Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
iichel wrote:1)
2) the AFS system contains the level sensor on the rear axle, the AFS module and the AFS motors. The motors are integrated in the headlight. You'll also need the wiring.
3) you'll need to fit the entire AFS system.
4) AFS will work with any bcm since it's a separate system. It's operated by the powertrain CAN. But for the LED headlights of the Polo 6C, you need a different bcm. It is the 7E0 937 090 Z4Y. I have the same BCM and it works well.
I am going for led headlamps which are coming with vento in India
Bcm of vento with led headlamps is 7E0 937 089A
It has just auto level function
What other components are required I have listed few of them tell me if I am missing something here
1) Afs module it's sensor and wire ( where I will get the whole kit )
2) connector converter 10 pin to 14 pin
3) The above BCM or BCM max
4) Do I need to change light switch or indicator stalk ?
5) And is it require to connect cornering lamp connection to headlamp?
6) Suppose I don't install afs will it work on the manual button beside light switch or is there any solution without upgrading to bcm and Afs ?
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
4) no that is not necessary
5) no the LED headlights don't have a cornering light
6) no and no. Please install the correct BCM and AFS, for your own safety and convenience and that of the other road users. I will only support LED headlight retrofits when AFS is done. A badly aimed LED headlight is very annoying.
smg_shardul
Drives: Polo 6R
iichel wrote:4) no that is not necessary
1)What about parts list ?
2) will this bcm support led lights 7E0937090 as this is available?
smg_shardul
Drives: Polo 6R
Thanks a lot...[emoji4]
sanders
Drives: 6r bluemotion tdi 1.2
Post by sanders »
Retrofitted the AFS, but seem to have a problem.
Got fault code 01771, double checked the wiring to the AFS module and found ok.
Did anyone encounter the same problem after the retrofit?
Full autoscan please
sanders
Post by sanders »
Will post the scan after the weekend left the laptop with the logs at work.
sanders
Post by sanders »
here is the autoscan.
[VCDS
Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: Release 17.8.0 Data version: 20170721 DS276.2
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,14,August,2017,18:55:57:62108
VIN: WVWZZZ6RZCY License Plate:
Mileage: 231300km-143723mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 55 56 61 77
VIN: WVWZZZ6RZCY215108 Mileage: 231300km-143723miles
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H07 9979
Revision: 12005001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 49533 001 1048576
ASAM Dataset: EV_ECM12TDI03103P906021B 001042
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 275678585E1F887EEB-8072
Readiness: 0 0 0 0 1
VCDS
Self-Diagnosis Log
Monday,14,August,2017,18:56:04:62108
Page 2
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3416E00B7842624E282D900521300
Shop #: WSC 00788 648 00255
VCID: 000403C497F19F468A-8054
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3874AB248BA1178672-806C
VCDS
Self-Diagnosis Log
Page 3
VIN: WVWZZZ6RZCYLicense Plate:
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 026120185
Coding: 3AB02BBF08F32400B3380F916CAB8ED95A80672F7E0D34C1200000000000
VCID: 4182C6C0D87B564EC5-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 270812 05 54 0403
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010557
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016679
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0007366
Coding: 830000
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU006021200013428
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU003021200013238
Coding: 58BC32
VCDS
Self-Diagnosis Log
Page 4
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX013PB9F
Coding: 003232
Shop #: WSC 01383 785 00200
VCID: 4A90E1ECED4D951614-801E
Serial number: 3575HRB405515IRQ4PI+
Serial number: 3585HRB405115IRQ6G4H
Serial number: 3515RRB404R12QE4FGAU
Serial number: 3525RRB405N12QE41941
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H03 0505
Coding: 140801
Shop #: WSC 50709 124 43266
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
VCID: 336E9C089AC7F4DE47-8066
VCDS
Self-Diagnosis Log
Page 5
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0035
Revision: H38 Serial number: 010212F1002792
Coding: 2500C2
VCID: 346C9F1497C9F3E65E-8060
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Time Indication: 0
Date: 2017.08.14
Time: 00:08:15
Component: IMMO H03 0505
Shop #: WSC 00000 000 00000
VCID: 6AD0416C8D8D751634-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661806871
Coding: 020000
VCID: 29527E60400BBE0EFD-807C
VCDS
Self-Diagnosis Log
Page 6
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H09 5274
Revision: AB001001 Serial number: VWZ6Z7N7036070
Coding: 00000400000000812001
Shop #: WSC 00066 123 12345
VCID: 3B7EB428BA973C9E9F-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11220
Shop #: WSC 00788
VCID: 2F669078EAEFD03E23-807A
VCDS
Self-Diagnosis Log
Page 7
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77F66818CE3FD8FEBB-8022
4 Faults Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:15
13705472 - Databus
U1121 00 [137] - Missing Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:14
13705474 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:14
13705480 - Databus
VCDS
Self-Diagnosis Log
Page 8
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:14
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0035
Coding: 030B1A59
VCID: 74EC5F14D749B3E69E-8020
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970893992
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 F HW: 5K0 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661870876
Coding: 0800000000000210
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 28547B6453018706E2-807C
End-------------------------(Elapsed Time: 03:37)--------------------------]
sanders
Post by sanders »
measuring block 126 gives status 0 for the powertrain communication.
i connected the can wiring on the wiring from the instrument panel.
think the module is faulty.
Coding: 2500C2
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Time Indication: 0
Date: 2017.08.14
Time: 00:08:15
so here it's saying, there is no contact to the module
buuuuuuut
here it says, the module is present but with errors:
VCDS
Self-Diagnosis Log
Page 7
4 Faults Found:
5275220 - Headlight
Fault Priority: 1
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:15
13705472 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:14
13705474 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:14
13705480 - Databus
VCDS
Self-Diagnosis Log
Page 8
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231305 km
Date: 2017.08.14
Time: 00:06:14
so that doesn't make sense to me. or your autoscan is a copy paste of many single scans.
so it's good to know what's going on there.
apart from that, the module is missing a basic setting. that's done by basic settings in vcds. try to do this, report back then.
iichel wrote: Mon Aug 14, 2017 7:55 pm .... that's done by basic settings in vcds. try to do this, report back then.
+1
sanders
Post by sanders »
Tuesday,15,August,2017,18:57:15:62108
VCDS Version: 17.8.0.1
www.Ross-Tech.com
VIN: WVWZZZ6RZCY License Plate: SAM 15-08-2017
VIN: WVWZZZ6RZC Mileage: 231300km-143723miles
Revision: --------
Revision: V0000000
Coding: 0714DD
Coding: 0200A3
Coding: 1000AB
Coding: 830000
Coding: 58BC32
Coding: 58BC32
Coding: 003232
Coding: 140801
Coding: 2500C2
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 231307 km
Time Indication: 0
Date: 2017.08.15
Time: 18:50:19
Coding: 020000
Coding: 11220
Shop #: WSC 00788
Coding: 0192000001000000
3 Faults Found:
13705472 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231307 km
Date: 2017.08.15
Time: 18:51:01
13705474 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231307 km
Date: 2017.08.15
Time: 18:51:01
13705480 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 231307 km
Date: 2017.08.15
Time: 18:51:01
Coding: 030B1A59
ROD: UHVNA.rod
sanders
Post by sanders »
made some progress,
basic setting performed
when you enter module 55 and clear the faults than you here movement from the headlights
still fault in gateway and in range the databus faults
Adam87
Drives: T5.2
Post by Adam87 »
I did a caddy AFS module that wouldn't code, I had to reflash with VCP
