Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
You can do it (after the relay), but it doesn't make sense (IMHO), the washer jet heater elements operate automatically.
I think it's better if you connect them with signal +15 - SB15 - (factory way).
Yes you can. But why not simply use ignition? They hardly use any electricity in high temperatures.
Edit: I agree with what is written above.
favi
Drives: 6R
Post by favi »
Thank you for answer,
I will do it by connect to the signal +15 - SB15 - (factory way).
favi
Drives: 6R
Post by favi »
Mirror arrived
favi
Drives: 6R
Post by favi »
ciclo wrote: Wed Apr 21, 2021 3:22 am I do not know how your front fog lights are currently installed (due to the installation of the LED headlights), but if they are powered by the BCM (with SCLs), the relay dedicated to the fog lights in the automatic lights wiring is not necessary either (the signal-wire to BCM pin 7a is still necessary).
If an ocean of doubts arises in your mind regarding wiring, keep asking here ... :)
My front fog lights are factory wired. I didn't change anything.
If your front fog lights have the static cornering light function, the original/factory wiring is correct in combination with "6C/6R LED Headlights" (and HBA).
This type of electrical installation for the front fog lights is managed by the BCM. Front fog light activation signal is sent from light switch pin T17/8 (or new connector T10/5 -->T10/3 red connector -->) to BCM T73a/7.
In this case it would not be necessary to modify the electrical installation for the front fog lights, although it depends on what you have done in your wiring upgrades for BCM Max, Automatic lights, and finally this new wiring adaptation for HBA.
In any case, it would have an easy solution in case of failures.
favi
Drives: 6R
Post by favi »
ciclo wrote: Sat Feb 25, 2023 4:16 am what you have done in your wiring upgrades for BCM Max, Automatic lights
I did only this :)
VVV
ciclo wrote: Mon Mar 05, 2018 9:20 pm Hi favi, nice project!
We hope not to disappoint you to make your beautiful red 6R a better car.
I subscribe to your topic ... for support you and share the info. :wink:
The first thing:
How to install a 7E0 BCM Max in 2011 Polo 6R non Bluemotion ‘H7’ halogen headlights (favi).
Preview, 14 pages.
:arrow: Download or watch here the PDF file.
ciclo wrote: Sat Feb 25, 2023 4:16 am If your front fog lights have the static cornering light function, the original/factory wiring is correct in combination with "6C/6R LED Headlights" (and HBA).
Yes, it works perfect
I have question about diode
Witch one i need to buy?
Like that?
Rectifier Diode 1N4007 1000V 1A 10pcs
Current Max : 1A
voltage: 1000V
Housing : DO-41
Yes, 1N4007 will do the job perfectly for the non-dimming mirror function.
favi
Drives: 6R
Post by favi »
So, now i have modification from your .pdf instaling tutorial BCM MAX (auto dimming mirror have too).
- In the area of the anti-dazzle mirror, the reverse signal wire is no longer necessary (if installed), the non-dimming function is performed by the new CAN lines for the HBA mirror.
So:
1. I need make new wrie T6/6 with diode or not ?
2. Can i use old wire T6/1 and T6/2 (ground)?
Yes for both questions, you have to change/remove/cut the Original MQS contact terminals from the T6 connector wires (T6/1 + SB25, T6/2- ground, and isolate T6/3 wire) and install the NEW MCON contact terminals for the new T8 connector (T8/1+ SB25, T8/2- ground, and the new wire T8/6 DGND).
As seen in the above scheme made by ciclo. :)
MQS :arrow: https://www.a4-freunde.com/attachment.p ... 9780&stc=1
MCON :arrow: https://www.a4-freunde.com/attachment.p ... 2108&stc=1
Here the diagram of the original mirror Y7 (T6 connector) for Polo 6R. :arrow: pg4 https://drive.google.com/file/d/0B2nv91 ... lbAQ4oVzwg
favi
Drives: 6R
Post by favi »
I made a wiring from interior mirror and camera.
I have BCM MAX.
What's next?
You wrote earlier that
ciclo wrote: Wed Apr 21, 2021 3:22 am No more than other retrofits. :lol:
Things to keep in mind in your current wiring:
- The two high beams (HB) must be connected to the BCM. (PINs 1a, 1b) - 1a and 1b to T14/11 LED ?
- The 7E0 Stalks - BCM wiring, :arrow: the four wires, 38, 39, 40, 41. - ?
- CAN lines for HBA, connected to the New CAN lines for the instrument cluster. - DID
- In the area of the anti-dazzle mirror, the reverse signal wire is no longer necessary (if installed), the non-dimming function is performed by the new CAN lines for the HBA mirror. - DID
- The relay for automatic lights is no longer necessary. (function by coding)
Easy,
from this:
to this:
https://drive.google.com/file/d/0B2nv91 ... B_5OxyUh0Q (ciclo's polo, bixenon)
https://drive.google.com/file/d/0B2nv91 ... 57A3T1S71w (this is how it should be finished in your case + fog lights signal).
I recommend you make a completely new wiring from the red connector (ISO connector 10-pin).
Good luck!
favi
Drives: 6R
Post by favi »
THanks a lot !
favi
Drives: 6R
Post by favi »
Good way?
