Page 2 of 2
Posted: Sun Jul 15, 2007 3:55 pm
by Dan_Gti
Tim_GTi wrote:Just had a thort, is the halfords caliper paint brush or spray? if its brush isn't it jsut easier to mask up unwanted areas and paint the calipers carefully still fully attached? or if not to just remove them from the disc but without pulling out the brake cable (to save having to bleed it n all that?)
The Halfords kit comes with braker cleaner, tin of paint and a tin of paint hardener. You need to use a small brush (doesn't come with kit) to apply the paint. I'm no artist but found it really simple applying two coats to all the calipers. As long as your careful and don't allow any drips to fall onto the pads etc it will be fine.
Other people have sprayed their calipers but to do this you would need to completely remove them as the slightest bit of paint in the wrong area could lead to braking issues......
To completely remove the calipers you would need to disconnect the brake hoses which involves a whole lot more work putting them back together (bleeding etc)
Posted: Sun Jul 15, 2007 7:40 pm
by Tim_GTi
Dan_Gti wrote:Tim_GTi wrote:Just had a thort, is the halfords caliper paint brush or spray? if its brush isn't it jsut easier to mask up unwanted areas and paint the calipers carefully still fully attached? or if not to just remove them from the disc but without pulling out the brake cable (to save having to bleed it n all that?)
awseme so all i need is the halfords kit which will last two coats on each caliper? and i don't actually have to take em off? how much does it cost? sorry, just want to get it 100% right lol
Posted: Sun Jul 15, 2007 9:55 pm
by Dan_Gti
Tim_GTi wrote:Dan_Gti wrote:Tim_GTi wrote:Just had a thort, is the halfords caliper paint brush or spray? if its brush isn't it jsut easier to mask up unwanted areas and paint the calipers carefully still fully attached? or if not to just remove them from the disc but without pulling out the brake cable (to save having to bleed it n all that?)
The kit will give you easily 2 coats per caliper. I had loads left over and I didn't go lightly on the amount for each coat
It costs £25 which is a bit expensive but you get a can of brake cleaner in the pack which is pretty good. Buy a decent brush about a 1-2cm wide.
Posted: Mon Jul 16, 2007 8:21 am
by Tim_GTi
cheers dude. its guna go dwn this weekend!
