UK-POLOS.NET - THE VW Polo Forum • BCM High to BCM Max, AFS, LED Headlights and HBA - Page 10
Page 10 of 11
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Posted: Sun Apr 08, 2018 3:03 pm
by federicodrdpro
Ok, thanks Michel for the feedback!
Here the errors that appear when I use HBA:
Sunday,08,April,2018,15:42:13:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628   License Plate:
Mileage: 88110km-54749mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 20 25 44 55 0B
VIN: WVWZZZ6RZCY020628   Mileage: 88110km-54749miles
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C089086461C76E19-8030
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416F00B2842B14E482D900421700
   Shop #: WSC 00788 648 00255
   VCID: 071CA380B22D357ECB-8052
   Serial number: 08021613470256
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7EF2C664E1F774B6F8-802A
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 128171814
   Coding: 3CB02BBF48E3260093380E906CEF9ED05A88732F608530C0200000030800
   Shop #: WSC 18752 008 00032
   VCID: 2B543F304A05311E0F-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 060215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU030051100011446
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU025051100015419
   Coding: 08BC30
   Component: LIN BACKUP HO  H03 1301
   Subsystem 7 - Part No SW: K8 951 171 A    HW: K89 511 71A
   Serial number: ÿK8951171A  °103
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027051100012627
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU027051100013292
   Coding: 08BC32
5 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            007 - Short to Ground - Intermittent
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 12
                    Reset counter: 166
                    Mileage: 88043 km
                    Time Indication: 0
                    Date: 2012.08.28
                    Time: 02:10:36
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 71
                    Reset counter: 126
                    Mileage: 88043 km
                    Time Indication: 0
                    Date: 2012.08.28
                    Time: 02:08:31
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 30
                    Reset counter: 166
                    Mileage: 88047 km
                    Time Indication: 0
                    Date: 2012.08.28
                    Time: 22:58:22
01495 - Bulb for High-Beams; Left (M30)
                    Fault Priority: 3
                    Fault Frequency: 16
                    Reset counter: 166
                    Mileage: 88050 km
                    Time Indication: 0
                    Date: 2012.08.28
                    Time: 23:01:40
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 165
                    Mileage: 88050 km
                    Time Indication: 0
                    Date: 2012.08.28
                    Time: 23:01:40
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NWXFQ
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40550INGS999T
   Serial number: 3585HRB40570INGSBHPF
   Serial number: 3515RRB40510JNPM7P50
   Serial number: 3525RRB404P0K4DOA8O1
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A7A0A74BD5F989684-806E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68DE803C9B73DA0622-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 040400E200000000000000
   Shop #: WSC 34948 001 1048576
   ROD: N/A
   VCID: 2E5236247117443628-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H03 0505
   Serial number:
   VCID: 6ADAFA348D7FE81634-803E
   Part No: 6R0 423 156 B
   Coding: 11210
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77FCD340CECD45FEBB-8022
End-------------------------(Elapsed Time: 03:32)--------------------------
Michel have you an Autoscan to compare with mine? (module 09 and module 20 HBA)
Posted: Sun Apr 08, 2018 3:16 pm
by iichel
sure no problem
Thursday,15,March,2018,11:21:14:11868
VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN:   License Plate:
Mileage: 63860km-39680mi   Repair Order:
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 3D 44 47
          55 56 57 61 69 6C 77
VIN:   Mileage: 63860km-39680miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
3D-Special Function -- Status: Not registered 0001
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270B06DDAF6FF1FF132-8072
Readiness: 0 0 0 0 1
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Coding: 21DD4885432500C5841A126EC25500521505
   Shop #: WSC 00049 770 00138
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89BFFB2-805A
1 Fault Found:
0625 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 211
                    Mileage: 63860 km
                    Date: 2018.03.15
                    Time: 11:04:40
