bl / gn Output indicator light for indoor surveillance shutdown
A 58 0.35 red / black Output indicator light for SAFE operation of the Central
A 59 0.35 br / gr Output indicator light for interior locking
A 60 0.35 wh / ye Output indicator light for heated rear window
A 61 - - -
A 62 0.5 wh / gn Output high beam (+ Kl.56aL Kl56aR) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
A 63 2.5 - Input supply (30), left headlight (only for vehicles with stop-start system)
A 64 1.0 black / red Input supply (30), heated outside mirrors
A 65 1.0 red / black Output power (30G), interior light and trunk light
A 66 1.0 rt / vi Input supply (30), Indoor Lighting
A 67 - - -
A 68 2.5 rd / ye Input supply (30), windshield (only for vehicles with stop-start system)
A 69 2.5 ws / sw Output wipers, position 1
A 70 2.5 br Input signal for wiper mass
A 71 2.5 green / yellow Output wipers, 2 position
A 72 1.5 black / yellow Output signal horn
A 73 2.5 rd / ye Input supply (30), horn
B 1 1.0 gray / red Input control for switch and instrument lighting (58)
B 2 2.5 gr / vi Right low beam output (Kl.56bR) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
B 3 0.5 gr / ye Lamp LED daytime running lights left (Kl.TFL)
B 3 1.0 ge / br Lamp daytime running light left (Kl.TFL)
B 4 - - -
B 5 0.5 gn Parking light, front left (Kl.58l)
B 6 0.5 gn / ws Auxiliary light right (Kl.58r)
B 7 1.0 gr / bl Plus connection (58) panel wiring, parking and driving light position light switch T17/16 (only with stop-start system)
B 8 - - -
B 9 1.5 wh / ye Output signal lamp for fog lamp left
B 9 1.0 wh / ye Output signal lamp for cornering left for vehicles with gas discharge headlights, Kl.ABL_L
B 10 1.5 wh / ye Output signal lamp for fog lamp right
B 10 1.0 vi Output signal lamp for cornering right for vehicles with gas discharge headlights, Kl.ABL_R
B 11 1.0 sw / gn Input supply (30), fog lamps for
B 12 0.35 bl / bl Output signal reversing lights (cars with automatic or automatic light retrofit)
B 13 1.5 rd / ye Input supply (30), flashing light and brake light
B 14 1.5 black / white Output signal flashing left (class L)
B 15 1.5 sw / gn Output signal flashing light right (Kl.R)
B 16 1.0 ws Output signal brake lights
B 17 0.35 vi / ws LIN bus, door control unit in the steering wheel and shift lever
B 18 0.35 or / br CAN low drive
B 19 0.35 or / sw CAN high, drive
B 20 0.35 or / gn CAN high, comfort
B 21 0.35 or / br CAN low, comfort
B 22 0.35 or / br CAN low diagnostic
B 23 0.35 or / sw CAN high, diagnosis
B 24 0.35 vi / ws LIN bus control unit for sliding adjustment, rain and light sensor for detection, sensor for indoor surveillance
B 25 - - Input contact closed door left
B 26 - - Input contact closed sliding door right
B 27 0.5 wh / gn Wiper input signal, position 1
B 28 0.5 bl / ye Central input signal, passenger door
B 29 0.5 gr / vi Input, "0" position light switch
B 30 0.35 vi Input signal switch for deactivation of the interior monitoring
B 31 0.35 wh / rd Input signal switch for heated rear window
B 32 0.5 gn / bk Limit switch input signal for windshield wipers
B 33 - - -
B 34 0.5 gr / bl Output signal lighting - Switches and instruments (58d)
B 35 - - -
B 36 0.5 vi / ws LIN bus, alarm horn
B 37 0.5 gr / ws Signal (K) Diagnosis
B 38 1.5 br Input to ground (31), for electronic
B 39 0.5 red / white Input signal supply (30) for electronic
B 40 - - -
B 41 - - -
B 42 0.35 sw / gn Brake contact switch input signal
B 43 0.35 gr / sw Input signal switch for rear fog light (Kl.NSL)
B 44 0.35 bl / ye Input Signal "set" speed control system
