UK-POLOS.NET - THE VW Polo Forum • 6R Cruise Control Retrofit Problems - Page 10
Page 10 of 41
Posted: Wed Sep 28, 2016 5:07 am
by ciclo
Valgas6R wrote:Hello . I have a problem. I bought a car from Germany and the car is the cruise control lever No. 6Q0 953 503 EJ and driver BCM 7H0 937 089F.
The VCDS is all encrypted.
Cruise control does not work and wipers at the first race.
Where to start .
What to look for.
Please help
The engine 1.6 TDI
Production Year 2012
We are asking for help.
viewtopic.php?f=56&t=68862&p=513901#p513901
Posted: Fri Jan 20, 2017 1:14 pm
by S0K0L
Hi all,
I'm new on this forum, so sorry if my question is on wrong place :/
I want to install on my Polo 6R Cruse Control (CCS) and Trip computer.
I found here http://www.cum-cartec-shop.de/product_i ... dropdown=1
stalks which by description fits to my BCM (6R0 937 087 D) for Trip Computer i need take With MFA which is +10€, but what means "Nachrusten +25€"?
My VIN number is: WVWZZZ6RZAY104383 so any suggestion's are welcome! :)
Another question is, is possible to install this to standard cluster which looks like this on my polo? Image
In this set for Stalks I will probably need wires for Trip Computer? What else will need to buy?
Thank you for your answers! :)
Posted: Fri Jan 20, 2017 2:14 pm
by iichel
It would be good to send us a VCDS autoscan. Some BCMs don't support the CCS function.
Apart from installing the wiring, you'll need to install the stalks of course and edit some coding with VCDS.
Posted: Sat Jan 21, 2017 12:39 am
by JIC Cracked
Hi S0K0L 8)
If your looking for cruise control kit for your 6R, I have one available in the sale selection.
viewtopic.php?f=62&t=69168
If your interested I will do a good price for you :wink:
Posted: Sat Jan 21, 2017 2:11 pm
by S0K0L
Hi JIC Cracked! :)
Can you tell me what is included in this kit? :) Is only Cruise control or also with Trip Computer? :)
Do you have harness for Trip Computer? Or these are already fit in car?
Sry for so many questions, I want to know what do I need everything for complete installing Cruise control and Trip Computer and either will this work with Cluster which I have in car :/
Thank you for answers! :)
Posted: Sat Jan 21, 2017 4:18 pm
by ciclo
Autoscan.
Posted: Sat Jan 21, 2017 4:24 pm
by JIC Cracked
Hi S0K0L :)
As Ciclo said a full autoscan will help :wink:
This is in the kit as followed:
Comes with Used Stalk, Slip Ring and Brand New Kufatec CC Wiring.
Kufatec Link Below:
https://www.kufatec.co.uk/shop/en/volks ... ction_ms=1
Once we have a post of you scan, it be easier to figure out which configuration will work best with your car.
Posted: Sat Jan 21, 2017 4:53 pm
by iichel
I think that maybe a question that JIC_Cracked could answer is whether the stalks only have the CCS buttons on the left side or also the MFA buttons on the right side ;)
Posted: Sat Jan 21, 2017 5:15 pm
by JIC Cracked
Maybe this can clear matters :wink:
Posted: Sat Jan 21, 2017 5:16 pm
by S0K0L
0k I'll try to do Autoscan at Monday, what I need to look? :)
Posted: Sat Jan 21, 2017 6:53 pm
by ciclo
Hi S0K0L, Welcome. :wink:
If you want, take some pictures of the current parts that you want to change, also a general picture of the dashboard would be perfect (steering wheel, instrument cluster, stalks, upper buttons to the radio, A/C).
VCDS:
It is important the engine code (ECU), to know the exact slot in ECU connector where you have to install the wire for CCS.
There are two ways to code the ECU. (depending on...)
It is also necessary to code the BCM.
Multifunction Display :arrow: viewtopic.php?f=56&t=65096#p489673 (three wires)
Posted: Sat Jan 21, 2017 7:54 pm
by shockoprinz
Hallo everybody [emoji4]
I have installed ccs in seat toledo 2014 according to the wire diagram of polo 6r as we have same bcm , ecu and almost the same electrical equipments ecu pin connector for ccs was pin 24
Sent from my SM-G935F using Tapatalk
Posted: Sat Jan 21, 2017 9:11 pm
by S0K0L
Hi Ciclo, thank you!
Pictures will be tomorrow!
The car is 1.6TDI 55kW bought on 22.12.2009. Comfortline equipment.
From the aditional equipment it doesn't have almost nothing. Clusters are these on picture few posts above. Manual climate control 'Climatic', radio is RCD210.
Stalks looks like these on picture above but ofcourse without Cruise control and Trip computer buttons.
Upper buttons are for heating trunk glass and flasher button.
BCM number is 6R0937087D
Posted: Sun Jan 22, 2017 8:28 am
by ciclo
So the BCM is ready for the CCS and the Instrument Cluster also is ready for Trip computer.
T94/64 slot in ECU connector for CCS.
So you need:
- Stalks without ring for ESP (you need install on them the one you have), with buttons for CCS and Trip computer. Reference: 6Q0953513AN (it's very important due to 'A' Model Year)
- Wiring for CCS
- Wiring for Trip computer (3 wires)
You will find interesting information on this topic (diagrams, connectors), but when you read it you should keep in mind that there are many 6R versions in reference to its year and place of manufacture.
Useful link (workshop manuals, etc... to removing/installing parts)
Posted: Sun Jan 22, 2017 12:55 pm
by S0K0L
Thank you Ciclo for all explanation! J
So this one will fit ?https://www.kufatec.de/shop/de/volkswag ... ction_ms=1
Modelyear till 2012. Probably I'll need those 3 wires for Trip computer.
