Polo 6R 1.2 GT Tsi RHD
Re: Polo 6R 1.2 GT Tsi RHD
Contact iichel.
Your best bet is to open a new thread, 'maybe' iichel needs some more info that is not related to this thread.
Once you open the new thread he will guide you on the right path.
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
Dear Ciclo,
As you know my cornering lights are not properly functioning with 7E0937089D bcm. You suggested to compare the parameters with my other BCM 090D.
Instead can we try updating the firmware to the latest? I was referring to your thread.
Do 090E firmware supports LED headlights? With full functionality?
If yes can you help me with this? I may need a firmware.
- Sakthi
I don't know if your Static Cornering Lights are working properly or not, or at least I don't remember you telling me anything about it.
According to the last BCM coding we did, they should work perfectly if you have the original bulbs installed.
Your current BCM already has the best possible firmware... 0772. 😊
Edit:
Okay, I just finished reading the issue about your SCLs with Osram "LED" bulbs.
Did you do what I told you to do with VCP?
In a hacky way 🏴‍☠️, and without knowing what might happen to the rest of the lights (nothing will break), try putting a value of 67 HEX in Byte18 in the coding of your BCM 089D.
This HEX value always gave good results for installations with 'non-original' lamps.🤭
If you get what seem to be good results for your SCLs you will have to observe how the rest of the lights work over time.🤷‍♂️
sshakthi123
updated the coding and now the SCL's works perfectly :mrgreen:
At high level I did basic checks of all the lights and all of them worked at first glance.
should i be checking anything else specifically?
As always I appreciate your support in fixing this.
But what / why is this fix? I didnt see these byte values under Byte 18.....
Sunday,22,December,2024,21:34:01:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT-LED-HL-FOG
Mileage: 68030km-42271mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 65
VIN: MEXL15600GT052162   Mileage: 68030km-42271miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501505175568
   Coding: 0000024
   Shop #: WSC 30641 005 1048576
   VCID: 3A7B84EA755F9F9416-806E
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 62DD2463422803C24615246F4253C0800909
   VCID: 000F36029B03054418-8054
   Serial number: 10051504650266
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 089 D    HW: 7E0 937 089 D
   Component: BCM PQ25 MMI4 H84 0772
   Revision: BB084001    Serial number: 2602 180190154
   Coding: 3AB02BFF48A10000213806207CEB9E9090C0676F60CD39D1210400030020
   Shop #: WSC 00046 123 12345
   VCID: 3467AAD2973B69E4CC-8060
   Component: RLHS 200618 0  50  0107
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU031031440906027
   Coding: 1400B3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU013011440132978
   Coding: 0400B3
   Subsystem 4 - Part No SW: 5TA 959 442     HW: 5TA 959 442
   Serial number: 1131818514601282AJ1B
   Coding: 250000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13202580150909024344
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150901174201
   Coding: 020000
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391606504499
   Coding: 0001151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 68039 km
                    Date: 2024.12.22
                    Time: 21:30:16
   Revision: --------    Serial number: 003GW0115JH8
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140801
   Shop #: WSC 00078 790 12345
   VCID: 479DED1EFEADF27C99-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 089 D
   Revision: BB084001
   Coding: 002307
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H05 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
   Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
   Component: MU-S--ER      H20 0240
   Serial number: VWZAZ2R8806143
   Coding: 02630100BE0000001111000101182A001F0100D60020010003
   Shop #: WSC 00066 790 00056
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2541479624E1006C4B-8070
1 Fault Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 68039 km
                    Date: 2024.12.22
                    Time: 21:30:16
                    Voltage terminal 30: 13.6 V
   Serial number: 40000000256160
   ROD: EV_RDKBERU30_005.rod
End-------------------------(Elapsed Time: 03:10)--------------------------
sshakthi123
ciclo wrote: Sun Dec 22, 2024 1:15 pm Did you do what I told you to do with VCP?
No, yet to do those checks. I’ll try that as soon as possible.
There are no scientific studies on this, just 💥BOOM!💥 experiments.😁😂
BTW, my 6R with Bixenon (SCLs) from factory came with 67HEX value in Byte18, maybe with VCP you can draw conclusions... 🧙‍♂️
Always very grateful for your wise attitude in posting the Autoscan.👌
sshakthi123
Thanks Ciclo.
I’ll try to do the VCP tests at the earliest.
sshakthi123
Periodic autoscan, post the recent oil service.
Wednesday,06,August,2025,21:07:38:00006
VCDS Version: 18.2.0.3 (x64)
www.Ross-Tech.com
Mileage: 74360km-46205mi   Repair Order:
VIN: MEXL15600GT052162   Mileage: 74360km-46205miles
Readiness: 0000 0000
   Coding: 0000024
   Coding: 62DD2863422803C24615146F4253C0800909
   Coding: 01
   Revision: V0000000
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
2 Faults Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 150
                    Mileage: 74246 km
                    Time Indication: 0
                    Date: 2025.07.21
                    Time: 17:58:20
03587 - Control Circuit for Starter Lock Lock
            007 - Short to Ground - Intermittent
                    Fault Status: 00100111
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 74320 km
                    Time Indication: 0
                    Date: 2025.08.02
                    Time: 21:52:03
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 72207 km
                    Date: 2025.04.20
                    Time: 00:36:01
   Coding: 003036
   Coding: 140801
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 254
                    Reset counter: 159
                    Mileage: 72207 km
                    Date: 2025.04.20
                    Time: 00:36:49
   Revision: BB084001
   Coding: 002307
   Serial number:
2 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 72207 km
                    Date: 2025.04.20
                    Time: 00:36:01
                    Voltage terminal 30: 12.0 V
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 74306 km
                    Date: 2025.08.02
                    Time: 13:34:39
                    Voltage terminal 30: 13.2 V
                    Interface for external media: status-Status: Open circuit
End-------------------------(Elapsed Time: 02:52)--------------------------
