Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Yes, try to do it in a clean way.😊
favi
Drives: 6R
Post by favi »
Yeah !
Next question:
BCM pin connectors :
- 000 979 025 E (1a/1b) ?
- 000 979 151 E (4b, 8b, 7a) ?
- 000 979 025 E for 62a, 37a ?
FUSE Box connectors:
- 34a - 36a/b N 906 844 05 or N 907 326 03 ?
Stalks 7E0 - N 907 326 03
favi wrote: Sat Mar 11, 2023 6:10 pm Yeah !
Next question:
- 000 979 025 E (1a/1b) ? :arrow: 000 979 151 E , 000 979 242 E
- 000 979 151 E (4b, 8b, 7a) ? :arrow: 000 979 150 E
- 000 979 025 E for 62a, 37a ? :arrow: 000 979 009 E
Stalks 7E0 - N 907 326 03, 000 979 023 E
favi
Drives: 6R
Post by favi »
I did all wirings.
But have problem :D
I coded - 28 byte 3 bit 0->1
Adaptation BCM 53 - 0->1 and 54 - 0 ->1
Gateway - HBA added - no faults
Highbeam - not works
Flash highbeam - not works
Highbeam lamp on instrument cluster - always on
Due to the new electrical installation you have to disable the Byte23 Bit0.
favi
Drives: 6R
Post by favi »
HBA works !
but faults on hb 01495 and 01499
and parkings lights 03431 and 03432
but lights work
Congratulations!🎉
Please post a full autoscan so we can see what's going on.😊
favi
Drives: 6R
Post by favi »
Ok, HBA not works ;D
1. only icon on instrument cluster works
2. my reverse camera in logo badge - doesn't want to flip back after put into first gear
3. Sometimes, when I activated HBA (icon on instrument cluster ON), flash high beam doesn't works.
4. VCDS Scan
Saturday,25,March,2023,12:54:24:00009
VIN: License Plate:
Mileage: 280440km-174257mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 55 5F 77
VIN: Mileage: 280440km-174257miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9851
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070D 003015
   ROD: EV_ECM12TFS02103F906070BQ_003.rod
   VCID: 23455A8B2AD5F19E36-8076
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3217500B7842814E484DA00401300
   Shop #: WSC 27514 001 1048576
   VCID: 071D2E1BB22D3DBE4A-8052
   Component: LENKW.SENSOR  H06 0070
   Serial number: 15031304651874
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326BAFCF6D2F6816CD-8066
   Revision: B9080001    Serial number: 0771 071161174
   Coding: 2CB02BBF48E1240093380E007CCB1FD000C0670F60CD39E0210000030820
   Shop #: WSC 02737 022 157175
   VCID: 68DF0DA79B73D2C6A3-803C
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 170117 04  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8610
   Serial number: KU0KU010091300015333
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8610
   Serial number: KU0KU006091300015370
   Coding: 1000AB
   Subsystem 4 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160003417360027086
   Coding: A40000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU015031100013211
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU014031100013620
   Coding: 08BC32
4 Faults Found:
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:54:05
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:54:05
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:54:08
03156 - Sensor for Anti-Theft System (G578)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:54:08
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231501401002
   Coding: 308002
   Shop #: WSC 07456 790 50316
   VCID: 3B7582EBB265A95E1E-806E
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00J3B65
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9BD72FEDBF00D695-801E
   Serial number: 3575HRB40570G68U9HCH
   Serial number: 3585HRB40550G68U7HIK
   Serial number: 3515RRB405T0510IA8VI
   Serial number: 3525RRB405T0510IMOL.
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0609
   Coding: 140E01
   VCID: 3467A9D79F3B6626DF-8060
   Revision: B9080001
   Coding: 002200
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 000000E700000000000000
   Shop #: WSC 35110 790 50316
   VCID: 2D51BCB37C1137EE90-8078
1 Fault Found:
15466752 - Control module not coded
          U1013 00 [009] - -
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Date: 2023.03.25
                    Time: 12:54:04
   Component: IMMO          H05 0609
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6DA6BBEA1D45FEA2-807A
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   Shop #: WSC 12345 123 12345
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A7B87EFBD5F905605-806E
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0468
   Serial number: VWZAZ2U0639822
   Coding: 02720001FF0000001111000100080A001F0100D400200100CF
   Shop #: WSC 00567 048 00001
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 244759972FDBF6A64F-8070
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 DF    HW: -----------
   Component: ECE AS 23/24  --- 2010
1 Fault Found:
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Date: 2023.03.25
                    Time: 12:54:04
                    Voltage terminal 30: 13.8 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:10)--------------------------
Gateway Installation List:  7E0 909 901
                Address 09: Cent. Elect.       Labels: 7E0-937-BCM-V1.clb
Control Module Part Number: 7E0 937 090     HW: 7E0 937 090
  Component and/or Version: BCM PQ25 Max4 H80 0736
           Software Coding: 2CB02BBF48E1240093380E007CCB1FD000C0670F60CD39E0210000030820
            Work Shop Code: WSC 02737 022 157175
6 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:59:37
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:59:37
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:59:42
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 12:59:41
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:01:36
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:01:36
Address 20,7E0 857 511 F,channel IDE03886-Activation speed for high beam assistant,adapted from,58 km/h,to,30 km/h,
Address 20,7E0 857 511 F,channel IDE03888-Left-/right hand driving,adapted from,Right ,to,Left ,
6 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:03:46
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:03:46
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:03:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:03:51
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:03:47
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 280448 km
                    Time Indication: 0
                    Date: 2017.08.15
                    Time: 13:03:47
FUse box photo
Address 20:
- New coding :arrow: 0404000000000000000000
IDE03888-Left-/right hand driving, :arrow: Right ,1
- Adaptations (Full)
	SW:7E0-857-511-G   HW:7E0-857-511-E ---  High Beam Assist.
	Component:FLA           H10 0003, Coding:0404000000000000000000
	EV_HighBeamAssisAU316,001004,EV_HighBeamAssisAU316.rod
	Tuesday,29,September,2020,17:39:44:32438
	VCDS Version: Release 20.4.2 (x64)  Data version: 20200730 DS317.0
	VCID: 2E05F3C4B090AE1BF0F-807A
IDE03885-Speed threshold for high beam recommendation off,28 km/h,2
IDE03886-Activation speed for high beam assistant,30 km/h,2
IDE03888-Left-/right hand driving,Right ,1
IDE04034-Compass: magnetic field zone,Zone 8 ,1
IDE08662-Speed threshold for immediate high beam recommendation off,5 km/h,2
IDE08708-Inter. light-depending deactivation of dimming function,via discreet wire ,1
IDE08712-Brightness of indicator light for day/night interior mirror,Light sensor in interior mirror ,1
IDE11047-MAS11967-Function characteristics predictive route data-Drive sequence,not activated ,2
IDE11047-MAS11968-Function characteristics predictive route data-HIgh beam suppression when driving uphill/downhill,not activated ,2
IDE11047-MAS11969-Function characteristics predictive route data-Delayed high beams on freeway,not activated ,2
IDE11047-MAS11970-Function characteristics predictive route data-High beam suppression in residential areas,not activated ,2
IDE11047-MAS11971-Function characteristics predictive route data-High beam suppression outside residential areas,not activated ,2
IDE11047-MAS11972-Function characteristics predictive route data-High beam suppression on freeway entry and exit ramps,not activated ,2
IDE11047-MAS11973-Function characteristics predictive route data-HIgh beam suppression in tunnels,not activated ,2
IDE11047-MAS11974-Function characteristics predictive route data-High beam suppression before tunnels,not activated ,2
IDE11047-MAS11975-Function characteristics predictive route data-HIgh beam suppression in traffic circles,not activated ,2
IDE11047-MAS11976-Function characteristics predictive route data-Dynamic adaptation of built-up areas recognition parameters,not activated ,2
IDE11047-MAS12004-Function characteristics predictive route data-High beam suppression before traffic circles,not activated ,2
ENG128953-IDE80001-AA_Parameters-Analysis 1,-100 ,6
ENG128953-IDE80002-AA_Parameters-Analysis 2,84 ,6
ENG128953-IDE80003-AA_Parameters-Analysis 3,62 ,6
ENG128944-IDE80170-AS_Parameters-Analysis 170,144 ,3
ENG128944-IDE80171-AS_Parameters-Analysis 171,112 ,3
ENG128944-IDE80172-AS_Parameters-Analysis 172,80 ,3
ENG128938-IDE80105-BC_Parameters-Analysis 105,50 ,5
ENG128938-IDE80106-BC_Parameters-Analysis 106,100 ,5
ENG128938-IDE80107-BC_Parameters-Analysis 107,100 ,5
ENG128934-IDE80010-BCS_Parameters-Analysis 10,700000 ms,12
ENG128934-IDE80011-BCS_Parameters-Analysis 11,60000 ms,12
ENG128934-IDE80012-BCS_Parameters-Analysis 12,5000 ms,12
ENG128948-ENG128957-Compass_display_dimming_curve_manipulation-Point_0_Bus_Value,0 ,12
ENG128948-ENG128958-Compass_display_dimming_curve_manipulation-Point_0_PWM_Value,1 ,12
ENG128948-ENG128959-Compass_display_dimming_curve_manipulation-Point_1_Bus_Value,25 ,12
ENG128948-ENG128960-Compass_display_dimming_curve_manipulation-Point_1_PWM_Value,1 ,12
ENG128948-ENG128961-Compass_display_dimming_curve_manipulation-Point_2_Bus_Value,51 ,12
ENG128948-ENG128962-Compass_display_dimming_curve_manipulation-Point_2_PWM_Value,4 ,12
ENG128948-ENG128963-Compass_display_dimming_curve_manipulation-Point_3_Bus_Value,75 ,12
ENG128948-ENG128964-Compass_display_dimming_curve_manipulation-Point_3_PWM_Value,15 ,12
