what is the difference between the :
PHILIPS BLUE VISION ULTRA PLUS and the
PHILIPS BLUE VISION
which are the best ?
thanks
New Xenon type bulbs
I bloody well have. While testing a Xenon it started to roll off the surface, so I had the bright idea to catch it. I didn't smash it, but I did get mildly eletrocuted and burned in the process.Scorpio1 wrote:
I have never felt a xenon lamp that is hot or even warm, where as a halogen lamp gets hot.
Correct. The most powerful filament bulbs with E marking are Piaa. Here's some.KarlM wrote:The way i see it is anything that is TUV approved and E marked is perfectly legal
Do not use them "Note that these bulbs do not have a UV film coating on them as to allow the maximum possible output of light. " your polo headlight cover is polycarbonate which will craze with the UV at that temperature. As it is with VAG bulbs, the reflector bubbles at the top - go see yours!yeha wrote:Correct. The most powerful filament bulbs with E marking are Piaa. Here's some.KarlM wrote:The way i see it is anything that is TUV approved and E marked is perfectly legal
