UK-POLOS.NET - THE VW Polo Forum • Mud Flaps Part Number - Page 2
Page 2 of 2
Posted: Sat May 05, 2007 12:39 pm
by GTILass
ticki wrote:
pootas wrote:
ticki wrote:6N0075101A - Rear Mud flaps
Hmmmm I have a set of mudflaps with that part number but they don't fit on my Gti....The screw holes on the mudflaps don't match the holes pre drilled in the arches....
Your supposed to create new holes with the self taping screws included. Its all in the instructions.
the instructions i have dont have words :?
Posted: Sat May 05, 2007 12:56 pm
by pootas
GTILass wrote:
ticki wrote:
pootas wrote: Hmmmm I have a set of mudflaps with that part number but they don't fit on my Gti....The screw holes on the mudflaps don't match the holes pre drilled in the arches....
Your lucky you have instructions!! I don't have any...
Posted: Sat May 05, 2007 1:01 pm
by Mouse_GTI
I thought they screwed on top of the arch liners
Posted: Sat May 05, 2007 2:43 pm
by pootas
Got them on now....Just used self tappers to secure the mud flaps to the arch lining...
Posted: Sat May 05, 2007 8:15 pm
by polo_gti21
on the rears you need to use an existing bolt plus the self tappers and make a hole for the nut and bolt thing and the fronts you need to use the existing torx25 screws and the clip that comes in the box to hold on the arch. mine scrape goin up slight slopes as its sittin low :D
Posted: Sun May 06, 2007 12:37 pm
by pootas
polo_gti21 wrote:on the rears you need to use an existing bolt plus the self tappers and make a hole for the nut and bolt thing and the fronts you need to use the existing torx25 screws and the clip that comes in the box to hold on the arch. mine scrape goin up slight slopes as its sittin low :D
Might seem like a stupid question but...
On the front flaps there is a flap of rubber where the clips fit...
Now does the flap of rubber go inbetween the arch and the arch lining and then the metal clip on top?? At the moment I have the rubber flap just folded over and the metal clip behind the arch and lining....
Posted: Sun May 06, 2007 6:22 pm
by polo_gti21
ive just moved the lining back a bit the rubber flap then folds round the inside of the arch to protect paint and the clip goes over that.
Posted: Sun May 06, 2007 7:31 pm
by GTILass
Mouse_GTI wrote:I thought they screwed on top of the arch liners
i dont have liners
:cry:
