Locked
master991 wrote:Hello ciclo,
I think the brightness is very good for this "small" light's.
I have install the lights without the black plastic part. It's very easy to disassembling.
Cheers [CLINKING BEER MUGS]
Master991
geTapatalked
Ok, discretion and effectiveness are required, I don't want a light show for this mod (meditated Imagea lot about this matter), these small lights will be perfect to fulfill their mission.
LeeT96
Drives: 6R R-Line 1.2 TSI 105
Post by LeeT96 »
ciclo wrote:
LeeT96 wrote:Hi ciclo can you please tell me the part numbers for gloss black steering wheel trim and 6c lower R Line grilles? I am wanting these my self :D
You mean this? click on the picture
http://www.uk-polos.net/view ... 22#p494022 the change of grilles is stunning, you will like it ... :wink:
Thank you ciclo, I apologise for my ignorance! I should have looked harder haha!
I assume that the grilles and fog surrounds are a straight swap? Also, do the gloss black surrounds exist without the controls? I do not have controls currently and therefore they wouldn't work :-(
Sent from my Nexus 6 using Tapatalk
Hi LeeT96, sorry for delay (vacations time) :D
It is a straight swap, you can see in above link where clamping hooks are located, also in following link pictures of how to remove the foglamp cover(tools, etc ...) https://drive.google.com/file/d/0B2nv91 ... hpU2c/view
There are no glossy black trims without buttons to steering wheel model that we have.
CNK
Drives: 6R
Post by CNK »
@ciclo Could you tell me where it's the place where you connected the additional trunk lights to red and black cable?
I used lamp: 1K0947109
Photos: https://www.dropbox.com/sh/7rrwhlifssfh ... pc-Ia?dl=0
Do I need to connect one cable to the T5h on the left and the other to connector on the right side of the trunk?
I found these pictures: http://forums.tdiclub.com/showthread.php?t=358501
http://forums.vwvortex.com/showthread.p ... ts-our-car
Is there a better way to connect wires?
You know how to do "Dynamic bend lighting" in 6R with DLR and fog lights?
LeeT96
Post by LeeT96 »
hi Ciclo,
thank you for your help regarding the grilles!
Can I ask - due to the car being a turbo, therefore needing greater cooling procedures than the 1.2 N/A, would I be safe to put on my BlueMotion grille? There is no real way of air getting into the engine bay through the top grille if I decide to do so.
I am being lazy, not wanting to go outside, and am not sure where the air intake is, lower or upper? Assume it is upper.
gpeixoto109
Drives: 2013 Polo 6R 1.2TDI
Post by gpeixoto109 »
Hello ciclo! I have been watching your mods and really love most of them!
I bought a polo 6R nearly two months ago, and I was used to cruise control, but now in my polo I don't have it, but I saw I can install it, but I don't know the part number I need to buy.
I saw a website to buy, but I would like to know if is the right one.
http://www.cars-equipment.com/www/en/sh ... -fabia-vw/
can you please help me?
the part number I have right now on my polo is 6R0 953 521 A.
It´s a 2013 polo 1.2TDI 75
thank you!
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
LeeT96 wrote:hi Ciclo,
The Bluemotion is also a turbo engine...
And there is more than enough air going through the lower grill...
LeeT96
Post by LeeT96 »
Oh yes, really good point mate. However, is there nothing internally that compensates for less cold air?
Mart!n-GTI-DK
LeeT96 wrote:Oh yes, really good point mate. However, is there nothing internally that compensates for less cold air?
No. You should be good. :)
LeeT96
Post by LeeT96 »
Hi ciclo,
I now have the gloss front grilles from 6c, is there a gloss black diffuser from 6c RLine and if there is does it fit?
Thank you
CNK wrote:@ciclo Could you tell me where it's the place where you connected the additional trunk lights to red and black cable?
Click :arrow: https://drive.google.com/file/d/0B2nv91 ... FTMFk/view
We click on magnifier :) :
The red wire to pin 2 (positive) of the original trunk light.
The black wire spliced to blue red wire on the T5h / 1 connector.
This is the best way, so the lights switched on/off by opening and closing the trunk and electrical system shall be protected by the same fuse for the interior lights.
By the way, good job with the fit of the lamp. :wink:
About static cornering lights (not dynamic) depends on your BCM and the original installation fog lights on your POLO 6R, show me a clear picture of your fuse box.
gpeixoto109 wrote:Hello ciclo! I have been watching your mods and really love most of them!
thank you!
As you have trip computer, you have to get:
6R0953507C without MFSW
6R0953507B with MFSW
Recently I changed my stalks finished in C by B.
http://www.uk-polos.net/view ... 80#p496280
http://www.uk-polos.net/view ... 40#p497056
LeeT96 wrote:Hi ciclo,
Thank you
According ETKA diffuser R-line is the same for 6C and 6R, so there is no glossy black. You'll have to paint it. Image
gpeixoto109
thank you!
Hello Ciclo! I already have the radio controls in the steering wheel, but I would like to have the trip computer in the wheel to, is it difficult to install the MFSW controls?
thank you for your help, I can now buy the part I need!
gpeixoto109 wrote: Hello Ciclo! I already have the radio controls in the steering wheel, but I would like to have the trip computer in the wheel to, is it difficult to install the MFSW controls?
Hi gpeixoto, clarifications:
With buttons on the left side of the steering wheel (radio and phone) and without buttons on the right side of the steering wheel (multifunction display, trip computer ...), you need stalks finished in C.
The only way (OEM) to have trip computer controls on the steering wheel POLO 6R is installing a steering wheel like the one I have. (vw models: R-line, R, BlueGT, GTI, WRC, Scirocco, etc...)
If you install this steering wheel, you need stalks finished in B. (... and instrument cluster with MFD :!: )
To sum, if you do not want to spend much money to install cruise control, install the stalks finished in C.
Easy or difficult to install? This is a very common question, but it depends on the tools you have. (incl hands and brain ...Image) If you want, you can...
Cruise control is the best upgrade I did on my POLO 9N3 1.2 44kW ... IT IS PERFECT !!! Image... :lol:
gpeixoto109
Cruise control is the best upgrade I did on my POLO 9N3 1.2 44kW ... IT IS PERFECT !!! Image... :lol:[/
Thank you for your help! I thought the steering controls would do to the MFA, so to install the steering controls I have to change many things, one of them it's the cluster. I already tought of it, but didn't find the reference of cluster I need. All the clusters with MFD I see are for petrol engines, and I have diesel, is it possible to change anyway? Where can I find the cluster?
Where did you bought your stalks?
Can you tell me the part reference I need for the cluster and the steering controls?
Thank you!
CNK
Drives: 6R
Post by CNK »
ciclo wrote: Click :arrow: https://drive.google.com/file/d/0B2nv91 ... FTMFk/view
Thanks! Do you have a picture of this?
Why not connected the cables in this way: http://forums.tdiclub.com/showthread.php?t=358501?
http://cnk.net.pl/polo/2015-07-26-16.23.jpg
How you connected the wires?
ciclo wrote: About static cornering lights (not dynamic) depends on your BCM and the original installation fog lights on your POLO 6R, show me a clear picture of your fuse box.
My fuse box:
https://www.dropbox.com/s/1ree5nbydzqo8 ... 3.jpg?dl=0
Other info:
https://www.dropbox.com/s/ye58z76y7in6c ... 0.jpg?dl=0
Locked
