Any modified Polo's???
mjsaville
Re: Any modified Polo's???
Post by mjsaville »
Superb, thanks for that.... Our car is still mid delivery due to the lockdown.... Hopefully get it in another month or so... :roll:
MJ
Teee
Drives: Polo gti +
Post by Teee »
J+silva wrote: Sat Sep 14, 2019 9:53 am I install the reverse led and to my surprise no code is needed it has no error.
J+silva wrote: Mon Aug 12, 2019 10:06 am Hi,does anyone know how to code the reverse light lamp to leds I would like to change it.
Hi what led bulb did you use ? I’m trying to find some led reverse light bulbs thanks
J+silva
Drives: polo conf.
Post by J+silva »
Teee wrote: Tue May 05, 2020 11:20 am
I bought this leds to the reverse light and turn lights. The turn lights its PY21W and reverse its P21W.
https://pt.aliexpress.com/item/32985355 ... b90an61aKb
Teee
Drives: Polo gti +
Post by Teee »
J+silva wrote: Tue May 05, 2020 1:45 pm
Thanks appreciate that buddy gonna order them now 😎
Dazeredo
Drives: Polo aw1 1.0t 95hp
Post by Dazeredo »
Did you buy only the reverse lights or did you buy also the turn signal?
I was counting when I bought the car that All lights were on led and I was looking for led bulbs to replace the bulbs of the reverse and rear turn signals [emoji28]
J+silva
Drives: polo conf.
Post by J+silva »
Dazeredo wrote: Tue May 05, 2020 7:58 pm Did you buy only the reverse lights or did you buy also the turn signal?
I have change reverse lights, turn signal and interior lights to leds.
Dazeredo
Post by Dazeredo »
I think is time for me to do the same.
Just for curiosity, the interior lights don't blink while fading? I had that problem in my previous car.
J+silva
Drives: polo conf.
Post by J+silva »
I had zero problems until now with the interior leds, whenever a change causes me problems i don't change anything. :)
Not that I've looked, but I thought that only the reversing lights in the rear cluster for the GTI+ were ye olde halogens. Is that not the case?
Or perhaps there are different rear cluster variants for different markets/trim levels?
J+silva
Drives: polo conf.
Post by J+silva »
monkeyhanger wrote: Wed May 06, 2020 11:35 am Not that I've looked, but I thought that only the reversing lights in the rear cluster for the GTI+ were ye olde halogens. Is that not the case?
In my case the reverse light and rear turn signal were normal lamps.
J+silva wrote: Wed May 06, 2020 1:36 pm
I'll have to take a closer look at mine to determine if there are different variants with more or less incandescent bulbs, but the UK brochure does suggest that different trims get different rear clusters.
For all trims except R-line and GTI/GTI+, there is no mention of rear clusters.
For R-line, we have mention of LED tinted rear light clusters
For GTI/GTI+ we have mention of LED darkened rear light clusters.
That does suggest to me that only R-line and GTI/GTI+ get LED rear light clusters, in the UK at least.
Dazeredo
Post by Dazeredo »
I can´t tell for sure but the GTI rear cluster seems the same that the regular Polo with the optional LED package. I noticed that lot of brands only put LED on the red part of the rear cluster on this car segment.
PS: I know that at the front they are different, the GTI got a red stripe.
J+silva
Drives: polo conf.
Post by J+silva »
For me personally I like leds and I change (when possible) every lamps to leds and in the polo I think its everything in leds :D
proalves
Drives: Polo GTI AW1 2019
Post by proalves »
On my GTI the reversing light and rear turn signal are normal lamps.
I remember seeing in the GTI presentation they mention that.
J+silva
Drives: polo conf.
Post by J+silva »
I made a change in the car trunk.
