Page 10 of 11
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Posted: Wed Dec 27, 2017 11:53 am
by benzinkopf
thanks Ciclo! happy holidays and new year!
Posted: Wed Dec 27, 2017 12:17 pm
by ciclo
You're welcome! same for you, happy holidays and very happy new year... :wink:
Posted: Tue Jan 30, 2018 11:08 pm
by federicodrdpro
How is possible to check the regulation of the headlights after Installed the AFS?
Posted: Wed Jan 31, 2018 7:40 am
by ciclo
Yes with a tester, it is a fast, simple and cheap operation (even free) that most workshops can do.
or https://www.wikihow.com/Adjust-Car-Headlights
Posted: Tue Nov 20, 2018 10:27 pm
by golffather
iichel wrote: Fri Apr 29, 2016 10:38 am In many countries, auto-leveling of high-brightness lights over 2000 lumens is obligatory.
Personally I think it is a very good thing to do too. Bright Xenon and LED headlights, when not adjusted and regulated properly, can be very annoying.
Be aware, that this is only for the OEM Xenon and OEM LED headlights. It is not for halogen headlights!
This is a topic to help installation, since it is not very difficult.
Material you need:
6R0 941 273 B sensor for the rear axle
6R0 907 357 module for AFS J431
6Q0 612 405 bracket for brake tube, to mount the sensor on.
Mounting position of the AFS module is above the glove box (LHD) or behind the steering wheel (RHD).
You need the bracket (part number to come).
Mounting position of the sensor is under the car.
Take a look where the brake hose has a coupling piece at the rubbers of the rear axle, on the left side.
This coupling piece is also a bracket, where it is connected to the chassis. This bracket needs to be changed for the 6Q0 612 405 bracket.
For this, you need to disconnect the brake hose, shortly. This is dangerous fluid.
You can mount the sensor, heat shield up towards the exhaust, on the new bracket.
The arm of the sensor goes to a mounting point on the rear axle.
The wiring is not so complicated:
CAN powertrain wiring to T26 of the module J431 and wiring from module J431 to sensor G76.
Module is powered by terminal 15, ignition switched power.
Module is connected to T14 of the headlights. It is the same for OEM LED for 6C and OEM Xenon for 6R.
Look in the pictures for J431 (T26, 26 pin connector)
The wiring loom is not difficult to make yourself.
You need 2 connectors:
4E0972726 26 pin connector with micro quadlock system
4B0973712 4 pin connector for sensor with micro power timer
The connectors in the headlight (T14) are all micro power timer.
do not forget to seal the connectors with, for example, 357 972 740 E for the micro power timers.
you will need to seal one hole on the sensor connector which is empty. use 3C0 972 841
VCDS:
enable module 55 (xenon range) in the canbus gateway (module 19)
appropriately code the xenon range module for RLS, start/stop etc.
If everything is wired correctly:
If you start the engine, and low beam is on, you will see the lights go up and down. this is the reference run.
This is an indication that all is wired well.
Do you know what the power voltages are to the headlight pins T14/1,2,3,4?
What does the micro power timer mean?
Trying to adjust the motors manually and seeing what i need to supply the pins with
Posted: Wed Nov 21, 2018 1:09 am
by CNK
golffather wrote: Tue Nov 20, 2018 10:27 pm What does the micro power timer mean?
Micro Timer - 1,5mm
check https://www.a4-freunde.com/showwiki.php ... zu+gehoert :wink:
Posted: Wed Nov 21, 2018 6:00 pm
by golffather
CNK wrote: Wed Nov 21, 2018 1:09 am
Micro Timer - 1,5mm
ah ok thanks! thats the pins themselves.
I just need to know what signal is on these lines.
Posted: Wed Aug 28, 2019 11:33 am
by MicheleMelluso
Hi, and congratulations for the forum.
I have a 2017 VW Polo 6C with halogen headlights. I would like to install the original LED headlights but I don't know if my BCM is compatible. The serial number read through diagnostics is 6C0937089E.
Another question. If I don't install the auto-leveling headlight the dimmer(the one to the right of the light switch) to adjust the headlight height manually works?
