Page 9 of 51
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Posted: Sat Aug 08, 2020 3:10 am
by ciclo
MaDwArLoCk wrote: Fri Aug 07, 2020 1:56 pm Perfect, Fernando! 😎👍
It's logical, my new DM unit comes from a different region, so it had different data settings for the languages. Curiously there are many possibilities of data settings for languages.
I also added POIs (speed cameras, etc......) and Logos for radio stations.
My total thanks for your brilliant work, you are a Diamond!💎
We'll continue working and amusing ourselves on what remains to be done. :lol:
Super happy that everything works like a charm! 8)
Posted: Sun Aug 09, 2020 7:21 pm
by ciclo
Golf 7.5 From Basic BCM 5Q0937084DA to High BCM 5Q0937084DD
Process:
1- Make a backup of coding and adaptations from BCM to remove, install the new BCM and load/transfer the backup.
I recommend doing this process with VCDS, the transfer is 1 to 1, that is 100%. 💌
2- Remove CP, adjust immobilizer (key mode 1-2, 2-2) and load Dataset with ODIS-S online.
If you know the speed of light, we could say that the speed at which ODIS-S works is approximately the speed of water... 😂
My deepest thanks to Madwarlock for making this process very enjoyable and fun.
3- Check that everything works correctly.
It's necessary to restore the factory settings for the lights in the 5F infotainment system (the customization that we made over time in the adaptation channels) and check all our settings in all menus.
It's also necessary to redo all the customization processes for each key-remote, such as the adjustment of the passenger rear view mirror for the tilt down mirror function when parking (user manual), etc... I assume it will be the same for the other functions that are assigned to each key-remote individually (electric seats).
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 00001822001136
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 7DA704882D768583395-8028
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY18M08D06H04M32S34
Coding: 00A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
Sunday,09,August,2020,13:14:53:32438
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4526.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: BCM HIGH OK!
Mileage: 32730km-20337mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW   Mileage: 32730km-20337miles
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032232415082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92325D-807C
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733020F0084002430B00000012121212B835351919323200
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DB78F-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005004000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6C8139CC460C1C0B9EB-8038
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 00A8DD
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018193
   Coding: 0471151001
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4CC1994C264CFC0BFEB-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00600111FFC728949C810500400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C344B36B-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92305D-805C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 740 D    HW: 5G1 920 740 D
   Component: KOMBI         211 2500
   Coding: 07A52A802280000801887A051401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 270B06E09F6AFF53339-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 14071810801894
   Coding: 030100047F085700DA000258080F00010001070000000000000000000000
   Shop #: WSC 00046 028 00068
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D27C4886DF64583795-8068
   Alternator:
   Component: 1-01-02-01-04
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001255750088264
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0404000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B33971-803E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150320D000048000001000
   Shop #: WSC 00020 999 12345
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 48C9A55C3234102BDA3-801C
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F35F1-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 47CBA6603F2A1F53D39-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000005111010100880A001F0500D401200100CF
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323DE7B4A4A88AFB947-8066
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data medium:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CB86B-8060
End----------(Elapsed Time: 01:17, VBatt start/end: 14.2V/12.9V)-----------
Works like a charm! 8)
Now I can add colored lights, heated seats, etc ...
Posted: Tue Aug 11, 2020 12:45 am
by ciclo
Golf 7.5 ACC MFSW buttons
Two posibilities.
- AB for factory steering wheel.
- AE for Sport steering wheel.
GW
Autocoding
2CFFFF
Posted: Tue Aug 11, 2020 2:13 pm
by dcgumis
great job :):) ACC nice thing :D
Posted: Tue Aug 11, 2020 9:36 pm
by ciclo
It depends.
Some have doubts (R), and I agree with them.
https://www.youtube.com/watch?v=DH8ARsI5itc[/youtube]
The most important part of the video question is:
Can you ....? :lol:
However the ACC of/on my Touareg R-line 2019 is perfect!.
Posted: Tue Aug 11, 2020 11:15 pm
by exantas
VW ACC can get even worst. In newer cars with traffic sign recognition, ACC can automatically set the speed you go according to the signs.
Until the car camera picks up the sign from a side road or a the speed limit on an exit lane that you are not on. And in that case although you have set it to 80km it suddenly goes to 50 for example. At least you can disable this option and it stays this way after you restart the car (unlike the lane assist the gets enable by default when you restart the car)
Posted: Wed Aug 12, 2020 1:42 am
by ciclo
exantas wrote: Tue Aug 11, 2020 11:15 pm Can you @ciclo? What you are not telling us? :)
I think it is quite simple if you have understood what was expressed in the video question.
That someone is able to find the possibility of making it possible.
Go from ACC to CCS!
exantas wrote: Tue Aug 11, 2020 11:15 pm I hope your new VWs get a thread on their own here, after you have enjoyed them for some time first of course :P
Thank you!
I recommend everyone to do the same, that is, open a new personal thread to share there your experiences and information with others.