B 45 0.35 ws Input signal "on / off" cruise control
B 46 0.5 bl / vi Input signal "reset" cruise control
B 47 0.35 bl / wh Input Signal "Cancel" cruise control
B 48 0.5 bl / bl Input signal switch for reversing light
B 49 0.5 bl (L) signal generator
B 50 0.5 red / black Input signal Starterrelais1)
B 51 0.5 black / red Input supply (75a) for Ignition
B 52 0.5 ws Input signal power washer pump / switch for driving lights (Kl.FL)
B 53 0.5 green / yellow Wiper input signal, position 2
B 54 - - -
B 55 0.5 vi / sw Starter interlock signal (only for vehicles with automatic transmission and without start-stop system)
B 56 - - Input clamping unit for tailgate
B 57 - - -
B 58 0.35 sw / gn Input signal switch heated mirrors
B 59 0.5 rd / ye Input signal for the reference voltage (30)
B 60 0.5 br Input signal for mass - reference voltage (31)
B 61 0.5 gn / rd Output motor for washer pump and motor for rear window wiper
B 62 0.35 br / gn Input signal intermittent wiper circuit
B 63 2.5 ws Output heated rear window
B 64 - - -
B 65 - - -
B 66 - - -
B 67 2.5 rd / ye Input supply (30), heated rear window
B 68 1.5 red / white Input supply (30), headlight right1)
B 69 - - -
B 70 - - -
B 71 - - -
B 72 - - -
B 73 - - -
Posted: Tue Nov 12, 2013 4:46 pm
by ciclo
New mod VCDS
Add data MFD. Refuel.
This indicates the amount of fuel needed to be filled.
Put just 25 liters of petrol, please. :)
Posted: Tue Nov 12, 2013 4:47 pm
by alexperkins
I wish i had a full MFD cluster :cry:
Posted: Tue Nov 12, 2013 6:10 pm
by greypolo9n3
omg :O how do i get this? lol
Posted: Tue Nov 12, 2013 6:51 pm
by ciclo
alexperkins wrote:I wish i had a full MFD cluster :cry:
Without tax: For petrol, same as bluegt. (€)
I searched a lot to find alternatives but found nothing.
Posted: Wed Nov 13, 2013 11:05 am
by jobbercete
Great great car Clico, you give the Polo another status....but you already know that, I told you before :lol:
We need to talk, but unfortunately I can't send PM's :(.
by the way, your work on the Polo is amazing, really appreciate all the stuff you share here and we are very fortunate people having you round here :D
Posted: Wed Nov 13, 2013 6:11 pm
by Mart!n-GTI-DK
The Amarok TDI have got a speedo with full MFD... It's the same shape and size as the Polo Speedo.
Posted: Thu Nov 14, 2013 5:56 am
by ciclo
Excellent information, thank you very much Mart!n-GTI-DK.
You know the exact number reference of the speedometer?.
images:
Posted: Thu Nov 14, 2013 6:09 am
by Mart!n-GTI-DK
Sorry. Can't help with a partnumber. But my friend Watcher who just posted a thread on here about his Polo project will test it on his TDI in the near future.
It's not that easy to get hold if just yet.
Posted: Thu Nov 14, 2013 6:15 am
by ciclo
Mart!n-GTI-DK wrote:Sorry. Can't help with a partnumber. But my friend Watcher who just posted a thread on here about his Polo project will test it on his TDI in the near future.
Ok ... is very recent. :wink:
Awesome Whatcher's Polo. I like.
Posted: Thu Nov 14, 2013 8:29 am
by Watcher
2H0 920 871 X this is for the amarok tdi with full mfa, i just want to confirm it can work before i buy it, so im waiting for my friend to get his amarok so we can try and swap in my car
Sent from my Aiiiiiiightphone
Posted: Thu Nov 14, 2013 12:56 pm
by ciclo
VCDS Autoscan
Posted: Sun Dec 01, 2013 11:34 am
by ciclo
To change the duration time coming/leaving home with vcds 11.11.3 and 12.12.0
Tested and successfully changed values​​.
Posted: Sun Dec 01, 2013 4:02 pm
by Mart!n-GTI-DK
Gotta have Watcher to look at that on mine... The time they are on is just a bit too short.
