UK-POLOS.NET - THE VW Polo Forum • retrofitting kessy to the Polo 6R - Page 9
Page 9 of 9
Re: retrofitting kessy to the Polo 6R
Posted: Sat Oct 21, 2023 9:04 pm
by MrCollayder
Krafeuss wrote: Fri Oct 20, 2023 3:57 pm Hi all
Thanks for sharing experiences on this retrofit.
From my side, I retrofitted Kessy on Golf 6. Immo is learnt, ELV, kessy and key are ok.
But ELV doesn't engage. It doesn't lock steering wheel.
Coding and adaptation channels of the 05 start/stop authentication, 09 central electrics and 25 immobiliser have been checked with a working kessy car.
No differences found there.
I don't have defaults with VCDS.
Do you have an idea ?
thanks
Hi! Please, check in the measurements of ELV parking status. If ELV don't see parking, it won't block the steering column. AND! Pq35 don't need T16/14 wire from the selector. P-status is translating via can.
Posted: Fri Nov 10, 2023 6:44 am
by spacewalker
MrCollayder wrote: Sat Oct 21, 2023 9:04 pm
no , is not right
I have it in my c ar , with hand brake
no matter if I use it or not
ELV just need see door open to lock it after ignition off
is like S-contact off
when you do ign OFF , and keep driver door lock - radio still working
but when you open driver door - radio go OFF and ELV is lock
Posted: Mon Nov 20, 2023 11:15 am
by MrCollayder
spacewalker wrote: Fri Nov 10, 2023 6:44 am no , is not right
I had a problem with this wire. There was GND always (selector's fault), so elv didn't lock at all and the bcm didn't react to the closing signal in any way. I removed this wire and only after that elv has started work correctly as you described. But after every "ignition off" elv detects fault "incorrect signal from the selector". If I put this wire back again, there won't any faults in the elv, but it won't lock after ign off and opening driver's door. And I really was surprised when found no wire in jetta's AW1 elsa scheme. Is it only for pq25 or not? I didn't understand it.
Posted: Tue Nov 21, 2023 7:46 am
by spacewalker
MrCollayder wrote: Mon Nov 20, 2023 11:15 am
but it show error about selector
so it was a point to look
Posted: Sun Feb 09, 2025 2:56 pm
by Siddhants127
Hi guys I was looking around to retrofit push start system and i found 1 kit on aliexpress. Just wanted to know should i give it a shot? Has anyone done this before? The seller says i need to just solder me old remote key to his module and connect loc/unlock wire and brake line connector to make it work. A little skeptical about it. I have polo 2021 Gt tsi 6r.
Thanks in advance
Posted: Sun Jun 07, 2026 5:19 pm
by sejuani
I have also successfully completed KESSY retrofit on my POLO.
The system is working properly, and I can lock, unlock, and start the vehicle without any issues.
To prepare for the next stage of my retrofit project (installing the A5 camera), I upgraded my BCM from 7E0 937 090 C to 7E0 937 090 E by flashing.
However, after the firmware upgrade, the remote key fob could no longer lock or unlock the vehicle. At the moment, I can only lock and unlock the doors using the mechanical key.
I have heard a theory that the EEPROM data structure used for remote key information in the E-version BCM differs from that of the C-version BCM (possibly due to different EEPROM addresses or storage logic). As a result, the keys may need to be paired again using VVDI2.
Has anyone encountered a similar issue or found a solution?
Posted: Mon Jun 08, 2026 6:06 pm
by ciclo
Without Kessy, the problem you're experiencing when flashing to E doesn't exist, the remotes pair without issues...
Posted: Wed Jun 10, 2026 4:16 pm
by sejuani
After installing KESSY, I am no longer able to pair the remote keys via Adaptation.
Perhaps the only solution is to re-pair the remote keys using VVDI2.
Posted: Fri Jun 12, 2026 3:43 pm
by Shadow109
Yes, you only need re pair the keys using vvid2, some of the key data is stored in bcm, when flashing the bcm all the data will be removed
Posted: Wed Jun 24, 2026 3:07 am
by sejuani
I finally managed to solve the issue.
After configuring the A5 camera on the 090 E BCM—including the long coding, adaptations, and calibration—and verifying that everything worked correctly during real-world driving, I downgraded the BCM back to 090 C.
To my surprise, the 2QD (Address 44) was still able to communicate properly with the 3Q0 A5 camera. As a result, there is no need to pair the remote keys again using VVDI2.
However, if any future A5 camera settings need to be changed, the BCM will have to be upgraded back to 090 E first.
Posted: Wed Jun 24, 2026 7:15 pm
by ciclo
8)
Acceptable discrepancies. :)