ENG128948-ENG128965-Compass_display_dimming_curve_manipulation-Point_4_Bus_Value,99 ,12
ENG128948-ENG128966-Compass_display_dimming_curve_manipulation-Point_4_PWM_Value,80 ,12
ENG128948-ENG128967-Compass_display_dimming_curve_manipulation-Point_5_Bus_Value,100 ,12
ENG128948-ENG128968-Compass_display_dimming_curve_manipulation-Point_5_PWM_Value,80 ,12
ENG128949-Compass_display_memory,activated ,1
ENG128942-IDE80152-DLD_Parameters-Analysis 152,3000 ms,16
ENG128942-IDE80153-DLD_Parameters-Analysis 153,3000 ms,16
ENG128942-IDE80154-DLD_Parameters-Analysis 154,3000 ms,16
ENG128942-IDE80155-DLD_Parameters-Analysis 155,1500 ms,16
ENG128941-IDE80150-DLE_Parameters-Analysis 150,1015807 ,5
ENG128941-IDE80151-DLE_Parameters-Analysis 151,OFF ,5
ENG128940-DS_Parameters,200 m,2
ENG128952-ENG128992-DTC_Mask_CAN-30_DTC_reserved_0,activated ,2
ENG128952-ENG128993-DTC_Mask_CAN-31_DTC_0xCA0001,activated ,2
ENG128952-ENG128994-DTC_Mask_CAN-32_DTC_0xCA0002,activated ,2
ENG128952-ENG128995-DTC_Mask_CAN-33_DTC_0xCA0003,activated ,2
ENG128952-ENG128996-DTC_Mask_CAN-34_DTC_0xCA0004,activated ,2
ENG128952-ENG128997-DTC_Mask_CAN-35_DTC_0xCA0005,activated ,2
ENG128952-ENG128998-DTC_Mask_CAN-36_DTC_0xCA0D00,activated ,2
ENG128952-ENG128999-DTC_Mask_CAN-37_DTC_0xCA0104,activated ,2
ENG128952-ENG129000-DTC_Mask_CAN-38_DTC_0xCA0E00,activated ,2
ENG128952-ENG129001-DTC_Mask_CAN-39_DTC_0xCA0E01,activated ,2
ENG128951-ENG128969-DTC_Mask_functional-0_DTC_0xEC0100,activated ,3
ENG128951-ENG128970-DTC_Mask_functional-1_DTC_reserved,activated ,3
ENG128951-ENG128979-DTC_Mask_functional-10_DTC_0xEC0D07,activated ,3
ENG128951-ENG128980-DTC_Mask_functional-11_DTC_0xEC0D08,activated ,3
ENG128951-ENG128981-DTC_Mask_functional-12_DTC_0xEC0E00,activated ,3
ENG128951-ENG128982-DTC_Mask_functional-13_DTC_0xEC0E01,activated ,3
ENG128951-ENG128983-DTC_Mask_functional-14_DTC_0xEC0E02,activated ,3
ENG128951-ENG128984-DTC_Mask_functional-15_DTC_0xEC0E03,activated ,3
ENG128951-ENG128985-DTC_Mask_functional-16_DTC_0xEC0E04,activated ,3
ENG128951-ENG128986-DTC_Mask_functional-17_DTC_0xEC0E05,activated ,3
ENG128951-ENG128987-DTC_Mask_functional-18_DTC_0xEC0E06,activated ,3
ENG128951-ENG128988-DTC_Mask_functional-19_DTC_0xEC0E07,activated ,3
ENG128951-ENG128971-DTC_Mask_functional-2_DTC_0xEC0102,activated ,3
ENG128951-ENG128989-DTC_Mask_functional-20_DTC_0xEC0E08,activated ,3
ENG128951-ENG128990-DTC_Mask_functional-21_DTC_0xEC0E09,activated ,3
ENG128951-ENG128991-DTC_Mask_functional-22_DTC_0xEC0E0A,activated ,3
ENG128951-ENG128972-DTC_Mask_functional-3_DTC_0xEC0D00,activated ,3
ENG128951-ENG128973-DTC_Mask_functional-4_DTC_0xEC0D01,activated ,3
ENG128951-ENG128974-DTC_Mask_functional-5_DTC_0xEC0D02,activated ,3
ENG128951-ENG128975-DTC_Mask_functional-6_DTC_0xEC0D03,activated ,3
ENG128951-ENG128976-DTC_Mask_functional-7_DTC_0xEC0D04,activated ,3
ENG128951-ENG128977-DTC_Mask_functional-8_DTC_0xEC0D05,not activated ,3
ENG128951-ENG128978-DTC_Mask_functional-9_DTC_0xEC0E0B,activated ,3
ENG128947-ENG128957-EC_indicator_dimming_curve_manipulation-Point_0_Bus_Value,0 ,12
ENG128947-ENG128958-EC_indicator_dimming_curve_manipulation-Point_0_PWM_Value,1 ,12
ENG128947-ENG128959-EC_indicator_dimming_curve_manipulation-Point_1_Bus_Value,25 ,12
