UK-POLOS.NET - THE VW Polo Forum • Polo only giving me 105 bhp, dyno results attached - Page 2
Page 2 of 3
Posted: Sun Jul 02, 2006 10:17 pm
by jezmk4
whoops
you sure its got a Gti engine in it?
Posted: Mon Jul 03, 2006 1:31 am
by Mouse_GTI
I'd be flaming!
Posted: Mon Jul 03, 2006 7:10 pm
by andyg
I'd go down to the VW garage I got it off and I would batter the salesman to death with the VW tire iron if that was the case.
Posted: Tue Jul 04, 2006 10:01 pm
by hex_da_rex
[quote="Del_GTi"]Here's mine mate. Putting out 131.7bhp standard.
What is the mileage on your polo? Just out of interest....
Posted: Tue Jul 04, 2006 10:29 pm
by Del_GTi
55k mate. 8)
Was about 51k when the rolling road was done.
Posted: Tue Jul 04, 2006 10:32 pm
by andyg
Mines 64k btw, oil change every 5k
Posted: Thu Jul 13, 2006 10:01 pm
by andyg
Found out what the problem is!
Apparently there is a short in the circuit that controls the VVT, so its giving off errors such as cam speed sensor etc and the VVT isn't working properly/if at all.
So if anyone on here is experiencing crap power and/or has a power curve like mine then it could be that!
Posted: Thu Jul 13, 2006 11:39 pm
by jezmk4
andyg wrote:Found out what the problem is!
if you need any of the sensors mate, ive got all of them
Posted: Fri Aug 04, 2006 4:12 pm
by andyg
Well, I got a bill, but its not fixed :(
I could do with some help, I took it to JBS in chesterfield and they found some fault codes relating to cam speed sensor etc. They traced the problem to a short. Fixed the short and replaced the fuse (which apparently runs the VVT) The fuse is still intact, but the car is still putting out 100bhp (took it to the rollers last week).
Yeh mate, how much do you want for them? could you talk me through how the VVT works on the polo, i mean what switches it on? I assumed it would be the crank speed sensor or some solenoid activated by oil pressure.
Any other advice would be apprieciated, If I could get it to 120 bhp id be happy enough, 100 is a bag of s**t really :(
Posted: Fri Aug 04, 2006 4:21 pm
by ---Carl---
id be gutted :(
hope u get this sorted !!!!!
Posted: Fri Aug 04, 2006 7:03 pm
by jezmk4
andyg wrote:Well, I got a bill, but its not fixed :(
Any other advice would be apprieciated, If I could get it to 120 bhp id be happy enough, 100 is a bag of **** really :(
hi man, where abouts are you from?
as from my logic, the vvt is operated by a solenoid that controls oil flow to the tappets, the big thing at the left of the rocker cover, thats the first thing i would try on these engines, aswell as having the engine compression tested, tbh, most things with this engine should pop up on vagcom
how about this for something blatent, you sure its firing on all cylinders?
ive seen polo gti coil units snap terminals, and i was bloody surprised how smooth my engine ran on only three!!
(seems very unlikely thought, would lose alot of power i would think)
the crank speed sensor, i dont have a spare unfortunatly, i have the other cam sensor
Posted: Fri Aug 04, 2006 10:55 pm
by andyg
I'm in west yorkshire.
I got the compression and timing tested, which are both fine. I feel a lag of power throughout the rev range, the car has always felt boggy when setting off but I thought everyone else was the same.
JBS (where I took it to get fixed) rolling road is broken and they have no idea when it will be back up and running. Which i must say is a bit cheeky, when their site has no mention of that. If i had of known it was broken I would have never taken it down in the first place. Not to mention how uninterested they were when I called back with the problem, on both occasions. £200 squid down the drain. My other alternative is to take it to the dealers and get ready to be shafted :(
Cheers for the info about the VVT jez.
