Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
thanks Ciclo! happy holidays and new year!
You're welcome! same for you, happy holidays and very happy new year...
- federicodrdpro
- Drives: White Polo 6R TDI
How is possible to check the regulation of the headlights after Installed the AFS?
Yes with a tester, it is a fast, simple and cheap operation (even free) that most workshops can do.
or https://www.wikihow.com/Adjust-Car-Headlights
golffather
Do you know what the power voltages are to the headlight pins T14/1,2,3,4?iichel wrote: Fri Apr 29, 2016 10:38 am In many countries, auto-leveling of high-brightness lights over 2000 lumens is obligatory.
Personally I think it is a very good thing to do too. Bright Xenon and LED headlights, when not adjusted and regulated properly, can be very annoying.
Be aware, that this is only for the OEM Xenon and OEM LED headlights. It is not for halogen headlights!
This is a topic to help installation, since it is not very difficult.
Material you need:
6R0 941 273 B sensor for the rear axle
6R0 907 357 module for AFS J431
6Q0 612 405 bracket for brake tube, to mount the sensor on.
Mounting position of the AFS module is above the glove box (LHD) or behind the steering wheel (RHD).
You need the bracket (part number to come).
Mounting position of the sensor is under the car.
Take a look where the brake hose has a coupling piece at the rubbers of the rear axle, on the left side.
This coupling piece is also a bracket, where it is connected to the chassis. This bracket needs to be changed for the 6Q0 612 405 bracket.
For this, you need to disconnect the brake hose, shortly. This is dangerous fluid.
You can mount the sensor, heat shield up towards the exhaust, on the new bracket.
The arm of the sensor goes to a mounting point on the rear axle.
The wiring is not so complicated:
CAN powertrain wiring to T26 of the module J431 and wiring from module J431 to sensor G76.
Module is powered by terminal 15, ignition switched power.
Module is connected to T14 of the headlights. It is the same for OEM LED for 6C and OEM Xenon for 6R.
Look in the pictures for J431 (T26, 26 pin connector)
The wiring loom is not difficult to make yourself.
You need 2 connectors:
4E0972726 26 pin connector with micro quadlock system
4B0973712 4 pin connector for sensor with micro power timer
The connectors in the headlight (T14) are all micro power timer.
do not forget to seal the connectors with, for example, 357 972 740 E for the micro power timers.
you will need to seal one hole on the sensor connector which is empty. use 3C0 972 841
VCDS:
enable module 55 (xenon range) in the canbus gateway (module 19)
appropriately code the xenon range module for RLS, start/stop etc.
If everything is wired correctly:
If you start the engine, and low beam is on, you will see the lights go up and down. this is the reference run.
This is an indication that all is wired well.
What does the micro power timer mean?
Trying to adjust the motors manually and seeing what i need to supply the pins with
- CNK
- Drives: 6R
golffather
CNK wrote: Wed Nov 21, 2018 1:09 amMicro Timer - 1,5mm
check https://www.a4-freunde.com/showwiki.php ... zu+gehoert![]()
ah ok thanks! thats the pins themselves.
I just need to know what signal is on these lines.
MicheleMelluso
Hi, and congratulations for the forum.
I have a 2017 VW Polo 6C with halogen headlights. I would like to install the original LED headlights but I don't know if my BCM is compatible. The serial number read through diagnostics is 6C0937089E.
Another question. If I don't install the auto-leveling headlight the dimmer(the one to the right of the light switch) to adjust the headlight height manually works?
Thank you
Thank you
Yes to the first, but no to the second
- sparrow77
- Drives: 2013 1.2TSI BlueMotion 5spd
Sorry, bumping an old thread. I've fitted xenons to my Bluemotion 6R, coded them and everything is working. Next step will be to add ALS, which seems straightforward based on this thread. Because my car has start/stop, I noticed a lot of the places that sell wiring looms for this retrofit mention incompatibility with start/stop.
e.g. https://www.kufatec.com/en/volkswagen/v ... o-6r-37920
"NOT suitable for vehicle with PR-number 7L6, 7L8 (Start/Stop)"
http://vagtec.co.uk/eshop/volkswagen/po ... lo-6r.html
"NOT suitable for vehicle with PR-number 7L8 (Start/Stop)"
It's a lot cheaper to buy the level sensor, bracket and module separately, so I think I'll buy my loom from car-systems, which I've dealt with before: https://www.carsystems.eu/wiring-for-au ... id923.html
This doesn't mention any compatibility issues with Bluemotion. What exactly causes the issues with start/stop? Anything I should be aware of?
FWIW, here's my autoscan from this morning - including working xenons.