(images of your cars, retrofits, scans, diagnostics, solutions, etc)... :wink:
Posted: Wed Aug 12, 2020 5:40 am
by ciclo
Golf 7.5 Footwell lights with ambient lights function (x4)
Well, this was maybe the first retrofit I did on my wife's Golf.
In the same way as explained in this video:
https://www.youtube.com/watch?v=XTiLrowY7Z0 👌
(part 1 & part 2)
But the adaptation shown in the video description did not work for my wife's Golf 7.5 despite searching and testing additional information.
I had to do it this way:
-OEM Footwell lights + Ambient lights mode (2 front + 2 rear ... Ref: 5G0947409)
 Address 09, SECURITY ACCESS--> 31347
 Adaptation
 Leuchte30FR LC72-Lasttyp 30,not active ,16 (36-LED Kleinleistung)
 Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16 (02)
 Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16 (Always)
 Leuchte30FR LC72-Lichtfunktion A 30,not active ,16 (Footwell Light)
 Leuchte30FR LC72-Lichtfunktion B 30 ,16 (Terminal 58xs dimmer) -power supply for ambient lights function.
 Leuchte30FR LC72-Lichtfunktion C 30 ,16 (Interior Light) -power supply for footwell lights function.
 Leuchte30FR LC72-Dimmwert AB 30,0 ,16 (100) ambient lights mode  (if "127" = full brightness 😁, but is not possible dimming the ambient lights with insturment cluster menu)
 Leuchte30FR LC72-Dimmwert CD 30,0 ,16 (100) footwell lights
In this way the menu for footwell lights is not available to increase or decrease the brightness as ambient lights, however this is done with the menu for the instrument cluster / switch lights.
The multi-color footwell ambient lights at another time. :wink:
edit (13/03/2021 -DD/MM/YY-)
UPDATE!
Ok, checking some codings for my multi-color ambient lights I have found this thread:
https://www.golfmk7.com/forums/index.ph ... st-7496915
I post it here in case someone wants to install the white LED lights with the 'specific menu' to adjust/set the brightness for footwell lights.
Wired to C72 and ground.
Performed this coding:
Adaption Channel:	From:	To:
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	not installed	installed
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0	0.2
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	0	70%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	0	70%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	0	70%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	0	70%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	0	70%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	0	70%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	0	127%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	0	126%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	0	127%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	0	126%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	0	70%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	0	70%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	0	70%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	0	70%
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	0	89
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	0	2
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	not active	36 - LED Kleinleistung
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	not active	Footwell light
This completely worked for me and allows for HMI dimming adjustment.
Posted: Thu Aug 13, 2020 4:03 am
by ciclo
ACC buttons installation on non-sport MFSW with CNL buttons.
Use at least three tools to remove the steering wheel Trim as shown in the pictures.
Gradually lift the trim all around with all three tools at the same time at each point. Easy.
CNL (factory)
ACC
Image 8)
Posted: Thu Aug 13, 2020 8:02 pm
by ciclo
Golf 7.5 DRLs Menu.
09
31347
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9 ... active.
DRLs are mandatory, so why activate this menu.
- My reason for activating this menu is due to also being able to disconnect the DRLs when doing long processes of diagnostic or coding with Terminal 15/Ignition switch ON and Engine OFF with all consumers disconnected. (lights, radio-nav, A/C, etc... and DRLs)
Other DRLs deactivation are possible, but...
Posted: Thu Aug 13, 2020 8:52 pm
by ciclo
Golf 7.5 ACC activated. OK! ... (from CCS with Front Assist, Speed ​​limiter, etc)
- In my case, it was only necessary to install the ACC buttons for later activation.
viewtopic.php?f=58&t=72376&start=120#p573788
viewtopic.php?f=58&t=72376&start=120#p573878
One for the daily days and the other for the weekends.😂
- Online activation took about an hour, an "excellent job" of loading data and clearing faults as the flashing process of the involved units progresses.
My deepest thanks to those involved. P/S 🤗👌
Images
I have other installations in progress, so you will see removed trims that are not related to this activation.
- Menus
edit :arrow: viewtopic.php?p=576175#p576175
- 1st Test
:mrgreen:
- End of test
Posted: Sun Aug 16, 2020 6:37 am
by ciclo
Golf 7.5 Windows closing due to rain.
09
31347
Adaptation
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,not active ,8 ... (active)
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art,once ,8 ... (permanent)
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus,not active ,8 ... (active)
RLHS
Coding
Byte0 Bits 1,2 ... enabled
Posted: Sun Aug 16, 2020 7:00 am
by benzinkopf
Spain rainy season now Ciclo?[emoji41]
Posted: Sun Aug 16, 2020 7:39 am
by ciclo
:) No, summer weather.
It's just that I enabled the menu and it's visible in RHLS on the last autoscan I did.
No special reason, it's not due to rain, or garden sprinklers :lol:, or anything like that ...
Posted: Sun Aug 16, 2020 9:14 am
by benzinkopf
anyway great to see updates from you.[emoji1360]