   Part No SW: 6RA 959 654     HW: 6RA 959 654
   Component: LENKW.SENSOR  H02 0020
   Serial number: 090465LBH0000C
   Coding: 01
   ASAM Dataset: EV_LWSKLOVW25X 005002
   ROD: EV_LWSKLOVW25X.rod
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF617F832-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E078A8-806C
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933806E2FFEB9FD080A273EFE08D78D0A2E400030800
   VCID: 688945E162713E87DA8-803C
   Component: RLS 140415 03  37  0059
   Coding: 0380DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
1 Fault Found:
00886 - Turn Signal Switch (E2)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 171
                    Mileage: 63860 km
                    Time Indication: 0
                    Date: 2018.03.15
                    Time: 11:04:36
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   VCID: 3B23CAAD43E7451F67A-806E
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC97ECC-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 3333E28D6BB78D5FBFA-8066
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042200
2 Faults Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 63860 km
                    Time Indication: 0
                    Date: 2018.03.15
                    Time: 11:16:34
03590 - Control Module for Multifunction Module
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 63860 km
                    Time Indication: 0
                    Date: 2018.03.15
                    Time: 11:16:39
   Revision: AA001001
   Coding: 040C00E200000000000000
   VCID: 2E05F3F98095A0B7D04-807A
   Component: IMMO          H04 0709
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3FE97CFD0C97CCC-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9BFDB2-807A
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B03FAEDB307D59FF7A-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB9978459877984-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
   Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
   Component: SWA Master    H07 0030
   Serial number: 0384674663
   Coding: 010121
   Shop #: WSC 54321 321 54321
   ASAM Dataset: EV_LaneChangAssis 001028
   ROD: EV_LaneChangAssis_VN75.rod
   VCID: 3039ED819AA1B647C28-8064
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0432634593
   Coding: 010121
3 Faults Found:
267776 - Data Set Implausible
          B2012 00 [009] -  -
          [Implausible dataset]
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 171
                    Mileage: 63860 km
                    Date: 2018.03.15
                    Time: 11:04:52
729349 - Control Module for Lane Change Assistance
          C1114 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 63860 km
                    Date: 2018.03.15
                    Time: 11:04:40
729605 - Control Module 2 for Lane Change Assistance
          C1115 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 63860 km
                    Date: 2018.03.15
                    Time: 11:04:40
Address 3D: Special Function        Labels: None
   Part No SW: 1F9 909 919 A    HW: 1F9 909 919 A
   Component: MultifunctionDevice 0067
   Revision: 00H03000    Serial number: 00000000000409
   Coding: 3D807B
   VCID: 3635DB9974459877984-8062
   Subsystem 1 - Part No: 6C0 959 442 C
   Component: E221__MFL-DC1
   Coding: 11221
   Shop #: WSC 12345
   VCID: 2F3BEEFD8E5FA9BFDB2-807A
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            49-10 - No Communications - Intermittent
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE871A8-807C
Address 4B: Multifunc. Module
Cannot be reached
   Coding: 0192000001000000
   VCID: 77AB169D3F4FA17F432-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE871A8-807C
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9BFDB2-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323EFE1E-8030
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Time Indication: 0
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3EF21E-8070
End----------(Elapsed Time: 02:33, VBatt start/end: 14.4V/14.5V)-----------
Posted: Sun Apr 08, 2018 5:00 pm
by federicodrdpro
Thanks! Is there a bit description of BCM Bytes on uk-polos?
Posted: Sun Apr 08, 2018 5:29 pm
by ciclo
in my wonderful mind. Thank you. :mrgreen:
iichel wrote: Sun Apr 08, 2018 1:53 pm Yes, both firegrafik and myself, we experienced this problem.
For me, it has disappeared but I didn't change anything.
:lol: it's always a good time to tell the hidden truths.
Bit, Bit, Bit, Bit, .... always is a _______ 'Bit'. :lol:
This never happened with bixenon. HBA worked perfectly (like a charm, wonderfully) from the first second.
Posted: Sun Apr 08, 2018 9:19 pm
by federicodrdpro
Ok, it is not a problem of bit. Who know which could be the problem?
