BCM High to BCM Max, AFS, LED Headlights and HBA
federicodrdpro
Drives: White Polo 6R TDI
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Post by federicodrdpro »
ciclo wrote: Thu Mar 22, 2018 9:04 pm0728DD
Rain closing work only with car unlocked with this coding: 0728DD
I have not plugged the Auto lights yet, because I am waiting to receive the 4CARMEDIA 331442 connector. :|
With the new BCM coding doesn't appear the lamp check when I flashing with the high beam and they work fine now!
Those are your 'final' codings for this project.
Set the comfort function again in all WRMs. However, the software of your WRMs also influences the Rain Closing function.
Finish the wiring installation correctly.
federicodrdpro
Today I plugged the Auto lights wiring with the new Stalk (7E0953507B) for HBA.
Auto lights work fine but I have some errors from steering angle: :|
Saturday,24,March,2018,20:30:36:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 20 25 44 55 0B
VIN: WVWZZZ6RZCY020628   Mileage: 86280km-53611miles
04-Steering Angle -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C089086461C76E19-8030
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416F00B2842B14E482D900421700
   Shop #: WSC 00788 648 00255
   VCID: 071CA380B22D357ECB-8052
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 102
                    Mileage: 86285 km
                    Time Indication: 0
                    Date: 2012.08.14
                    Time: 00:00:01
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x12AE
                    Hex Value: 0x1B9A
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 128171814
   Coding: 3CB02BBF48E3260093380E906CEF9ED05A88732F608530C0200000030800
   Shop #: WSC 18752 008 00032
   VCID: 2B543F304A05311E0F-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 060215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU030051100011446
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU025051100015419
   Coding: 08BC30
   Component: LIN BACKUP HO  H03 1301
   Subsystem 7 - Part No SW: K8 951 171 A    HW: K89 511 71A
   Serial number: ÿK8951171A  °103
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027051100012627
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU027051100013292
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NWXFQ
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40550INGS999T
   Serial number: 3585HRB40570INGSBHPF
   Serial number: 3515RRB40510JNPM7P50
   Serial number: 3525RRB404P0K4DOA8O1
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A7A0A74BD5F989684-806E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68DE803C9B73DA0622-803C
1 Fault Found:
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 102
                    Mileage: 86285 km
                    Time Indication: 0
                    Date: 2012.08.14
                    Time: 00:16:43
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 040400E200000000000000
   Shop #: WSC 34948 001 1048576
   ROD: N/A
   VCID: 2E5236247117443628-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H03 0505
   Serial number:
   VCID: 6ADAFA348D7FE81634-803E
   Part No: 6R0 423 156 B
   Coding: 11210
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
1 Fault Found:
            49-00 - No Communications
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77FCD340CECD45FEBB-8022
1 Fault Found:
13705474 - Databus
          U1121 00 [137] - Missing Message
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 102
                    Mileage: 86285 km
                    Date: 2018.03.24
                    Time: 00:16:41
End-------------------------(Elapsed Time: 03:25)--------------------------
My 279.948 Steering Angle doesn't fit perfectly on new 7E0953507B Stalk. :?
Install this 6R0959654
Do the G85 basic setting in Address 03.
:lol: -->' :? '--->Image
federicodrdpro
ciclo wrote: Sat Mar 24, 2018 9:06 pm Install this 6R0959654
Ok! :)
I modified a "plastic channel" of the stalk to fit my ring on it. But I don't understand why my ring doesn't work like with the old stalk.
I think I'll install the old stalk while I wait the new ring.
ciclo wrote: Sat Mar 24, 2018 9:06 pm ..
I can't because the stalk with the ring are on my desk. :lol:
P.S. Fog lights doesn't work, the wiring is not complete.
EDIT:
I installed the old stalk. This is the last Autoscan:
Sunday,25,March,2018,00:49:57:00001
www.Ross-Tech.com
   Revision: --------
1 Fault Found:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 12
                    Reset counter: 142
                    Mileage: 86285 km
                    Time Indication: 0
                    Date: 2012.08.15
                    Time: 00:00:01
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x12AE
                    Hex Value: 0x1B9A
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
   Revision: 0002S 02
   Coding: 0728DD
   Coding: 18BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003232
   Coding: 140A01
   Revision: B9082001
   Coding: 002200
   Revision: AA001001
   ROD: N/A
   Serial number:
   Coding: 11210
   Shop #: WSC 00788
1 Fault Found:
            49-10 - No Communications - Intermittent
End-------------------------(Elapsed Time: 03:21)--------------------------
P.S. Rain closing continue to work only with car Unlocked
I'm afraid you've broken your steering ring (internal wires) when you turned your steering wheel the first time once installed... CRACK! (sound :mrgreen:)...
It's just a guess... i'm not a fortune teller. 008 - Implausible Signal - Intermittent
Image :lol:
Did you take into account the central position of ring-internal wires/T12 connector/steering wheel/etc, i.e, same quantity of turns to each side?
I mean to this:
(new model of ring, not like yours, but they are built in the same way)
federicodrdpro
Yes, I think it is broken, but I didn't hear any "crack". :shock:
I can't read my ring because it is not possible. I blocked it when I got off the steering wheel.
Now I buy a new ring.
I need a 4H0951253A Relay for the fog lights. Which is the Part Number of the Relay support?
EDIT:
HBA work without MFA+! 8) but I have lamp check on IC and sometimes the left low beam go off and don't come to on until I switch off the car.
federicodrdpro
I installed 6R0959654 ring but I have to calibrate the new ring:
In Module 03 ABS -> Basic Settings, I can't do nothing.
In Steering angle -> Basic Settings, I can do this settings but I need the Security Access.
Which is the right way to calibrate the ring?
Last edited by federicodrdpro on Sat Apr 07, 2018 1:54 pm, edited 1 time in total.
ignition on
steering wheel centered
connect vcds
03 ABS
security access
40168
basis settings
steering angle sensor: carry out zero calibration
then you should be fine.
federicodrdpro
Security Access of module 03 accepted. This is the Basic Settings:
"Not OK"
In Steering Angle Module I need another Security Access to calibrate the ring.
you need to calibrate the steering angle sensor in the ABS module.
are the wheels straight? is the steering wheel centered? you're now in the measurement blocks?
federicodrdpro
Ok, I have calibrated the steering angle sensor in the ABS module. Thanks Michel :)
There's another error that appear when I flashing with High Beam:
And when I use HBA sometimes left or right low beam turn off for a second and then turn on again. :roll:
P.S. Fog Lights works perfect. :wink:
Install the correct parts in the correct way to solve your problems. Thank you. :mrgreen:
federicodrdpro
I followed your HBA scheme. All work but I have Lamp check when I flash with the High Beam. Only when I active the Light assist the low Beam left or right turn off for a second and then turn on again.
Yes, both firegrafik and myself, we experienced this problem.
For me, it has disappeared but I didn't change anything.
