Ok...we are in contact if there is any news...Ugabista wrote:The error does not erase with VCDs. Here no one could help me with this ... the ideal would try another panel to see if solve the problem before spending money on buying another...rasnicop wrote:I had bougth the car with 83000 km and the error happened with 27000 and the car works very well and I think the fault is a bug or bad value of these sensor, how you say me.Ugabista wrote:Yes, the same problem.
Not yet solved the problem. It works well but has the bug, I think just changing the panel or sensor...
Sometimes, the compressor of the A/C makes a little bit strange sounds, but when turn on the A/C, the sounds disappears. I dont know if the error is related with this.
Thanks for the reply.
6R 1.6TDI 90HP CAYB 2009
Re: RE: Re: 6R 1.6TDI 90HP CAYB 2009
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: RE: Re: RE: Re: 6R 1.6TDI 90HP CAYB 2009
Ok, thanks friend [emoji106]rasnicop wrote:Ok...we are in contact if there is any news...Ugabista wrote:The error does not erase with VCDs. Here no one could help me with this ... the ideal would try another panel to see if solve the problem before spending money on buying another...rasnicop wrote:
- Ugabista
Hi guys, the instrument cluster 6C0920740C give in my Polo? Thanks for any help [emoji4]
No that will not function
- Ugabista
Ok, thanks dear iichel [emoji106]iichel wrote:No that will not function
That's a cool mod
Very interesting your "individual" concept for interior lighting. Good job.
It is advisable to use led bulbs, especially for those that are located under the seats.
You can use the 'door close' wire from the T28 connector to operate a relay (door close = GND, door open = open contact).
This is how I operate the warning lights in my doors and 'entrance' lights. It is now also operating the footwell lights.
Remember that every door has a different wire color and position. Measure or check the wiring schedule accordingly!
- Ugabista
Thanks friend @Ciclo [emoji4]
Halogen lamps do not give great light, but the photos also do not help much, in my opinion is enough brightness, besides I do not appreciate the cold color of the led to an interior.
Some more photos of the process.
- Ugabista
It's a good alternative yes, friend @iichel [emoji4]
Photos dont work
- Ugabista
I can see on phone and PC. Links Photobucket.