ENG128947-ENG128960-EC_indicator_dimming_curve_manipulation-Point_1_PWM_Value,1 ,12
ENG128947-ENG128961-EC_indicator_dimming_curve_manipulation-Point_2_Bus_Value,51 ,12
ENG128947-ENG128962-EC_indicator_dimming_curve_manipulation-Point_2_PWM_Value,4 ,12
ENG128947-ENG128963-EC_indicator_dimming_curve_manipulation-Point_3_Bus_Value,75 ,12
ENG128947-ENG128964-EC_indicator_dimming_curve_manipulation-Point_3_PWM_Value,15 ,12
ENG128947-ENG128965-EC_indicator_dimming_curve_manipulation-Point_4_Bus_Value,99 ,12
ENG128947-ENG128966-EC_indicator_dimming_curve_manipulation-Point_4_PWM_Value,80 ,12
ENG128947-ENG128967-EC_indicator_dimming_curve_manipulation-Point_5_Bus_Value,100 ,12
ENG128947-ENG128968-EC_indicator_dimming_curve_manipulation-Point_5_PWM_Value,80 ,12
ENG128954-IDE80040-FA_Parameters-Analysis 40,0 ,18
ENG128954-IDE80041-FA_Parameters-Analysis 41,500000 ,18
ENG128954-IDE80042-FA_Parameters-Analysis 42,105 ,18
ENG128954-IDE80043-FA_Parameters-Analysis 43,118 ,18
ENG128954-IDE80044-FA_Parameters-Analysis 44,0 ,18
ENG128954-IDE80045-FA_Parameters-Analysis 45,0 ,18
ENG128954-IDE80046-FA_Parameters-Analysis 46,250 ,18
ENG128954-IDE80047-FA_Parameters-Analysis 47,160 ,18
ENG128954-IDE80048-FA_Parameters-Analysis 48,5 s,18
ENG128935-IDE80020-FRTB_Parameters-Analysis 20,500 ms,26
ENG128935-IDE80021-FRTB_Parameters-Analysis 21,1200 ms,26
ENG128935-IDE80022-FRTB_Parameters-Analysis 22,1600 ms,26
ENG128935-IDE80023-FRTB_Parameters-Analysis 23,2000 ms,26
ENG128935-IDE80024-FRTB_Parameters-Analysis 24,1600 ms,26
ENG128935-IDE80025-FRTB_Parameters-Analysis 25,2000 ms,26
ENG128935-IDE80026-FRTB_Parameters-Analysis 26,417 ms,26
ENG128943-HBOT_Parameters,100 ,1
ENG128945-IDE80180-LLD_Parameters-Analysis 180,115 ,4
ENG128945-IDE80181-LLD_Parameters-Analysis 181,125 ,4
ENG128937-IDE80090-MD_Parameters-Analysis 90,150 km/h,8
ENG128937-IDE80091-MD_Parameters-Analysis 91,70 km/h,8
ENG128937-IDE80092-MD_Parameters-Analysis 92,40 km/h,8
ENG128937-IDE80093-MD_Parameters-Analysis 93,80 km/h,8
ENG128950-IDE80110-PSD_Parameters-Analysis 110,10 s,10
ENG128950-IDE80111-PSD_Parameters-Analysis 111,1 s,10
ENG128950-IDE80112-PSD_Parameters-Analysis 112,100 m,10
ENG128950-IDE80113-PSD_Parameters-Analysis 113,200 m,10
ENG128950-IDE80114-PSD_Parameters-Analysis 114,2 s,10
ENG128950-IDE80115-PSD_Parameters-Analysis 115,100 m,10
ENG128950-IDE80116-PSD_Parameters-Analysis 116,250 m,10
ENG128950-IDE80117-PSD_Parameters-Analysis 117,1 s,10
ENG128950-IDE80118-PSD_Parameters-Analysis 118,150 m,10
ENG128950-IDE80119-PSD_Parameters-Analysis 119,70 km/h,10
ENG128946-IDE80185-Village_Detect_Parameters-Analysis 185,254000 ,27
ENG128946-IDE80186-Village_Detect_Parameters-Analysis 186,350 ,27
ENG128946-IDE80187-Village_Detect_Parameters-Analysis 187,45000 ,27
ENG128946-IDE80188-Village_Detect_Parameters-Analysis 188,9 ,27
ENG128946-IDE80189-Village_Detect_Parameters-Analysis 189,4 ,27
ENG128946-IDE80190-Village_Detect_Parameters-Analysis 190,174000 ,27
ENG128946-IDE80191-Village_Detect_Parameters-Analysis 191,9 ,27
ENG128946-IDE80192-Village_Detect_Parameters-Analysis 192,2000 ,27
ENG128946-IDE80193-Village_Detect_Parameters-Analysis 193,5000 ,27
ENG128946-IDE80194-Village_Detect_Parameters-Analysis 194,3 ,27
ENG128946-IDE80195-Village_Detect_Parameters-Analysis 195,3 ,27