Friday,09,April,2021,10:21:05:52359
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY090318 License Plate:
Mileage: 112650km-69997mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 44 56 61
VIN: WVWZZZ6RZDY090318 Mileage: 112650km-69997miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 FJ HW: 03F 907 309 K
Component: SIMOS10.23AH10 4038
Revision: --H10--- Serial number:
Coding: 001100B6202401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070FJ 004007
ROD: EV_ECM12TFS021_VW25.rod
VCID: 6FBBD677B711C403669-803A
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3217600B2842814E384D900501300
VCID: 025D8FC39443D96B997-8056
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 392F282FB9555AB388D-806C
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 251120043
Coding: 3CB02BBF08A1000000300F912A2B0DD05AC0672F7E053041A00000000000
Shop #: WSC 124697 483 00190
VCID: 41DF40CFD1850273C0D-8014
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU011091200011248
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU010091200015821
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU004091200010377
Coding: 58BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU004091200015471
Coding: 58BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361225100949
Coding: 108001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E253B33A0FB7D8BBDF-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01D2R6F
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD67E3EC33C12B117-801E
Serial number: 3575HRB405D1IMPM4GE4
Serial number: 3585HRB405F1IMPMB8OG
Serial number: 3515RRB406919PPQCHLJ
Serial number: 3525RRB405B1AP60BOUZ
Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
Component: KOMBI H05 0605
Coding: 140C01
VCID: 3C21313BB6E76F9B93B-8068
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 E HW: 1K0 907 951
Component: J533 Gateway H38 0041
Revision: H38 Serial number: 130912F2000379
Coding: 2500C2
VCID: 3537241F954DBED36C5-8060
Component: IMMO H05 0605
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A8DC7638CF3212B317-803E
Address 44: Steering Assist Labels: None
VCID: 55F7849F3C4D9ED38C5-8000
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5814
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 16000400040005
Shop #: WSC 127395 840 08317
VCID: 46D553D3F8AB254BF5F-8012
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0041
Coding: 032B7A64
VCID: 74B1D91BDEB7E7DB9BB-8020
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970099393
End----------(Elapsed Time: 01:05, VBatt start/end: 14.9V/14.9V)-----------
Log-WVWZZZ6RZDY090318-112650km-69997mi_loppu.txt
Displaying Log-WVWZZZ6RZDY090318-112650km-69997mi_loppu.txt.- iichel
I think it's a bunch of nonsense, Start/Stop doesn't influence the operation of AFS in any way.
- sparrow77
Thanks for clarifying, iichel.
Another question, sorry for double post:
EDIT: sorry, should have looked at the first page for this very helpful post.
I'm sort of semi-adept at wiring. If I understood this right, from the module J431 there are 8 wires going to the headlights (4 each), three wires to the sensor G76, and then three wires that go... somewhere? Two CAN and one ground? "Module is powered by terminal 15, ignition switched power." Where exactly do I run the two CAN wires? Terminal 15 where? Sorry, just trying to understand.iichel wrote: Fri Apr 29, 2016 10:38 am CAN powertrain wiring to T26 of the module J431 and wiring from module J431 to sensor G76.
The compatibilities have improved over the years (
However,
Address 55: Xenon Range (J431) -Start/Stop function-
sparrow77, any reason to have Byte12 Bit6 disabled in your BCM? ... are SCLs bulbs installed in your bi-xenon headlights?
- sparrow77
I have no idea, unfortunately. I'm not sure if it makes a difference, but my car is an early MY2013 and the xenons are pre 04/2011. Not sure about bulb types.ciclo wrote: Fri Apr 09, 2021 1:45 pm sparrow77, any reason to have Byte12 Bit6 disabled in your BCM? ... are SCLs bulbs installed in your bi-xenon headlights?
This morning we were coding the xenons. I used the binary coding changes indicated in your post, at the bottom here.
Unfortunately for my car, the DRLs weren't working after this. I had a quick peek through the thread (as I was getting help from a local guy and didn't want to use too much of his time, he was doing the coding on his laptop) and saw that someone else had issues the the DRLs (not the same issue exactly). So I decided to try this snippet 2049, and the DRLs started working after that. I know this was a slightly sketchy way of troubleshooting, but I didn't have much time. I should just buy the VCDS cable for myself and only waste my own time instead of other people...
For what it's worth, here's my autoscan from before we started making changes. (Xenons plugged in but not working)
Friday,09,April,2021,09:56:49:52359
www.Ross-Tech.com
Readiness: 0000 0000
Revision: --------
Revision: 0003SH02
Coding: 3CB02BBF08A10000003009F02A2B0DD05FC0612F7E060041A00000000000
Coding: 58BC30
Coding: 58BC30
Coding: 58BC32
Coding: 58BC32
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 49
Mileage: 112596 km
Time Indication: 0
Date: 2015.08.30
Time: 16:10:09
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 21
Reset counter: 51
Mileage: 107334 km
Time Indication: 0
Date: 2015.03.17
Time: 18:08:39
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 107
Reset counter: 11
Mileage: 98608 km
Time Indication: 0
Date: 2014.11.15
Time: 09:02:26
00978 - Lamp for Low Beam; Left (M29)
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 4
Reset counter: 11
Mileage: 112597 km
Time Indication: 0
Date: 2015.08.30
Time: 20:46:21
Coding: 108001
Coding: 00314D
Coding: 140C01
Coding: 2500C2
Serial number:
Coding: 16000440040005
6 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 99932 km
Time Indication: 0
Date: 2014.11.25
Time: 19:37:40
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00875 - Treble Speaker Front Right (R22)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00876 - Treble Speaker Rear Left (R14)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00877 - Treble Speaker Rear Right (R16)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00856 - Radio Antenna
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Coding: 032B7A64
End----------(Elapsed Time: 01:09, VBatt start/end: 12.2V/12.1V)------------ iichel
4 wires to headlight L (sinistro - L in inalian)sparrow77 wrote: Fri Apr 09, 2021 1:34 pm Thanks for clarifying, iichel.
4 wires to headlight R (dextro - D in italian)
3 wires to the sensor
2 wires to canbus powertrain
1 wire to positive
1 wire to GND