Thank you
Posted: Wed Aug 28, 2019 3:13 pm
by iichel
Yes to the first, but no to the second
Posted: Fri Apr 09, 2021 11:30 am
by sparrow77
Sorry, bumping an old thread. I've fitted xenons to my Bluemotion 6R, coded them and everything is working. Next step will be to add ALS, which seems straightforward based on this thread. Because my car has start/stop, I noticed a lot of the places that sell wiring looms for this retrofit mention incompatibility with start/stop.
e.g. https://www.kufatec.com/en/volkswagen/v ... o-6r-37920
"NOT suitable for vehicle with PR-number 7L6, 7L8 (Start/Stop)"
http://vagtec.co.uk/eshop/volkswagen/po ... lo-6r.html
"NOT suitable for vehicle with PR-number 7L8 (Start/Stop)"
It's a lot cheaper to buy the level sensor, bracket and module separately, so I think I'll buy my loom from car-systems, which I've dealt with before: https://www.carsystems.eu/wiring-for-au ... id923.html
This doesn't mention any compatibility issues with Bluemotion. What exactly causes the issues with start/stop? Anything I should be aware of?
FWIW, here's my autoscan from this morning - including working xenons.
Friday,09,April,2021,10:21:05:52359
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY090318   License Plate:
Mileage: 112650km-69997mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 44 56 61
VIN: WVWZZZ6RZDY090318   Mileage: 112650km-69997miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 FJ    HW: 03F 907 309 K
   Component: SIMOS10.23AH10 4038
   Revision: --H10---    Serial number:
   Coding: 001100B6202401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070FJ 004007
   ROD: EV_ECM12TFS021_VW25.rod
   VCID: 6FBBD677B711C403669-803A
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3217600B2842814E384D900501300
   VCID: 025D8FC39443D96B997-8056
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 392F282FB9555AB388D-806C
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serial number: 0456 251120043
   Coding: 3CB02BBF08A1000000300F912A2B0DD05AC0672F7E053041A00000000000
   Shop #: WSC 124697 483 00190
   VCID: 41DF40CFD1850273C0D-8014
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU011091200011248
   Coding: 58BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU010091200015821
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU004091200010377
   Coding: 58BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU004091200015471
   Coding: 58BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361225100949
   Coding: 108001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E253B33A0FB7D8BBDF-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01D2R6F
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD67E3EC33C12B117-801E
   Serial number: 3575HRB405D1IMPM4GE4
   Serial number: 3585HRB405F1IMPMB8OG
   Serial number: 3515RRB406919PPQCHLJ
   Serial number: 3525RRB405B1AP60BOUZ
   Part No SW: 6R0 920 860 K    HW: 6R0 920 860 K
   Component: KOMBI         H05 0605
   Coding: 140C01
   VCID: 3C21313BB6E76F9B93B-8068
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 E    HW: 1K0 907 951
   Component: J533  Gateway H38 0041
   Revision:   H38       Serial number: 130912F2000379
   Coding: 2500C2
   VCID: 3537241F954DBED36C5-8060
   Component: IMMO          H05 0605
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC7638CF3212B317-803E
Address 44: Steering Assist        Labels: None
   VCID: 55F7849F3C4D9ED38C5-8000
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 16000400040005
   Shop #: WSC 127395 840 08317
   VCID: 46D553D3F8AB254BF5F-8012
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0041
   Coding: 032B7A64
   VCID: 74B1D91BDEB7E7DB9BB-8020
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970099393
End----------(Elapsed Time: 01:05, VBatt start/end: 14.9V/14.9V)-----------
Log-WVWZZZ6RZDY090318-112650km-69997mi_loppu.txt
Displaying Log-WVWZZZ6RZDY090318-112650km-69997mi_loppu.txt.
Posted: Fri Apr 09, 2021 12:35 pm
by iichel
I think it's a bunch of nonsense, Start/Stop doesn't influence the operation of AFS in any way.
Posted: Fri Apr 09, 2021 1:34 pm
by sparrow77
Thanks for clarifying, iichel.