I used this scheme:
Posted: Sun Apr 08, 2018 9:26 pm
by ciclo
It's a Bit problem.
A perfect diagram.
Be careful, you are talking to a moderator.
Posted: Sun Apr 08, 2018 9:36 pm
by federicodrdpro
I understood that it wasn't a problem of Bit. :oops:
Why this? :|
ciclo wrote: Sun Apr 08, 2018 9:26 pm
Please I am serious, I would talk about the problem of my 6R.
Posted: Tue Apr 10, 2018 4:46 am
by ciclo
federicodrdpro wrote: Sun Apr 08, 2018 9:36 pm Why this? :|
You clearly despise my work and my help. You throw a question to outer space as if I didn't exist.
federicodrdpro wrote: Sun Apr 08, 2018 9:19 pm Ok, it is not a problem of bit. Who know which could be the problem?
I used this scheme:
You bite the only hand that feeds you, this is only done by one type of person.
You have made a very serious mistake doing this.
Not related:
Speaking of Humility ...
Where are your thanks?
viewtopic.php?f=56&t=70787&start=105#p530598
viewtopic.php?f=56&t=70787&start=105#p531407
viewtopic.php?f=56&t=70787&start=105#p531808
viewtopic.php?f=56&t=70787&start=105#p531809
etc...
Oh, yes, here they are.
viewtopic.php?f=56&t=70787&start=135#p532703
viewtopic.php?f=56&t=70787&start=135#p532708
Do you have any kind of prejudice with me? again, you make a very serious mistake.
Good luck with solving your problems ... please keep us informed. Thanks.
Posted: Tue Apr 10, 2018 8:14 am
by iichel
Just to clarify, I don't think Federico is suggesting the wiring scheme is at fault.
I think all of us (ciclo, firegrafik, federico, myself) use the same scheme and the HBA works perfect.
I suspect he is mentioning the wiring scheme, to find out what coding is needed, since ciclo's suggestion is aiming at a bit (so something in the coding).
I noted a difference in the HBA coding, the second 04 in federico's scan is a an 0C in my scan (high beam type laser) but I changed it back to LED and there is no difference.
I don't know where the problem is coming from, but the wiring is OK.
Posted: Tue Apr 10, 2018 10:42 am
by ciclo
iichel wrote: Tue Apr 10, 2018 8:14 am I think ,,,
:lol:
iichel wrote: Tue Apr 10, 2018 8:14 am I don't know where the problem is coming from,..
Posted: Tue Apr 10, 2018 11:04 am
by firegrafik
I also have some issues with HBA
There is last year video of this with high beam flashing with HBA activated.
https://photos.app.goo.gl/7F5YLkjo09LLqD2r2
Sometimes it work only one high beam light (right or left, and sometimes no one works but blue light on IC work) also sometimes the same fault appears, for only right or left high beam
Before LED headlights I used HBA with H7 halogen headlights and it worked like charm.
I tried many coding variants for 09 and 20 units but problem hasn't gone, so the one thing I have not checked is adaptation channels values from T6 with LED headlights and HBA from the factory.
Posted: Tue Apr 10, 2018 11:16 am
by peter_dk25
ciclo wrote: Tue Apr 10, 2018 4:46 am
Yes - I have noticed the same.
:shock:
Posted: Tue Apr 10, 2018 11:18 am
by ciclo
firegrafik wrote: Tue Apr 10, 2018 11:04 am I also have some issues with HBA
viewtopic.php?f=56&t=71073#p531645
Posted: Tue Apr 10, 2018 4:05 pm
by iichel
I based some tests on this coding --> 3A904BB808A1240012380600344B049000C0604F60C51960210000000820 (see the link from ciclo above)
changed byte 18 to 60
changed byte 29 bit 5 to 1
all works now, high beam signalling with HBA ON and dipped beam ON and OFF.
Posted: Tue Apr 10, 2018 6:11 pm
by ciclo
Image...Image
