☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼ ...CLOSED!
- Drives: polo 1.4 85KM CGGB/GOLF 7.5
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Hello
wants to buy the cabling "B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH"
My polo 6R 2009 1.4 85km
VIN WVWZZZ6RZAY02XXXX
BCM 7E0937090
BCM 7E0937090
Hello Fernando!
My mate has problem with posting with images (all the time has error: "Forbidden. Data submitted too often. Please wait a few minutes. Contains contacts." and he can't edit previous post, probably because his account is new, so here are photos from dcgumis's Polo:
Fusebox:
Light switch:
Relays:
Scans:
Hello Fernando!
Fusebox:
Light switch:
Relays:
Scans:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 37 44 56
VIN: WVWZZZ6RZAY02xxx Mileage: 166510km-103464miles
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BH HW: 03C 906 024 BH
Component: CGGB MM4HV G 9971
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 53413 001 1048576
VCID: 65C629BBAF726116CE-5072
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AC HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200228E3016F00B2042C14E280D800000200
Shop #: WSC 02069 000 00000
VCID: 7F0A9BD3EAEEDBC624-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 A HW: 6R0 820 045 A
Component: Climatic 23 0500
Revision: 00 09 23
VCID: 2C509C9F4F18905ED1-8078
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 2234 km
Time Indication: 0
Date: 2010.01.08
Time: 17:45:52
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H08 0025
Revision: BF008001 Serial number: 9955A155091657
Coding: 3DB02BB828F32400923800003D2B1CD000C0410F608000002000
Shop #: WSC 124697 483 00190
VCID: 3C70ACDFBF7800DE41-8068
Subsystem 1 - Part No SW: 6R0 959 801 H HW: 6R0 959 801 H Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 0803
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 K HW: 6R0 959 802 K Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 0803
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Coding: 08BC32
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag005 H09 0018
Revision: -------- Serial number: 003DW003YHK-
Coding: 003035
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 428CD227D59C762E0B-8016
Crash sensor for side airbag; driver side:
Serial number: 3572SRB40000911C8A98
Crash sensor for side airbag; front passenger side:
Serial number: 3582SRB4000091185980
Crash sensor for side airbag; rear; driver side:
Serial number: 3516GRB401V9F7IH9SA3
Crash sensor for side airbag; rear; passenger side:
Serial number: 3526GRB40219F7IH1K1-
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 B HW: 6R0 920 860 B
Component: KOMBI H23 0110
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 336287E39A26CFA690-8066
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0025
Coding: 002200
VCID: 70E848EFA3B0B4BEAD-8024
Address 25: Immobilizer Labels: None
Serial number: 5110
ASAM Dataset: Unknown
ROD: N/A
VCID: 55A6197B3412F1965E-8000
No ASAM data for: "" (VW25)
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H24 6276
Revision: AB001001 Serial number: VWZ6Z7S0418589
Coding: 00010000010000A00000
Shop #: WSC 01357 011 00200
VCID: 3D76A1DBA46209D676-8068
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V15 8522
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00000
VCID: 2E549697ED04E24EFF-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
End-------------------------(Elapsed Time: 02:43)--------------------------
Hello dcgumis.
Ok, I have already collected the information posted by Szymon.
During this week I will manufacture your wiring looms 'B'.
I will contact you by private message when I have them ready to send them to you, I will provide you with my email so you can contact me and thus provide detailed information on the payment and shipping processes.
Best regards.
Thanks Szymon.CNK wrote: ↑Tue Dec 03, 2019 11:08 am
Hello Fernando!
Do not worry, only one post/reply has been posted. However, in case they are posted I always delete personal information/contacts in case it appears publicly in any reply/post.
Are you going to help dcgumis with this installation?
What equipment will be installed apart from the BCM Max and automatic lights?
Cheers.
According to factory settings, your 6R has H4 headlights installed.
What are your future plans in this regard?
H7, Bixenon, LED Headlights?
What taillights model do you currently have installed?
6R or 6C?
Please, if you plan to install any new part during/at the same time/together with the installation of the 'B' wiring looms, this is the time to tell me what your plans are for me to crimp the correct contact terminals. It will facilitate the installation of your wiring looms.