Another question, sorry for double post:
iichel wrote: Fri Apr 29, 2016 10:38 am CAN powertrain wiring to T26 of the module J431 and wiring from module J431 to sensor G76.
I'm sort of semi-adept at wiring. If I understood this right, from the module J431 there are 8 wires going to the headlights (4 each), three wires to the sensor G76, and then three wires that go... somewhere? Two CAN and one ground? "Module is powered by terminal 15, ignition switched power." Where exactly do I run the two CAN wires? Terminal 15 where? Sorry, just trying to understand. :D
EDIT: sorry, should have looked at the first page for this very helpful post.
Posted: Fri Apr 09, 2021 1:45 pm
by ciclo
:arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
:arrow: https://drive.google.com/drive/folders/ ... 1NJR3NKaG8
The compatibilities have improved over the years ( :mrgreen: ), ... but at first the warnings of those websites were correct.
However,
Address 55: Xenon Range (J431) -Start/Stop function-
sparrow77, any reason to have Byte12 Bit6 disabled in your BCM? ... are SCLs bulbs installed in your bi-xenon headlights?
Posted: Fri Apr 09, 2021 1:56 pm
by sparrow77
ciclo wrote: Fri Apr 09, 2021 1:45 pm sparrow77, any reason to have Byte12 Bit6 disabled in your BCM? ... are SCLs bulbs installed in your bi-xenon headlights?
I have no idea, unfortunately. I'm not sure if it makes a difference, but my car is an early MY2013 and the xenons are pre 04/2011. Not sure about bulb types.
This morning we were coding the xenons. I used the binary coding changes indicated in your post, at the bottom here.
Unfortunately for my car, the DRLs weren't working after this. I had a quick peek through the thread (as I was getting help from a local guy and didn't want to use too much of his time, he was doing the coding on his laptop) and saw that someone else had issues the the DRLs (not the same issue exactly). So I decided to try this snippet 2049, and the DRLs started working after that. I know this was a slightly sketchy way of troubleshooting, but I didn't have much time. I should just buy the VCDS cable for myself and only waste my own time instead of other people... :D
For what it's worth, here's my autoscan from before we started making changes. (Xenons plugged in but not working)
Friday,09,April,2021,09:56:49:52359
www.Ross-Tech.com
Readiness: 0000 0000
   Revision: --------
   Revision: 0003SH02
   Coding: 3CB02BBF08A10000003009F02A2B0DD05FC0612F7E060041A00000000000
   Coding: 58BC30
   Coding: 58BC30
   Coding: 58BC32
   Coding: 58BC32
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 112596 km
                    Time Indication: 0
                    Date: 2015.08.30
                    Time: 16:10:09
00447 - Function Limitation due to Over-Voltage
            001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Fault Priority: 6
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 107334 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 18:08:39
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 107
                    Reset counter: 11
                    Mileage: 98608 km
                    Time Indication: 0
                    Date: 2014.11.15
                    Time: 09:02:26
00978 - Lamp for Low Beam; Left (M29)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 112597 km
                    Time Indication: 0
                    Date: 2015.08.30
                    Time: 20:46:21
   Coding: 108001
   Coding: 00314D
   Coding: 140C01
   Coding: 2500C2
   Serial number:
   Coding: 16000440040005
6 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 217
                    Mileage: 99932 km
                    Time Indication: 0
                    Date: 2014.11.25
                    Time: 19:37:40
00874 - Treble Speaker Front Left (R20)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
00875 - Treble Speaker Front Right (R22)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
00876 - Treble Speaker Rear Left (R14)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
00877 - Treble Speaker Rear Right (R16)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
00856 - Radio Antenna
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
   Coding: 032B7A64
End----------(Elapsed Time: 01:09, VBatt start/end: 12.2V/12.1V)-----------
Posted: Fri Apr 09, 2021 3:07 pm
by iichel
sparrow77 wrote: Fri Apr 09, 2021 1:34 pm Thanks for clarifying, iichel.
4 wires to headlight L (sinistro - L in inalian)
4 wires to headlight R (dextro - D in italian)
3 wires to the sensor
2 wires to canbus powertrain
1 wire to positive
1 wire to GND
