Franciswat's Polo 6R 1.6 Bifuel
Franciswat
Drives: 6R 1.6 Bifuel
Re: My polo 6r bifuel
Post by Franciswat »
Hi ciclo, you do not have to apologize my friend I just worried you were fine. :wink:
To cut my long polo's story short as you remember I upgraded the bcm following Pavel's tutorial but It did not work. After that I insulated both T17/6 and T17/7; Pavel's tutorial does not say about it but I read that you told federico to do that ( :arrow: viewtopic.php?f=56&t=70787) and after this operation bcm worked correctly*. In order to check if my installation is correct you asked me to provide again pictures of my connectors and I posted them in previous post ( :arrow: viewtopic.php?f=56&t=70398&start=90#p541310). :wink:
*a part for one thing :arrow: faulty light warning appears every time I insert reverse gear :!:
One week ago my car (parked) had been involved in an accident and some interior component had been damaged (in addition to the bodywork).
Waiting for bureaucratic times to repair It I can provide you the last autoscan done before accident.
Thank you for your understanding and kindness! :wink:
Monday,03,September,2018,00:25:27:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZCY54xxxx   Mileage: 77040km-47870miles
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BBF08E10600923808006D2B0CD100C0412F60860000200000020000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0339054
   Coding: 820000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:59
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20251528901029
   Coding: 100001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K.rod
   VCID: 3A7CE9AABDC4D991E7-806E
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   VCID: 4A9CB96AED24491177-801E
   Serial number: 3575HRB4059124B2F99H
   Serial number: 3585HRB4061131GQCOUS
   Serial number: 3515RRB405P0VC0I5P0W
   Serial number: 3525RRB40510VC0IA9B9
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3460C7929FA02FE13D-8060
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 6RD 035 187     HW: 6RD 035 187
   Component: Radio         517 5124
   Revision: RB101000    Serial number: VWZZZ4Q5034465
   Coding: 00000400040005
   VCID: 0400575287805F61CD-8050
4 Faults Found:
00874 - Treble Speaker Front Left (R20)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:57
00875 - Treble Speaker Front Right (R22)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:57
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:57
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:57
End-------------------------(Elapsed Time: 03:15)--------------------------
My deepest gratitude for your concern towards me. 8)
Now I'm in perfect condition, and now the important thing is you and your 6R. :wink:
I regret the accident in which your 6R was involved when parked, hopefully the damage has an easy solution and you can enjoy your 6R as soon as possible.
Solution for the warning light when you enter reverse gear:
There are two possible solutions: (chosse one)
1- Install a new 1.0mm2 thickness wire from T73b/12 BCM white connector to the T6/5 right taillight connector, isolate T6/5 original wire.
(only for 6R with manual gearbox, i.e, your 6R)
or
2- New BCM coding: 3CB02BBF08E1060092380E406D2B0CD100C0412F60840000200000020000
(solution + CH/LH activated)
The best and most original is the first one.
Explanations about the installation guides.
- Pave's 6R don't have T17/6.
- Pave's 6R is DSG.
- T17/7 it's necessary to isolate it when installing the red connector for automatic lights (other guides, ...it's not your case).
I told you to remove/isolate it to rule out the possible causes of the problems you had previously.
In any case it keeps isolated by the other end (in relay holder) when installing the electric bridge instead of J331 relay.
Franciswat
Now I'm in perfect condition (...)
Glad to hear about it mate, this is the most important thing! :roll:
Thank you for your the exhaustive explanations (as always) ciclo! :wink:
I'll try first solution then but sorry am curious asking you how coding of second solution solves problem. You talk about CH/LH but I think they need extra wirings I miss. :roll:
In the end I forgot to tell you about this error which appears under 09. cent elect. since bcm upgrade.
1 Fault Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:59
I found this on Rosstech website :arrow: http://wiki.ross-tech.com/wiki/index.php/01134
Possible Causes
- Fuse(s) faulty
- Wiring and/or Connector(s) from/to Alarm Horn (H12) faulty
- Alarm Horn (H12) faulty
Possible Solutions
- Check Fuse(s)
- Check Wiring and/or Connector(s) from/to Alarm Horn (H12)
- Check/Replace Alarm Horn (H12)
Francesco :wink:
Franciswat wrote: Thu Oct 11, 2018 12:05 am I'll try first solution then but sorry am curious asking you how coding of second solution solves problem.
...by removing the lamp diagnostics.
Franciswat wrote: Thu Oct 11, 2018 12:05 am You talk about CH/LH but I think they need extra wirings I miss. :roll:
Only Automatic lights need additional wires/relay-s.
1 Fault Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 77040 km
                    Time Indication: 0
                    Date: 2013.01.24
                    Time: 09:54:59
Once I have read this thread in its entirety, this fault appeared when you made your first unsuccessful attempt to install the wires for the BCM adaptation ... and battery totally drained.
In previous autoscans, the fault is displayed with the original BCM High (087) re-installed and also with the new BCM Max (090) installed.
If you have a new battery installed try the following:
- Disconnect the battery (-) for a while. Take a beer.
- Connect again.
- Connect the VCDS cable
- Click on Autoscan, click on gateway installation list, wait for the reading, click on clear all DTCs, click on done, wait for results, click on Start... wait the new autoscan, save.
- If the results are positive, take a second beer and smile, if the results are negative, come back here.
Franciswat
(...) this fault appeared when you made your first unsuccessful attempt to install the wires for the BCM adaptation (...)