ENG128946-IDE80196-Village_Detect_Parameters-Analysis 196,28 ,27
ENG128946-IDE80197-Village_Detect_Parameters-Analysis 197,48 ,27
ENG128946-IDE80198-Village_Detect_Parameters-Analysis 198,100 km/h,27
ENG128939-VOS_Parameters,58 km/h,2
ENG128936-IDE80030-WG_Parameters-Analysis 30,100 ,3
ENG128936-IDE80031-WG_Parameters-Analysis 31,100 ,3
ENG128936-IDE80032-WG_Parameters-Analysis 32,100 ,3
ENG128933-XCP_Settings,not activated ,1
Elapsed Time: 00:09
This way should work like a charm.🧙‍♂️
- Fuses SB34 and SB36 should be 15 A since you have LED headlights installed (also for halogen headlights). Those of 7.5 A are when Bixenon headlights are installed (shutters only).
Note: these fuses only have the 'jumper function' to facilitate the installation, since the diagnosis and protection of the electrical system for the high beams is managed by the BCM.
- The previous BCM T73a/62 retrofit wire should have been insulated and then run a new wire from T41/40 to T73a/62.
- Since the RVC and the high beam activation signal (T41/39 - T73b/8) work with a +30 signal, you must check the fuses/wires/splices that feed both. You are the only one who knows how you did this installation, I'm afraid it's also related to the Alarm Horn (H12) and Sensor for Anti-Theft System (G578) Autoscan faults. Although it may also be related to the fact that you did not have the HBA module/mirror coded, since the activation and deactivation of the RVC is through the new CAN lines of the HBA mirror.
- New BCM coding (test): :arrow: 2CB02BBF48E1240093380E007CCB1FD0C0C0670F60CD39E0210000030820
As it is a good spring Sunday I send you an image of the two of us who have been developing these previous thoughts,
... to inspire you some confidence.
favi
Drives: 6R
Post by favi »
ciclo wrote: Sun Mar 26, 2023 7:02 am Address 20:
IT WORKS !!! Tested on the highway and the country road.
ciclo wrote: Sun Mar 26, 2023 7:02 am - Fuses SB34 and SB36 should be 15 A since you have LED headlights installed (also for halogen headlights). Those of 7.5 A are when Bixenon headlights are installed (shutters only).
High Beams - work! 7.5 A changed for 15 A
ciclo wrote: Sun Mar 26, 2023 7:02 am - The previous BCM T73a/62 retrofit wire should have been insulated and then run a new wire from T41/40 to T73a/62.
I did it.
I looked at the problem. My RVC closes, but around 5-10 minutes after the vehicle closes (click "lock" on the key).
44 FUSE BOX is for? I have empty, but when i did BCM MAX i had there 5 A.
SB44
Power signal +30 for the alarm horn and ultrasonic sensors, but it is possible that you also used it for other retrofits.
:arrow: viewtopic.php?p=543913#p543913 (🤷‍♂️).
Enjoy the HBA 😎, in addition to providing safer driving you avoid having to be aware of using the lever for the high beams. Lately I've been driving our ex-9N3 and having to use the high beam lever is a pain.😄
favi
Drives: 6R
Post by favi »
New front bumper!
New rims :)
Image Image
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Rocking !!!
with PDC and Headlight washers :)
Nice look. 8) 👍
The front fog lights + SCLs disappeared... 😄
favi
Drives: 6R
Post by favi »
ciclo wrote: Mon Sep 04, 2023 6:57 am Nice look. 8) 👍
Yes but... comming soon back :)
