Locked
gpeixoto109 wrote: Thank you for your help! I thought the steering controls would do to the MFA, so to install the steering controls I have to change many things, one of them it's the cluster. I already tought of it, but didn't find the reference of cluster I need. All the clusters with MFD I see are for petrol engines, and I have diesel, is it possible to change anyway? Where can I find the cluster?
Where did you bought your stalks?
Can you tell me the part reference I need for the cluster and the steering controls?
Thank you!
For diesel 6R (2010-2014) there is no a reference number for instrument cluster with MFD as original replacement ... there are other alternatives (petrol cluster with modified software, Cluster from Skoda Fabia, etc...) but I not have information about these matters, sorry.
It's not possible right side buttons (OEM) for your steering wheel model, you need a new steering wheel.
I bought my new stalks in VW dealer.
CNK wrote: Thanks! Do you have a picture of this?
Why not connected the cables in this way: http://forums.tdiclub.com/showthread.php?t=358501?
http://cnk.net.pl/polo/2015-07-26-16.23.jpg
How you connected the wires?
No picture, sorry.
You can connect cables as you see fit. I always have in mind to use the least amount of cable for any installation (in case one day I can take my Polo Rline to Mars or a "new earth" ... and the spaceship reviewer :) says it weighs 10 grams more and my beautiful super-rline can not be transported :lol: ).
To add wires, I use the method of crimping terminals (like OEM). For example : http://www.uk-polos.net/view ... 90#p482495
Static cornering light is not possible in your 6R with current electrical installation of your fog lights (through the fuse SB54).
It is because your fog lights are not controlled by BCM J519(it would be through the fuse SB57, a very different electrical installation).
By the other hand your DRLs are not controlled by BCM.
You just can not make special changes with VCDS for these lights.
CNK
Drives: 6R
Post by CNK »
ciclo wrote:
CNK wrote: Static cornering light is not possible in your 6R with current electrical installation of your fog lights (through the fuse SB54).
So I should replace the BCM and buy an extra wires? Then it will be possible?
CNK, wait, not so fast ... :lol:
What is the reference number of your BCM?
Do you have ESP button? You need the steering angle sensor (G85) for the function of static cornering lights.
VCDS autoscan?
CNK
Drives: 6R
Post by CNK »
Ok ;)
Yes, I have ESP button: https://www.dropbox.com/s/lywuq5vn2anit ... 9.jpg?dl=0
My BCM:
   Component: BCM PQ25 H+4  H46 0256
   Coding: 3DB02BBF08F32400923008002C2B0CD00040410F60040000200000000000
VCDS autoscan: https://www.dropbox.com/s/bx9ezza9mpa14 ... 8.txt?dl=0
BCM 6R0 937 087 K
Fortunately you do not need to change the BCM. All you have to do is change the current wiring foglights for a new one. Once the new installation of cables is done, you must recode BCM. (I tell you how to code :wink: )
Now, I edit this post with information on what you must do to have static cornering lights on your POLO 6R.
We continue :) :
Your current electric installation of front fog lamps:
New installation in two steps:
1
2
VCDS coding (Once you have made electrical installation)
BCM (address 09)
current coding:
new coding:
3DB02BBF08F32400923008006C2B0CD00040412F60840000200000000000
Copy the new coding from here, paste it into the blank space for the new coding:
Done. :D
CNK
Drives: 6R
Post by CNK »
Wow, thank you very much! You are awesome!
CNK, perhaps you may be interested in this wiring:
http://www.ebay.de/itm/VW-Polo-6R-Kabel ... 2c5ff0c895
:wink:
CNK
Drives: 6R
Post by CNK »
Wow :O So if I will buy this wire I don't had to make any more change in my electrical installation?
In the description of this it says that we can do it in just 45 minutes. This is great.
This wiring is very cheap, made as OEM. If you really want to do this installation, you buy it, and when you receive it, make some pictures and show me the pins of each wire, then I'll tell you if you need additional wires. The key are the diagrams that I made for you (you must study them :mrgreen: ).
¿45 minutes? ... I'd say a little more time.
CNK
Drives: 6R
Post by CNK »
Hah, ok. I'm waiting for Terminal Crimping Tool now.
I am not a specialist in electronics, but I'll try to do it yourself :twisted:
I need to buy new fuse and terminals, too.
In my local car mechanic connect fog lamps costs $80.This is a much faster way, but.. I will try do it :D
Do you know where can I find any pictures which show the places where are connections from this scheme?
I'm a newbie :mrgreen:
In the following links you can see the connectors where you should connect the cables. (these links are guides to other installations)
Look for the pictures within the guides.
Light switch connector: http://www.uk-polos.net/view ... 71#p421710
Fuse box: https://drive.google.com/file/d/0B2nv91 ... ZrU0k/view
BCM connectors: https://drive.google.com/file/d/0B2nv91 ... E1bk0/edit
Fog lights connectors: https://drive.google.com/file/d/0B2nv91 ... hpU2c/view
As you will no longer need the 15 amp fuse SB54 you can avail this fuse for SB57 position.
My ORIGINAL stalks of steering column for sale: :arrow: http://www.uk-polos.net/view ... 92#p497669 (SOLD)
with CCS + TRIP computer buttons
Special wiring with J29 diode included
Image Image Image Image Image Image
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hello cycle, I have a question about mounting unit k 418..i two wires of the motor of the mirror (red and black / red brown) with which of the two wires (orange and brown) I will have to be connected? I do not quite understand from your guide
Red-black (T10f/4, T10v/4)---> orange
Red-brown (T10f/2, T10v/2)---> brown
Locked
