Page 73 of 333
Posted: Thu Jun 18, 2015 6:52 am
by ciclo
Yesterday I changed my original stalks of steering column.
From 6R0953507C to 6R0953507B
Why?
Long time ago I had installed the multifunction buttons on steering wheel.
The problem is that the buttons for DIS (SW and right stalk) in both places at the same time provides electronic errors occasionally.
"The right side buttons of the steering wheel stops working when you push the buttons on the stalk"
The only way to solve this problem is to change the stalks.
Done the change, everything works perfectly !!! Tested.
In this way it is just like the steering wheel and stalks Polo 6R BlueGT, GTI or WRC. Now all work like a charm in my R-line. Image
Posted: Thu Jun 18, 2015 7:18 am
by ciclo
shpunt, :idea: comfort function to remote control.
current coding 09 cent elect: 7CB8697848430C0093A80F306CCB96C4AD42610F60842D41B2A0140A0000
New coding 09 cent elect: 7CB869F848430C0093A80F306CCB96C4AD42610F60842D41B2A0140A0000
Posted: Thu Jun 18, 2015 7:32 am
by shpunt
Ok. I'll try :)
Posted: Thu Jun 18, 2015 5:52 pm
by Mart!n-GTI-DK
ciclo wrote:Yesterday I changed my original stalks of steering column.
Nice job Fernando. :)
Posted: Thu Jun 18, 2015 8:07 pm
by ciclo
Mart!n-GTI-DK wrote: Nice job Fernando. :)
Thank you. It was a job that was pending. :)
I have to take some pictures of this change and others that I have done. Soon... after the summer :lol:
Posted: Thu Jun 18, 2015 10:00 pm
by CNK
Hello @ciclo, I saw that you changed your Instrument cluster MFA.
How do I know what instrument cluster will fit into my Polo? I have a 1.4 gasoline engine, I bought my 6R in July 2011.
I found two product numbers with speedometer scale up to 240 kph:
- 6R0920870c
- 6R0920871
Posted: Fri Jun 19, 2015 6:07 am
by ciclo
6R0920871 Bifuel model
If you look closely in the picture below you will see that the two scales of small spheres measure amount of fuel. In this case it is for petrol and gas because this instrument cluster is to bifuel. So it is not right for your petrol 1.4.
6R0920870 C , E. BlueGT model
This instrument cluster is right for your 1.4. :wink:
6R0920870 A,B,D 280 km/h GTI model
6R0920870 F 280 km/h WRC model
BlueGT customized with blue needles
... this latter info is for Peter ... :P
Posted: Fri Jun 19, 2015 6:27 am
by ciclo
ciclo wrote:
auspolo6c wrote:hi just wondering if u could help me with the red wire do u bridge the two together on the relay or how do u do it do u connect 12 to the relay then pin 30 to car fuse box... im lost and I already blowen up two units sad to say as I have done a lot of work to my car and this is the one thing I cant get right
Of course I can help you, but I wonder if you can specify exactly what you are doing.
What are you doing and what is your installation guide?
You have the Polo 6C, not 6R, is it right?
Posted: Fri Jun 19, 2015 8:07 am
by peter_dk25
Thanks a lot 8)
Posted: Fri Jun 19, 2015 8:46 am
by ciclo
peter_dk25 wrote:Thanks a lot 8)
:lol:
Posted: Fri Jun 19, 2015 1:41 pm
by Switeo13009
Buenas Ciclo =)
Tengo un problema con la modification Taillights Polo 6C. OEM.
Cuando pongo la W16W, se illumina 2 secundos y despues se apaga ... solo la W5W functiona normalmente :(
Podrias ayudarme?
Tendrias una solution?
Muchas gracias, de Francia :)
Posted: Fri Jun 19, 2015 6:25 pm
by ciclo
Switeo13009, you have a high consumption in your parking lights (electrical lines) of your "retrofitted xenon headlamps".
The front parking light on one side is electrically coupled to the rear parking light on the same side, and you have a high consumption in the two sides.
Try using LEDs bulbs (low consumption <5w, high lighting) on the parking tail lights, there is no other solution for this specific problem that you have.
Posted: Fri Jun 19, 2015 6:34 pm
by ciclo
shpunt wrote:Ok. I'll try :)
How about those tests?
Please, inform us when you have the solution for Auto folding mirrors on your BEETLE 5C Image
Posted: Sun Jun 21, 2015 10:30 am
by ciclo
ciclo's R-line, LHD, RHD, dropping, dancing, etc.... one shot.
Posted: Sun Jun 21, 2015 3:16 pm
by shpunt
dont work.
window dont open when i try exit from car.
and when i up right window - it down, and when down - it up.
