Replacement engine
Re: Replacement engine
A decent mechanic would take no more than an hour to diagnose and correct the timing.
You should be able to do it yourself. Simple check the timing as per that diagram and the steps noted, and see how its looking. Then its just a case of slackening the tensioner, removing the belt, correcting the cam(s) putting the belt back on and tightening the tensioner back up.
littlepolo
Post by littlepolo »
The irony is I did its first belt swap using a meccano set (OK, some scrap metal and bolts) to set the cams/timing.
This time around I got the proper tool and messed it up.
Its easily done. It doesnt take much to get it out. If the tensioner isnt right, it can go out of timing after a few revolutions
Ah, sounds like the end could be in sight! A month or so ago, I was helping my mate get his old SAAB 96 which has a German Ford 1.5 V4 in it back running after getting lead free tolerant valve seats fitted and a bent push rod replaced, it just would not run and kept sending flames back out the carb inlet. After nearly discharging the battery fully, we called it a night and out the battery on charge and cracked open some whisky wine and food! Next day with a charged battery so no luck, then I switched my brain on and went over what work he had done prior to me arriving - the distributor was fitted 180 degrees out, changing that sorted things out very nicely! It tends to be just too easy to ignore checking some basic things once you have your blinkers on, very difficult to stand back and think about all the possibilities.
littlepolo
After checking the timing today it looks like the valve timing is late (No 1 cylinder is after the TDC timing mark when the locking tool drops into the cam sprockets. It looks like it is a tooth out. If I'm not mistaken the sprocket is 24 teeth and 360/24 equates to 15 degrees. With the valve timing retarded by this amount is there any risk of a bent valve?
The main cambelt is new-ish (less than 5 miles use) and the tensioner only a few thousand miles (less than 12 months). Are these OK to refit?
A tooth out won’t damage the valves
And yes, you can reuse everything no problem
littlepolo
Stripped down and checked the timing belts vs. the indexes. Found the crank pulley was advanced one tooth meaning the valve timing was retarded. Also found the camshaft link belt was out as the locking tool would not go in both holes at TDC at the same time. It looks like the exhaust was retarded a further tooth. Thinking back it had been quite an effort to get the belt on and that might have been because the index was out.
Reset the camshaft link belt ensuring the locking tool went in to both sprockets correctly then proceeded to reset the main timing belt accordingly. With the camshaft link belt correctly indexed the main timing belt went on quite easily (and easier than before). Rotated two full revolutions and it was clear the timing was correct (easy to drop in the locking tool and remove it).
Did a quick startup to check the running condition and the engine started first time. Definitely running better with the correct timing. One thing I did notice was quite a lot of noise from the end of the cylinder head nearest the belts. When I had started it up before there was light tappet noise and it settled down fairly quickly to normal levels of noise for a VW engine. Would the changed (correct) timing be an explanation for this - as in some of the hydraulic tappets have maybe not yet pumped up properly? Ran out of time today but will take it out for a run tomorrow to see if it settles down when warmed up.
Thats good youve managed to get the timing sorted
Sometimes, if the timing has been out, it can take a few mins for it to settle down. Especially if its cold, as the oil is thicker and the journals take a few mins to fill properly.
When i did the HG on my Mk2 GTI it sounded like a bag of nails as the head was empty of oil (even though I primed it a fair amount whilst rebuilding it and before i put the cam cover back on). After 10 mins it sounded sweet as a nut
Run it for 5-10 mins and see how its going.
littlepolo
Test driven this morning after clearing codes. All seems to be OK. Quieter than it has ever been.
I'll put up some photos and a summary later.
Im glad we managed to get it resolved. On the flip side, you've plenty of new parts now that will keep it running better for longer 8)
littlepolo
Spoke a bit too soon. After a lengthy test drive it started to run rough when I came to a halt.
It ran perfectly well at highway speeds (60mph).
DTC 17961 & 17912. Going to switch the MAP sensor.
VAG Error Code: 17961
EOBD II Error Code: P1553
Fault Location:
Manifold Absolute Pressure (MAP) Sensor (G71)/Barometric Pressure (BARO) Sensor (F96) - Range/Performance Problem
Possible Cause:
Intake/exhaust leak.
Exhaust Gas Recirculation (EGR) system.
Evaporative Emission (EVAP) Canister Purge Valve (N80).
Throttle control unit.
Wiring.
Manifold Absolute Pressure (MAP) Sensor (G71).
Barometric Pressure (BARO) Sensor (F96).
VAG Error Code: 17912
EOBD II Error Code: P1504
Fault Location:
Intake System - Leak Detected
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) active.
Intake leak.
Evaporative Emission (EVAP) System.
Hose connection(s).
That implies either an EGR issue or you have a vacuum leak.
Same issue here. http://www.volkswagenforum.co.uk/showthread.php?t=11474
littlepolo
Thanks for the info.
Ran out of time today but unplugging the MAP sensor seemed to have no effect (engine hot) other than throwing a code whereas unplugging the EGR did (idle settled after a few throttle blips and a few minutes). I adapted the EGR and throttle again while the engine was at operating temp. No change.
Put the vacuum gauge back on. Steady 16 at a fast idle. It's a bit low but drops near zero and bounces back near 25 on throttle blip.
I'll try again tomorrow and run it from cold. Can I drive for a few km with the EGR unplugged once its warn to verify it is at fault?
If EGR is faulty what is the minimum quality I need to ensure no further problems (at least not this year)?
Vacuum sounds ok now
EGR wise. Bosch or OEM. I’ll dig out some links for you with part numbers
And yes, you can unplug the EGR. It might throw an error but should behave itself