I apologize ciclo, I did not remember It appeared even with old bcm. :roll:
Battery is not new (It's a 6 years old battery I suppose If previous owner had never changed It - I bought car in 2016); I've just checked battery voltage with engine off and It's 12,8 v.
I tried anyway to do as you suggested (alarm fuse is good) but error did not disappear. Do you think I have to replace the battery? :wink:
PS I enabled CH/LH with VCDS but they did not work. I suppose they work only with xenon headlights installed (I have halogen lamps).
Cheers,
Francesco :wink:
Could you please clarify 2.8v battery power with engine off. Do you mean 12.8v?
Franciswat
Yes iichel indeed, sorry. :wink:
Franciswat wrote: Thu Oct 11, 2018 11:14 pm I tried anyway to do as you suggested (alarm fuse is good) but error did not disappear. Do you think I have to replace the battery? :wink:
In the previous autoscan it is clear that fuse 44 is fine and I do not think you have to change the battery.
What happened to the warning light when you put reverse gear? (with new BCM coding)
Franciswat wrote: Thu Oct 11, 2018 11:14 pm PS I enabled CH/LH with VCDS but they did not work. I suppose they work only with xenon headlights installed (I have halogen lamps).
Cheers,
Francesco :wink:
No, it is not related.
If wires installation for the BCM adaptation is correct, they should work with both models of lights.
...continuing my methodology to know the health status of your electrical installation, enter this new BCM coding.
3CB02BBF08E1260092380E406C6B0CD100C0412F60842000200000020000
Coming home:
Take out the ignition key from the ignition switch.
Pull from the lever of High Beam to flash once.
Open the driver door.
The lights should turn on.
Leaving Home:
When open the car with the remote control, the lights should turn on.
Please, new Autoscan and inform us. Thanks.
Franciswat
I used the last code you gave me in new BCM, ciclo. :wink:
That's the autoscan (some faults are related to the accident because car has not been repaired yet):
Saturday,13,October,2018,18:12:52:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx   Mileage: 79300km-49274miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 0003SH02
1 Fault Found:
00819 - High Pressure Sensor (G65)
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 79307 km
                    Time Indication: 0
                    Date: 2013.03.05
                    Time: 18:29:33
   Coding: 3CB02BBF08E1260092380E406C6B0CD100C0412F60842000200000020000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 820000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 79307 km
                    Time Indication: 0
                    Date: 2013.03.05
                    Time: 18:29:38
   Coding: 100001
   ASAM Dataset: EV_V7W5XParkAssis4K 001004
   ROD: N/A
No ASAM data for: "EV_V7W5XParkAssis4K" (VW25)
   Coding: 003232
   ASAM Dataset: EV_AirabVW10BPAVW250 A01001
   ROD: N/A
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirabVW10BPAVW250" (VW25)
   Coding: 140A01
   Revision: B9080001
   Coding: 002200
   Serial number:
   Coding: 11250
   Shop #: WSC 00788
End-------------------------(Elapsed Time: 03:12)--------------------------
About CH/LH I did as you said and I noticed that:
If I enter the last code you gave me :arrow: 3CB02BBF08E1260092380E406C6B0CD100C0412F60842000200000020000
- CH: low beam lights and parking lights switch off after 15 seconds when I leave the car
- LH: does not work
If I enter the code you gave me to solve rear light bulb error some posts ago :arrow: 3CB02BBF08E1060092380E406D2B0CD100C0412F60840000200000020000
- CH: fog lights and parking lights switch off after 15 seconds when I leave the car
- LH: does not work
With both BCM codes above I have no more bulb warning light when pull reverse gear. :wink:
It's what I assumed. Perfect!
The wiring health status that you manufactured and installed is in good condition.
The tests for CH/LH are correct, and they mean the following: (apart from providing me with the information I needed)
- that you must make a new electric installation for fog lights without BCM control when installing the Bixenon headlights (not in case you install LED headlights).
- the LH function works in conjunction with the light sensor and the light switch in AUTO position, and that is the reason why LH function not works in your car... it is the right thing in your case.
I'm afraid that you will have to buy new batteries for the alarm siren to solve the alarm fault/problem (as indicated in the ross-tech link).
But without a doubt it is much better to buy a new alarm siren, because you have to remove the alarm siren anyway.
1K0951605C e.g. search with google (images) and you'll find ...
Franciswat
Thank you very much for your help ciclo.
After my car will be repaired (I hope soon If the ensurance company will move on ..) I will start with light washers and xenon installation (which I already have).
I will probably need some help so please have patience with me! :wink:
Thank you again!
Franciswat
Does anyone know If it's possible to add on polo 6r the function for which right mirror automatically tilts down when you insert the reverse gear to park (like Golf)? :wink:
I don't know the english name of that function but translating from italian is "curb function".
Here's what I mean:
https://youtu.be/u_jVCvFTbl0
In ours 6R it's not possible with original parts.
Franciswat
Damit It Will be an useful add ciclo.
An other unrelated question!
Do you know how many horns polo 6r has?
I found on etka the single horn version and the double one version. Since I have to replace mine I do not know which version I have! :wink:
There is the so called 'treble horn' which has the high tone
And there is the so called 'bass horn' which has the low tone.
The lower equipped Polo 6R has only the treble tone (i.e. easyline, trendline) while the higher equipped versions have both the bass and treble horns (i.e. comfortline, highline, GTI, BlueGT, WRC).
They are located behind the left hand side foglight, if you remove it, you'll see it from the top.
