Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: Auto lights retrofit
Post by VASILEIOS1972 »
ciclo wrote: Mon Sep 23, 2019 6:25 am To display the MKE, and the Assistants menu, your IC needs the 0709 SW. It is possible to fix it in your current IC eeprom without touch the IMMO part.
Madwarlock (Slavik) can fix it if you read your IC eeprom and send him the eeprom file.
Get in touch with him, he already knows your case.
The cheapest way to read/write your IC eeprom is with the CH341A programmer. (search on google, youtube, aliexpress, etc...)
Note: (current IC SW)
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305 .............(MKE not displayed, no Assistants menu with this SW)
Coding: 120C01
Shop #: WSC 44700 231 72242
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C87992702-8078
Thank you Fernando for the information.
I have already send pm in Madwarlock
Best regards
Vasilis
FYI:
Your wiring (adapter for 6R Dimmer/HRR) and the other wires are already made.
I'm waiting for a connector to arrive. I guess tomorrow will come.
You must do the following steps:
First step:
- Note: in this step you should not have installed any wire for the J745 unit.
Check that the 6R Dimmer / HRR works. Report the result.
Second step:
Do the installation of the J745 unit, in the following images some of the wires that I have made for you as a favor.
I will contact you by email for payment and shipping processes. (will be the same as the other time)
VASILEIOS1972
OK Fernando I am waiting
Footwell lights (OEM)
T73a/65 + ve
T73a/4 -ve
These wires are present in the dome lights and therefore in the A-pillar, which is a better place than the BCM to make the splices.
It is not necessary to add a fuse, it is already present in the original installation.
Ambient lights
Use LED lights with very low consumption, add a fuse (mandatory).
:!: This consumption is added to the LEDs/lights of the switches. :!:
+ ve. where indicated in the previous image for Adapter (6R Dimmer/HRR).
- ve. any ground point near to the added lamp.
:arrow: In no case requires new coding.
VASILEIOS1972
Good morning Fernando
I have copy the information's for foot lights in the right section.
Do you want to begin this dialogue here?
viewtopic.php?f=41&p=561397#p561397
Good morning Vasileios, it is not necessary to dialogue anything in that thread because this is your thread for everything you want to do in your Sk Fabia VRS 2012.
This way it is easier for you to receive help, due to autoscans, mods, etc. and also follow the evolution of your car.
If you want to install the footwell lights or the Ambient lights do exactly as indicated in my previous post.
Everything will work great. :wink:
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
W8 dome lights
:arrow: viewtopic.php?f=41&t=73673&p=561452#p561452 ... Seem right.
VASILEIOS1972
Hello my friend Fernando
Two issues from the beginning
1) at night head light switch in place auto
un locking the car lights opened
2) at the same time locking the car lights don't open
3) locking the car with open windows, windows closed
4) unlocking the and press continuesly the open button
windows don't open
Is it something about coding?
Best regards
Vasileios
VASILEIOS1972 wrote: Tue Oct 01, 2019 4:05 pm Hello my friend Fernando
1 Leaving home function ... is correct.
2 Coming home function ... semi-automatic function, once you remove the key from the ignition switch you must pull from the HB stalk once.
When you open the door the lights will come on.
VASILEIOS1972 wrote: Tue Oct 01, 2019 4:05 pm 3) locking the car with open windows, windows closed
windows don't open
Best regards
Vasileios
I never touch the BCM coding or subsystems other than RLS for central locking so it must be the natural behavior of your window regulator motors/central locking from the factory.
VASILEIOS1972
No for windows, before bcm max when press continuesly the open key button the windows opened too.
Regards
Vasileios
You may have to set the 'comfort function' again with the window switches. Read the user manual.
VASILEIOS1972
Good morning my friend Fernando
You have absolutely right about the comfort function
Best regards
Vasileios
(⌐■_■)👍
Reading the instructions/manuals does not seem to be one of your best hobbies.😁
VASILEIOS1972