Thank you.
^ I think he will install Full LED headlights, and now he has 6C taillights (via adapters like you).
dcgumis has also factory DRL by headlights, because this 6R is from 2009 (it seems to me that DRL works like 10-20% of normal lights power).
current plans: front + rear PDC, Full LED headlights, heated seats, headlight washers.
This is what I know, but let's wait for his answer
Edit: and dcgumis's red 6R has H7 headlights, no H4 because it's very early model from August 2009.
Hello Ciclo
Hi, I have H7 headlight, not H4. The car is from August 2009. I plan to mount headlights washers FULL LED Polo 6C headlight AFS , parking sensors. I have 6C taillights (via adapters like you).
Ok, thank you very much CNK and dcgumis.CNK wrote: ↑Thu Dec 05, 2019 6:39 am ^ I think he will install Full LED headlights, and now he has 6C taillights (via adapters like you).
Yes, you two are right, they are H7 headlights from the factory, the wire in position 7 of lights switch connector indicates this. Sorry for my confusion. The 6R with H4 do not have this wire in position 7, with H4 the activation of relay J331 is by the stalk instead of the light switch.
No problem, the J331 relay will be eliminated anyway.
It is a 6R 2009 manufactured BEFORE November 2009, the wire in position 14 indicates this. (erWin)
Your wiring looms are already manufactured, all perfect!
Some brief explanations:
In the part dedicated to the fuse box I have provided you with three additional wires/contact terminals with +30 signal. One is for fuse SB57 to power the BCM for static cornering lights (in front foglights under BCM control in case of LED headlights) and two more for your other retrofits (RLS, etc).
I mention it because these three additional wires are VERY important part of the electrical installation. You must be very precise when you are doing the wires installation. We are going to move the original SB20 fuse wire to the SB17 position to have full power from the inner bar with signal 30 for the three additional wires.
You will see how to connect them in the installation guide. (easy)
In the black wire that goes to the reversing light I have added a blue Butt terminal to connect here the reverse signal needed by the auto dimming mirror. Remember it is the reverse signal, not the power of the mirror (the power must be +15, you have three fuse slots available with +15 between fuses SB9 and SB16, which are 13, 15, 16).
This reverse light black wire has the contact terminal to be inserted into the 6C taillights adapter. I recommend that you install an LED lamp in the reverse light, WHITE LED !, if you do not have it installed yet.
Now I am doing the installation guide, everything will be perfectly explained in the guide.
Tonight or tomorrow I'll post the installation guide (link) here so you can download and view/study it. Then I will contact you by private message so that we are in contact by email.
Best regards
Hi Ciclo
I am interested in a A-type wiring looms.
Can you contact me via pm.
Thanx
Thanx
Hello Kuba591, welcome!
Of course, no problem, I will contact you by private message, but for your A-type wiring there is a prerequisite that is very easy to meet before we get in touch by private message and email (for payment and shipping processes).
- Please post here a VCDS Autoscan of your 6R GTI, as recent as possible. Thanks!
In this way I will be able to manufacture your HQ wiring that will be perfect for your 6R GTI and as soon as possible, that is, at lightning speed.
Hi
Sorry for a delay.
Sorry for a delay.
