6R 1.6TDI 90HP CAYB 2009
Re: 6R 1.6TDI 90HP CAYB 2009
I'm
, patience.
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680
Component: RNS-MID H04 2760
Revision: AB001001 Serial number: VWZ6Z7K1978363
Coding: 0C010240020000A100
Shop #: WSC 00051 261 87199
VCID: 2E53E83379E29E6E36F-807B
It may require firmware updates to fix the RVC problem ... and incidentally you also update the maps.
Downloads
http://gpsunderground.com/forum/car-nav ... eat-skoda/
Read and carefully study the updates for your specific model of RNS510, I cannot advise you better than what is written in this website.
By the way, an excellent web page.
You can also access to the hidden menu in SETUP (Adaptation, channel 50, 0-->1)
Search on google and youtube, a lot of information available...
Downloads
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: RE: Re: 6R 1.6TDI 90HP CAYB 2009
I will do the firmware update to see if it resolves .ciclo wrote:------------------------------------
It may require firmware updates to fix the RVC problem ... and incidentally you also update the maps.![]()
Downloadshttp://gpsunderground.com/forum/car-nav ... eat-skoda/
By the way, an excellent web page.![]()
Thank you friend. [emoji106] [emoji4]
- Ugabista
Help...[emoji30]
I tried to install the Firmware modified 5238 and 4020 but gave error near the end ( Gateway error-202) , now the radio starts and does not work , is asking to install the software. What is this error and it will give ? What can I do? [emoji47]
Do an software reset with DVD to avoid canbus errors:
http://www.my-gti.com/1986/volkswagen-r ... t-problems
- Ugabista
Thanks iichel [emoji4]iichel wrote:Do an software reset with DVD to avoid canbus errors:
I was in doubt , he recorded this file and insert the radio and restart or the firmware?
I think its a fix to the current firmware on your device, to fix the error. Then it is allow to update to a new version, where this error is no longer present.
- Ugabista
Ok, i will be try and then tell the result. Thanks [emoji106]iichel wrote:I think its a fix to the current firmware on your device, to fix the error. Then it is allow to update to a new version, where this error is no longer present.
- Ugabista
Resulted friends!iichel wrote:Do an software reset with DVD to avoid canbus errors:
I've got the radio working well and the firmware update (5238 and assigns the letter L) solved the problem of camera RVC. Also installed V12 map.
You are brilliant!!
Thank you so much to both.
- CNK
- Drives: 6R
Now there are already V13 mapsUgabista wrote: I've got the radio working well and the firmware update (5238 and assigns the letter L) solved the problem of camera RVC. Also installed V12 map.
- Ugabista
Yes, soon [emoji4]CNK wrote:Now there are already V13 mapsUgabista wrote: I've got the radio working well and the firmware update (5238 and assigns the letter L) solved the problem of camera RVC. Also installed V12 map.
I have the same problem in my car. I have the 16372 fault code with the same issue and the value of the temperature of A/C Panel (G56) is -51 ºC...do you resolved it?Ugabista wrote:Okay, tomorrow I will have to make this direct link.ciclo wrote:All you have to do is add directly a wire from pin 7 connector 12-pin to the wire "positive audio" mic before the bluetooth phone unit.
Easier (plug and play) is to buy CARSYSTEM wiring.
When can i order this KIT: http://www.carsystems.pl/vw-bluetooth-k ... id886.html
Thank you very much.
Regarding the error I have in Climatic (08), was to do some more tests and I came across this discrepancy in values in the third frame, will be normal?
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 306FF64B63D6889E243-8065
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 31090 km
Time Indication: 0
Date: 2013.14.04
Time: 21:04:20
Part No SW: 6R0 820 045 A HW: 6R0 820 045 A
Component: Climatic 23 0500
Revision: 00 09 23
VCID: 2C57E23B4FFEEC7E18B-8079
1 Fault Found:
014 - Defective
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 27123 km
Time Indication: 0
Date: 2036.14.14
Time: 16:33:02
- Ugabista
Yes, the same problem.
Not yet solved the problem. It works well but has the bug, I think just changing the panel or sensor...
I had bougth the car with 83000 km and the error happened with 27000 and the car works very well and I think the fault is a bug or bad value of these sensor, how you say me.Ugabista wrote:Yes, the same problem.
Sometimes, the compressor of the A/C makes a little bit strange sounds, but when turn on the A/C, the sounds disappears. I dont know if the error is related with this.
Thanks for the reply.
- Ugabista
The error does not erase with VCDs. Here no one could help me with this ... the ideal would try another panel to see if solve the problem before spending money on buying another...rasnicop wrote:I had bougth the car with 83000 km and the error happened with 27000 and the car works very well and I think the fault is a bug or bad value of these sensor, how you say me.Ugabista wrote:Yes, the same problem.
