Page 10 of 333
Posted: Thu Dec 12, 2013 4:48 am
by Mart!n-GTI-DK
Start/stop is not involved in any way... ???
Posted: Thu Dec 12, 2013 9:07 am
by ciclo
matti wrote:ciclo wrote:matti, I have not the Kufatec wiring.
I did my wiring and now I'm going to redo as you see in the diagram.
How is your wiring different from Kufatec?
Also, what is causing the rear foglight issue? How is start-stop involved in this mess?
I do not know what are the differences. I do not know Kufatec wiring diagram. In my thread I do not want discuss the issue Kufatec wiring.
The only thing I can say is that the original wiring light switch vw polo BlueGT (for example) is exactly like mine.
With the diagram I posted all the lights work perfectly on my vw polo r-line.
Obviously the BlueGT has no wiring for fog lights as standard.
My vw polo r-line has standard fog lights and its wiring is exactly like the two diagrams that I posted below.
That's all I can say with absolute certainty.
matti, your first post are several questions in my thread ... nothing happens
... but, you can present your vw polo in forum? so it's easier for everyone.
Posted: Thu Dec 12, 2013 6:36 pm
by joelburbidge
ciclo wrote:
just finished changing the wiring and re fitted the kit all is working apart from high beam still, i haven't got it bright enough yet to check the auto lights
Posted: Thu Dec 12, 2013 6:47 pm
by Mart!n-GTI-DK
The highbeams is probably a coding issue as it was on mine. Have you changed the number for the highbeams to 58 in VCDS?
Posted: Thu Dec 12, 2013 7:08 pm
by joelburbidge
yes i've tried but no cigar
Posted: Fri Dec 13, 2013 1:52 pm
by ciclo
joelburbidge wrote: just finished changing the wiring and re fitted the kit all is working apart from high beam still, i haven't got it bright enough yet to check the auto lights
You can use a torch to zoom in and out of the sensor to verify that the automatic lights work...
You can adjust the sensitivity of the sensor with the vcds in bytes of RLS.
Posted: Fri Dec 13, 2013 1:57 pm
by Mart!n-GTI-DK
i got the Refuel coded in the MFD like you showed.
And it works great.
But do you know if can only show in 5 litre intervals or if it can changed to 1 litre instead???
Posted: Fri Dec 13, 2013 2:06 pm
by ciclo
Mart!n-GTI-DK wrote:i got the Refuel coded in the MFD like you showed.
And it works great.
It would be good to go every 1 liter. Every 5 liters is very subjective.
I do not know if this parameter can be changed.
Will have to investigate ...
Posted: Fri Dec 13, 2013 2:17 pm
by Mart!n-GTI-DK
ciclo wrote:Mart!n-GTI-DK wrote:i got the Refuel coded in the MFD like you showed.
And it works great.
Sounds good.
Posted: Sat Dec 14, 2013 9:34 am
by ciclo
Posted: Fri Dec 20, 2013 5:20 pm
by Mart!n-GTI-DK
Hola Ciclo.
Have you had a chance to look at the refuel intervals yet?
Posted: Fri Dec 20, 2013 6:16 pm
by ciclo
I have not had time to take a look at the fuel parameters. Guess when these dates have passed (Christmas), now I am very busy.
Did you find out something about it?
*********Glædelig jul!*********
Posted: Fri Dec 20, 2013 6:19 pm
by Mart!n-GTI-DK
ciclo wrote:I have not had time to take a look at the fuel parameters. Guess when these dates have passed (Christmas), now I am very busy.
Nope... I', just waiting on your expertise.
And a ***********Feliz Navidad*********** To you too.
Posted: Sun Dec 22, 2013 2:59 am
by ciclo
Posted: Sat Dec 28, 2013 5:41 am
by ciclo
Long time study the possibility of retrofitting light assist in VW POLO, but do not know how to activate (20) high beam assist in the gateway with vcds. Then, also should be selected its activation in the BCM.
Our gateway is integrated into the BCM, except Vw Polo with start/stop system that have a separate gateway.
Is necessary to have leveling unit lights, automatic lights, dimming mirror with camera ...
On the other hand I do not know if the lights stalk is valid. I believe not.
Must be use the CAN line (adding two cables), this is easy.
Examples (examples only and not use as a guide)
http://www.briskoda.net/forums/topic/29 ... assistent/
http://www.audizine.com/forum/showthrea ... eam-ASSIST
http://www.motor-talk.de/blogs/miwi-s-b ... 37432.html
Any help is welcome and greatly appreciated.
