Page 71 of 333
Posted: Sun Jun 07, 2015 10:22 pm
by CNK
ciclo wrote:CNK, look at all pictures of this link, perhaps this will help. :wink:
I'm trying to fix net side trunk: http://www.uk-polos.net/view ... 60#p469759 but how I can remove the side panel without removal of the rear seat?
Image Image
Posted: Mon Jun 08, 2015 6:37 am
by ciclo
Image Image Image
Posted: Mon Jun 08, 2015 12:29 pm
by diskoboy
diskoboy wrote:
diskoboy wrote:
ciclo wrote:diskoboy, remember you have to check the current flow diagrams before making any modification to the original wiring.
Perfect. I'll allready have the connectors - the red one is the same and the new 1k0972928 I have from an Passat - same connector used in the ignition/starter switch :)
All of the pins in the 16-pin-connector are the same in Polo year 2011 (6R) and 2016 (6C) :D
6C climatronic control unit DOES NOT WORK in a 6R. End of story.
                Address 19: CAN Gateway       Labels: 6R0-907-530-V1.clb
Control Module Part Number: 6R0 907 530 B    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H28 0020
           Software Coding: 7D431D20080000000002
            Work Shop Code: WSC 00788 648 00255
                      VCID: 3260AE41AD7D09B1A84-8067
1 Fault Found:
01336 - Company Data Bus for Comfort System
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 89
                    Mileage: xxx km
                    Time Indication: 0
                    Date: 2052.14.15
                    Time: 14:43:18
I can see in ETKA that 6R0 907 530 E exists, but don't believe that it will ever work...
Posted: Mon Jun 08, 2015 8:22 pm
by ciclo
Thanks for the information. :wink:
It is quite likely that all parts of 6C who are involved with CAN lines will not work on 6R.
Posted: Tue Jun 09, 2015 8:00 am
by CNK
Thanks ciclo, I will try again :)
On the vwvortex forum I found an interesting shelf from Golf VI (Rear Storage Tray, 1K0061178A):
http://i227.photobucket.com/albums/dd15 ... e18b8d.jpg
This is very useful, but there is no such shelves for Volkswagen Polo :(
Posted: Tue Jun 09, 2015 11:39 am
by grem
CNK wrote:Thanks ciclo, I will try again :)
This looks like something I definitely need. I found one for the polo but it is from china
http://www.aliexpress.com/item/Rear-Tru ... 42053.html
Posted: Tue Jun 09, 2015 7:27 pm
by ciclo
Search more closely with other words on aliexpress, I've seen such parts cheaper.
For example: http://www.aliexpress.com/item/Rear-Tru ... 58385.html
Posted: Sun Jun 14, 2015 4:26 am
by ciclo
A very complete video about Polo 6C R-line.
I like this video. :wink:
It is a pity that on Polo 6R/6C is not possible the Highbeam Assistant. HBA
http://en.volkswagen.com/en/innovation- ... ssist.html
On the other hand, it seems that the LEDs headlights provide good lighting at all times, but the appearance of the headlights is not my favorite. :?
They need a better design in appearance. IMHO
Posted: Tue Jun 16, 2015 5:10 pm
by shpunt
Hello.
Help me pls activate Auto folding mirrors on my VW Beetle 2014 (3 doors).
I have the same door component.
and my coding:
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 28013050140479
Coding: 7CB8697848430C0093A80F306CCB96C4AD42610F60842D41B2A0140A0000
Shop #: WSC 00066 123 12345
VCID: 2D51EF3674B133760F5-8078
Subsystem 2 - Part No SW: 6R0 959 801 BK HW: 6R0 959 801 BK
Component: J386__TSG_FT 003 8662
Coding: 0000A5
Subsystem 3 - Part No SW: 6R0 959 802 BR HW: 6R0 959 802 BR
Component: J387__TSG_BT 003 8662
Coding: 1000A5
What coding for J386 and J387 i can use for Auto folding mirrors ?
(i have factory folding installed)
Posted: Tue Jun 16, 2015 5:37 pm
by ciclo
This is the coding for POLO 6R (LHD, like your Beetle) three doors. Try it and tell us the results :wink:
Undersystem 2 - Styreenhedsnr: SW: 6R0 959 801 BD HW: 6R0 959 801 BD Forklaringsfil: NEZ\6R0-959-801.CLB
Komponent : J386__TSG_FT 003 8620
Kodning : 0280AB
Undersystem 3 - Styreenhedsnr: SW: 6R0 959 802 BF HW: 6R0 959 802 BF Forklaringsfil: NEZ\6R0-959-802.CLB
Komponent : J387__TSG_BT 003 8620
Kodning : 1080AB
Same functions as in the Polo 6R:
My guide: http://www.uk-polos.net/view ... 30#p481352
Posted: Tue Jun 16, 2015 5:39 pm
by shpunt
ok.
i'll try.
Posted: Tue Jun 16, 2015 6:08 pm
by shpunt
Ok.
But it can be different coding for Beetle.
I'll try.
Posted: Tue Jun 16, 2015 6:42 pm
by ciclo
Yes, you are right, especially by the system of door closing.
But this is the best information I can provide..., however, if you lose some function, you will have integrate the Bits of your previous coding to the new coding. (enabling or disabling bits)
Удачи вам :wink:
Posted: Tue Jun 16, 2015 7:02 pm
by shpunt
Posted: Wed Jun 17, 2015 5:57 am
by shpunt
this coding dont work on my Beetle.
Beetle have frameless doors, ie glass on top has no border. (the same as VW Passat CC)
and when you open the door - glass drops slightly (exits the rubber seal 5 mm).
but after this coding - the glass does not fall and I can not open the door.
