Page 88 of 333
Posted: Mon Aug 24, 2015 8:48 pm
by Andrea 6r
Perfect, thank you very much for the explanation :D
you always the best 8)
iichel thanks :D
Posted: Mon Aug 24, 2015 10:33 pm
by Spolos
iichel wrote:
But I do not understand why it is not working now. Can you check the fog light coding and cornering lights coding?
I will do it on saturday because i have to work but its strange that After erasing the error it won't come back in VCDS only in my instrument cluster
Spolos
Posted: Mon Aug 24, 2015 11:00 pm
by Rud031
Hi @ciclo
I have a situation.. I am gonna retrofit a light- and rainsensor on my Polo Bluemotion from 2011..
Now i want also automatic light, just the same way you retrofitted yours with an extra cable set.. I understood from @iichel that i need to change the long coding and you could help me with change the coding..
Would/could you like to help me with the coding?
My long coding at this moment is:
23B02BBF08E12400B32809B07D2B1CD1CF80610F7E860041200000000000
I am looking forward for your reply..
Posted: Tue Aug 25, 2015 6:12 am
by ciclo
New coding
23B02BBF08E12400B3280FB07FEB9ED1DF80610F7E862041200000000000
:arrow: http://www.uk-polos.net/view ... 05#p474349
Posted: Tue Aug 25, 2015 6:47 am
by Rud031
ciclo wrote:New coding
Thnx mate! I will save him immediately..
Posted: Tue Aug 25, 2015 8:44 pm
by Spolos
He Guys,
here is the autoscan from my polo:
Tuesday,25,August,2015,20:57:21:54989
VCDS Version: 15.7.0.1
Data version: 20150729
http://www.Ross-Tech.com
Dealer/Shop Name: Frans
Workshop Code: 123 12345 000001
VIN: WVWZZZ6RZCY074060 License Plate: SWENN
Mileage: 43870km-27259mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 69 0B
VIN: WVWZZZ6RZCY074060 Mileage: 43870km-27259miles
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HE HW: 03F 907 309 J
Component: SIMOS10.22H03 5459
Revision: --H03--- Serial number:
Coding: 001900D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070HE 004007
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6CDC0C97875D3A5E9A-8038
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3217400B6842514E884D100401300
VCID: 0716533BB2FBF90617-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 3260D2EF6DF9ACAE90-8066
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 300110496
Coding: 3AB02BB808A1000000300E406C6B0CD800C0602F60840040200000000000
Shop #: WSC 12345 123 00001
VCID: 3972E5C3B08F5FF651-806C
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 00BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
1 Fault Found:
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 129
Mileage: 43666 km
Time Indication: 0
Date: 2015.08.21
Time: 12:31:49
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00UBW3%
Coding: 003232
ROD: N/A
VCID: 4A90AA0FED69C46EC8-801E
Subsystem 1 - Serial number: 3575HRB40570NI361OGA
Subsystem 2 - Serial number: 3585HRB40570NI3690H$
Subsystem 3 - Serial number: 3515RRB405F0MFP6BGM5
Subsystem 4 - Serial number: 3525RRB405V0N49OKGNO
No ASAM data for: "EV_AirbaVW10BPAVW250" (VW26)
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3972E5C3B88F5FF651-806C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0251
Revision: BS050001
Coding: 002200
VCID: 70E418E7A375DEBEA6-8024
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AD00A8F8DA9246EE8-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660732081
Coding: 010000
VCID: 29523583402FEF7621-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 C HW: 3C0 035 279 C
Component: RNS315-EU H34 0263
Serial number: VWZAZ2L3824510
Coding: 040004110200000000000001
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 234E27AB2A0335266B-8076
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0031 0031
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11240
Shop #: WSC 12345
VCID: 2F66DB9BEACB8146FF-807A
Address 69: Trailer Labels: RETROFIT69.lbl
Part No SW: SW0 408 HW: 5F0 07V 010 1
Component: TOWBARMODULE ECS 0010
Coding: 0000001
VCID: 76E82EFF0111F08E7C-8022
End-------------------------(Elapsed Time: 02:37)--------------------------
i hope you can help me
Posted: Wed Aug 26, 2015 1:31 pm
by ciclo
New BCM 089F does not detect reverse light wire. FYI white connector T73b/12. Your car not have this wire from factory, like Polo 6R with factory xenon or BlueMotion.
It works in your car due to it have direct power supply from reverse light switch.
Try these codings, for now they should solve the problem of reversing light (but this is a trick, is not the real solution). They are also an attempt to make your fog lights with cornering light working correctly. But until you properly connect the wiring it does not make much sense.
1st
3AB02BB808A1000000300E006C6B0CD800C0602F60840040200000000000
2nd
3AB02BB808A1000000300E006C6B0CD800C0612F60840040200000000000
3rd
3AB02BB808A1000000300E006C6B0CD800C0612F60840040200000010000
Tell us the results.
When you install the original xenon headlights you should migrate your current fog lights wiring to static cornering lights (on xenon), and make new wiring from Light switch--->fuse SB54---> up to foglights.
Posted: Wed Aug 26, 2015 6:24 pm
by Andrea 6r
ciclo wrote:Image
For you to try, as I told is a present. Both are new, without use.
I send you mp with my address ;)
Posted: Wed Aug 26, 2015 8:07 pm
by ciclo
Andrea6R, look at your inbox. :wink:
Posted: Thu Aug 27, 2015 3:12 pm
by ciclo
Reversing light
Your Polo.
Xenon factory or bluemotion.
Why all this? Because you said you wanted to install dimming mirror.
There are also other settings for automatic or DSG, they have no reverse light switch. Only T73b/12.
Posted: Sun Aug 30, 2015 11:38 am
by gpeixoto109
Hello Ciclo!
I found this steering wheel from the new polo 6c that has buttons for cruise control, radio and MFA, can I install it in polo 6R, and use it for cruise control instead of buying the stalks you said?
Thank you!
Posted: Sun Aug 30, 2015 2:18 pm
by ciclo
Hi gpeixoto109
No. The cruise control systems are very different, you have to find a steering wheel without buttons for cruise control. :wink:
Posted: Sun Aug 30, 2015 3:25 pm
by ciclo
During the months of September and October I'll post some very interesting mods, so in the TOPIC ciclo's Polo just questions about these new mods.
Therefore:
- If you've been redirected to this post, "please" open a new topic in the forum and I'll be glad to help.
- If I don't answer in your new topic, you can warn me (via link) about your questions.
"Thank you very much to all for your understanding"
Image :lol:
Except: Administrators, moderators, ... and everyone who they have my email.
Posted: Tue Sep 01, 2015 12:28 am
by ciclo
I have one full kit automatic lights Polo 6R for sale. :arrow: http://www.uk-polos.net/view ... 41#p498999
Posted: Wed Sep 02, 2015 7:57 pm
by Vwdavid
ciclo, i'm so sorry... i can't send you a PM...
i have a question about the cruise control. with a BCM PQ25 of a vw polo 6r (6R0937086K) it's possible to install?