37-Navigation -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 73430 031 73430
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71E963C5A0A91DCCE7-8024
Readiness: 0000 0000
Part No SW: 0AM 300 050 K HW: 0AM 927 769 D
Component: GSG DSG AG7 411 9058
Revision: 00041014 Serial number: TFK01103240843
Coding: 0000020
Shop #: WSC 37806 001 1048576
VCID: 3169A3C5AB295DCCA7-513C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210248E3416D02B5842E12E682D940411700
Shop #: WSC 00788 648 00255
VCID: 071D2D1DB22D337C59-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326BACC96D2F66D4DE-8066
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 D HW: 7H0 937 089
Component: BCM T5GP Li4 H47 0230
Revision: BS047001 Serial number: 0398 097110111
Coding: 3CB029BF48A1000001280EB17E2B0FD00AC067FF60051041200000000000
Shop #: WSC 85046 004 02308
VCID: 377D9DDD864D83FCE9-8062
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130411 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1621
Serial number: KU0KU005041100013713
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1621
Serial number: KU0KU031031100012484
Coding: 08BC30
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Serial number: 0032483
Coding: 830000
11 Faults Found:
03428 - Activation of Left Adaptive Light
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 77
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:51:28
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Reset counter: 49
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:31:40
03429 - Activation of Right Adaptive Light
Fault Priority: 3
Reset counter: 77
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:51:28
011 - Open Circuit
Fault Priority: 3
Reset counter: 49
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:31:41
03432 - Activation of Right Parking Light
Fault Priority: 2
Reset counter: 76
Mileage: 147954 km
Time Indication: 0
Date: 2014.03.08
Time: 18:22:57
011 - Open Circuit
Fault Priority: 2
Reset counter: 49
Time Indication: 0
03591 - Control Circuit for Horn
012 - Electrical Fault in Circuit
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 150354 km
Time Indication: 0
Date: 2014.04.26
Time: 20:15:16
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Reset counter: 89
Mileage: 134568 km
Time Indication: 0
Date: 2013.08.29
Time: 00:58:46
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Reset counter: 89
Mileage: 134573 km
Time Indication: 0
Date: 2013.08.29
Time: 20:48:43
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 3
Reset counter: 19
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:31:40
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
Fault Priority: 3
Fault Frequency: 3
Reset counter: 19
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:31:40
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301109001708
Coding: 108104
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D718FF5AC71A9AC33-8068
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag012 H09 0020
Revision: -------- Serial number: 003GZ000HFMM
Coding: 003132
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4C97D231E7CB1024B4-8018
Serial number: 3575HRB405V0GR3468BI
Serial number: 3585HRB405V0GR34APG2
Serial number: 3515RRB405J0H4DQB1MT
Serial number: 3525RRB40650ESC6GGBQ
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H21 0320
Coding: 140C00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 72EB6CC9A5AF26D41E-8026
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 0230
Coding: 002000
VCID: 70EF66C1A3A314C4E8-8024
3 Faults Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:27:11
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:13:31
03590 - Control Module for Multifunction Module
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 134567 km
Time Indication: 0
Date: 2013.08.29
Time: 00:07:52
Component: IMMO H21 0320
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74A98D7FEE14A6-803E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 C HW: 1T0 035 686 C
Component: RNS-MID H10 5238
Revision: AB001001 Serial number: VWZ6Z7S513740Y
Coding: 00010400040000810001
VCID: 3467AAD1973B68E4CC-8060
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
2 Faults Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Priority: 5
Reset counter: 49
Mileage: 134560 km
Time Indication: 0
02877 - Digital Radio Antenna (R183)
011 - Open Circuit
Fault Priority: 5
Reset counter: 49
Mileage: 134560 km
Time Indication: 0
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 00788
VCID: 2F6DA5BDEA1D4B3CB1-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0116000001000000
VCID: 77FD5DDDCECD43FC29-8022
1 Fault Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 18
Mileage: 134567 km
Date: 2019.04.08
Time: 00:08:57
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
2 Faults Found:
011 - Open Circuit
Fault Priority: 5
Reset counter: 49
Mileage: 134560 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Reset counter: 49
Mileage: 134560 km
Time Indication: 0
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603489117
Coding: 020000000100011000000400
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_A02.rod
VCID: 2345598D2AD5FF5C25-8076
1 Fault Found:
9458451 - Cellular Antenna
B1053 13 [009] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 49
Mileage: 150855 km
Date: 2019.12.14
Time: 16:23:03
End-------------------------(Elapsed Time: 04:15)--------------------------
Hi Fernando
Sorry for a delay but I am unable to post my Autoscan here.
First it says that my post have to be accepted by the board. Then that my post contains contacts, so it is spam.
Also my function to send pm's is inactive, so in this situation I can send it to you either by an e-mail or post in somewhere online.
Hi.
Ok, solved, I had to approve your post.
VIN? tenth digit.
