Locked
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
I've just ordered a new BCM... Hopefully it will arrive Friday...
BTW - many posts ago I've tried to install a 6C climatronic control unit but it did'nt work. Question is if will do now? Also a new dash from a 6C... Hmm.. Have to test when the BCM is working :-)
I remember it perfectly.
We have many interesting projects from now ... :wink: :lol:
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
How did you order your BCM? I've just talked to my lokal VW dealer (in Germany but never mind). They sold me that I've can't order without a VIN number.
I bought here http://www.carparts-pros.com/index.php and always provide the VIN. No problem.
They request the order to the official dealer. Good service and competitive price for new parts. :wink:
CNK
Drives: 6R
Post by CNK »
How you retrofit instrument cluster? Local VW dealer from my city said, that they can't code other instrument cluster in authorised service.. I have only VCDS.. :cry:
CNK wrote:How you retrofit instrument cluster? Local VW dealer from my city said, that they can't code other instrument cluster in authorised service.. I have only VCDS.. :cry:
When the instrument cluster is new and compatible any VW dealership can do this work, in fact, my instrument cluster was installed at a VW dealership.
By the way, I fear (no sure) that for HBA I will have to update the software on my instrument cluster, wherever this is possible. :?
T6
Address 17: Instruments (J285) Labels: None
Part No SW: 7E0 920 870 L HW: 7E0 920 870 L
Component: KOMBI H05 1007
Coding: 170F01
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 3228DB8665D2D5AF3F-8066
My intrument cluster
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 356B399494BFB7B6775-8060
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
ciclo wrote:I bought here http://www.carparts-pros.com/index.php and always provide the VIN. No problem.
What VIN number did you provide? From your own car or?
diskoboy wrote: What VIN number did you provide? From your own car or?
My VIN. Anyway you'll receive the control units uncoded (Basic coding from factory)
The important thing is to correctly specify the part number according to ETKA.
For example:
7E0937090 ... No
7E0937090 Z4Y ... Yes
Added here: http://www.uk-polos.net/viewtopic.php?f ... 59#p499959
Throughout this week I have been testing various combinations of encodings (hundreds :lol: ) for BCM but I have not been able to find the right combination. Honestly, it's a very difficult job without having any information on long coding helper or UDS Adaptation channels ... Image
Next week (or when possible) I will go to official dealer to try to find a solution to the encodings, Adaptation, or update software (ODIS engineering).
This HBA system is very new on this type of BCM.
Is it maybe a problem with the coding of the IC or the camera?
Coding IC is OK, maybe update software.
Coding camera is right for xenon-lhd, same coding for scirocco 2015-16, but...
Many doubts at this time, we will see that says ODIS program...
By the way, I discovered new and interesting functions of this BCM that we will see over time. :wink:
Here's a challenge for you: retrofit brake pad wear indicators :mrgreen:
Such improvement is very easy iichel, parts in ETKA and the wire connected to the instrument cluster T32/15. (enable with long coding helper on instruments Byte1 Bit0)
The problem is that almost always I do an efficient driving and never have had to change the brake pads due to wear... I drive with a lot of calm in the cities. :lol:
I'm looking forward to seeing the changes made by the VW dealership over Adaptation of BCM or Instrument Cluster for the HBA. Tomorrow I will call to the vw dealership for a programming session. Image
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
ciclo wrote:Coding IC is OK, maybe update software.
What is the part no for the camera? There is also a camera starting with 7E....
PR- 4L6+8G1
With different retaining plate, light sensor...
Transporter T6 (2016)
7E0857511C
7E0857511E ... Multivan "Highline" +A8Z
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 7E0 857 511 C    HW: 7E0 857 511 C
   Component: FLA           H09 0002
   Revision: AA001001
   Coding: 040400E200000000000000
   Shop #: WSC 02739 790 50316
   VCID: 2A18C3E64D029D6F87-807E
With the same retaining plate, light sensor...
Scirocco (2016)
1K8857511E
Golf (2013)
5K0857511 B,C
With this mirror I'll try.
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 1K8 857 511 E    HW: 8J0 857 511 C
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 0201856B74745D545420363E01
   Shop #: WSC 00020 790 00000
   VCID: 346D049097C5AEBE40B-8061
Locked
