Page 99 of 333
Posted: Sun Oct 11, 2015 8:39 am
by sanders
Will do ciclo,
Could it be the lightswitch? Because when I push the knob to disengage the switch the green light from the foglight turnsters red as it should be. I check the wiring again hope to find something.
Verstuurd vanaf mijn GT-I9505 met Tapatalk
Posted: Sun Oct 11, 2015 8:57 am
by ciclo
Then, in that case, post here the coding of your BCM & RLS, only.
Posted: Sun Oct 11, 2015 9:02 am
by sanders
i opened a new topic with the full vcds scan ciclo
saw your post to late but if you like i could post it her also
Posted: Sun Oct 11, 2015 9:03 am
by sanders
scan from bcm with rls
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 026120185
Coding: 3AB02BBF08F32400B3380FB06EAB0ED95F80612F7E862441200000000000
Shop #: WSC 00788 648 00255
VCID: 418F3546D8FEA016D43-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 270812 05 54 0403
Coding: 06302D
Posted: Sun Oct 11, 2015 10:23 am
by ciclo
Posted: Sun Oct 11, 2015 2:33 pm
by sanders
what i did find ciclo, is that when i was removing the pin out of the 17 pin connector i didn't had a pin on position three (daylight).
but if i check the schematic on etka don't i need from pin 8 on 17 pin connector a wire thru pin 7 on bcm t73a? i saw on your schematic that it is only for retrofit?
greetz
Posted: Sun Oct 11, 2015 4:07 pm
by ciclo
sanders wrote:what i did find ciclo, is that when i was removing the pin out of the 17 pin connector i didn't had a pin on position three (daylight).
greetz
http://www.uk-polos.net/viewtopic.php?f ... 43#p500543
Posted: Thu Oct 15, 2015 2:58 pm
by iichel
how come your AUX port has a little cover on it?
Posted: Thu Oct 15, 2015 4:22 pm
by Mart!n-GTI-DK
iichel wrote:how come your AUX port has a little cover on it?
Isn't that how they all are???
Posted: Thu Oct 15, 2015 4:30 pm
by iichel
mine looks like this:
Posted: Thu Oct 15, 2015 4:44 pm
by CNK
I also have a AUX port like iichel:
Posted: Thu Oct 15, 2015 6:28 pm
by ciclo
I think it's pretty clear ...
It is a business strategy that affects my brain.
Or also it's a simply a matter of chastity
... to prevent FOD. Foreign Object Damage.
But there is always a good solution for all ...
Posted: Thu Oct 15, 2015 6:39 pm
by iichel
the new port is part number 6R0035724 and it looks like a straigt fit. should cost around 10 euros.
Posted: Thu Oct 15, 2015 7:37 pm
by ciclo
Yes, it uses the same connector as the old one (5M0035714).
Posted: Fri Oct 16, 2015 3:19 pm
by RUM4MO
"FOD" yes used a lot in aerospace industries, we have a guy that gets called FOD, but that stands for "F" off Dave, though stolen from the original use of FOD! As you might guess, he was not everyone's best friend!
