UK-POLOS.NET - THE VW Polo Forum • Black Plastic Car key - Page 2
Page 2 of 3
Posted: Sat Mar 18, 2006 11:53 pm
by inder
Yep, looked it up to confirm, ask for this part:
6N0 837 216 B INB
emergency key with variable
code transponder
* key code number and/or *
* chassis number must be *
* quoted when ordering *
inner profile
:D
Posted: Wed Mar 22, 2006 2:17 pm
by laura_fairy_22
i didnt think you can start the car with it?? only open the doors & glovebox??
Posted: Wed Mar 22, 2006 4:51 pm
by inder
laura_fairy_22 wrote:i didnt think you can start the car with it?? only open the doors & glovebox??
It will start the car, as it has the immobilser transponder chip inside - just like its big brother normal key :)
Posted: Wed Mar 22, 2006 4:53 pm
by ModifiedMadness
While we're on the subject of keys, this has probably been asked before but I'll ask again.
Are we able to have Flip key like the newer Audi's and some of the Golf's?
Is it something that we can get from VW?
Posted: Wed Mar 22, 2006 5:11 pm
by inder
MM - yes it is possible in theory.. as they both use the 433.92mhz freq. to transmit to the car, so you would need the flip key programmed to car also once its been cut
:?: 8)
Posted: Wed Mar 22, 2006 5:26 pm
by ModifiedMadness
Is that something VW could sort out for me, if I flashed the cash?
Posted: Wed Mar 22, 2006 5:31 pm
by Reeyad
ModifiedMadness wrote:Is that something VW could sort out for me, if I flashed the cash?
Theres a guide to doing it yourself on club polo I believe, il see if I can find the link
Posted: Wed Mar 22, 2006 9:30 pm
by nickpolo
i'd love a flip key - but didnt think it was possible, i thought you had to break a flip key and put bits from yours in and stuff, if thats not the case - i want one!!
Posted: Wed Mar 22, 2006 9:38 pm
by Reeyad
nickpolo wrote:i'd love a flip key - but didnt think it was possible, i thought you had to break a flip key and put bits from yours in and stuff, if thats not the case - i want one!!
Thats the guide I actualy saw it was in pdf format I cant find it now. It involves breaking a flip key and replacing the bits from your key to it.
Posted: Wed Mar 22, 2006 9:39 pm
by pettsy
ModifiedMadness wrote:Mine is as well, and the radio code.
Not that I'll need it, but would be nice to have.
the original stereo should re-code itself from the ecu :wink:
Posted: Wed Mar 22, 2006 11:30 pm
by inder
Yep that guide shows you how to DIY one, but if you want a brand new non-butchered one, then can order key from VW I recon.
(DIY involves breaking up your normal key, removing transponder chip, breaking open the flip key, putting transponder chip in, removing blade from normal key and drilling a hole in it for the roll pin in the flip key etc..)
Posted: Thu Mar 23, 2006 12:24 am
by ModifiedMadness
What kind of money we talking from VW for one?
Posted: Thu Mar 23, 2006 12:36 am
by inder
Not sure m8, £100? :shock:
DIY would be cheaper I guess. or maybe find an uncut flip key on ebay cheaper? then have it cut and coded?
Can give you part to ask dealer?
Posted: Thu Mar 23, 2006 7:53 am
by nickpolo
i was sure the whole point of having to break they key and do it that was was because the flip keys operated on a different frequency, so you needed to butcher one and put your gubbins in there so it worked?
Posted: Thu Mar 23, 2006 9:34 am
by inder
but the one I found listed, is the same freq as the key used in the polo, 433.92 mhz
was listed for a golf 2000
