Locked
J386__TSG_FT 003 8662
Coding: 0000A5
J387__TSG_BT 003 8662
Coding: 1000A5
With these codings can you opening the door correctly?
shpunt
Drives: Polo 6R
Post by shpunt »
yes. this coding is my factory door coding.
Possible codings:
driver door : 0080AF
passenger door: 1080AF
or
driver door: 0280AF
or
driver door: 0000AF
passenger door: 1000AF
or
driver door: 0200AF
Try these codings and tell us the results of the codes with fewer functions losses.Image
I found these codes from a Beetle 5C. The control units of the windows are to Bleetle with folding mirrors.
Subsystem 2 - Part No SW: 6R0 959 801 AQ HW: 6R0 959 801 AQ Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 1060
Coding: 0CBC34
Subsystem 3 - Part No SW: 6R0 959 802 BD HW: 6R0 959 802 BD
Component: J387__TSG_BT 002 1060
Coding: 0CBC34
shpunt
Drives: Polo 6R
Post by shpunt »
Good.
But for J386 and J387 is the same coding.
Is this correct?
Yes, however, you should consider that might have the power window motors and has no folding mirrors. It is rare, but possible.
LINK
shpunt
Drives: Polo 6R
Post by shpunt »
Ok.
Byte 3 and bits 3,4,7 must be market too?
Not necessarily.
Try it without / with... without information in vcds labels anything is possible.:lol:
I never thought I would be able to write more than a thousand posts in English. I love me... :mrgreen:
shpunt
Drives: Polo 6R
Post by shpunt »
ok.
but on your link i see different coding.
in up pade side: Coding: 0CBC34
and down page side: Coding: 8CBC30
what correct for auto folding? :)
The first autoscan. 0CBC34
In the second autoscan the reference number of the window motors are incorrect.
shpunt
Drives: Polo 6R
Post by shpunt »
ok. i'll try this Coding: 0CBC34
auspolo6c
Drives: 6c
Post by auspolo6c »
hi just wondering if u could help me with the red wire do u bridge the two together on the relay or how do u do it do u connect 12 to the relay then pin 30 to car fuse box... im lost and I already blowen up two units sad to say as I have done a lot of work to my car and this is the one thing I cant get right
shpunt
Drives: Polo 6R
Post by shpunt »
Coding: 0CBC34
Is this coding for auto folding mirrors after lock car or simple folding mirrors ?
auspolo6c wrote:hi just wondering if u could help me with the red wire do u bridge the two together on the relay or how do u do it do u connect 12 to the relay then pin 30 to car fuse box... im lost and I already blowen up two units sad to say as I have done a lot of work to my car and this is the one thing I cant get right
Of course I can help you, but I wonder if you can specify exactly what you are doing.
What are you doing and what is your installation guide?
You have the Polo 6C, not 6R, is it right?
shpunt wrote:Coding: 0CBC34
Good question. :)
Locked
