Page 2 of 3
Posted: Tue Jul 24, 2007 8:58 pm
by shantybeater
im up for that too, been trying to get rid of a metallic whirring sound for ages!
Posted: Thu Jul 26, 2007 12:12 pm
by Mouse_GTI
Anyone post up a DIY guide?
Posted: Thu Jul 26, 2007 12:31 pm
by alexperkins
No need - its on the back of the can
Posted: Thu Jul 26, 2007 1:32 pm
by Rupy
one of you can do mine...i'm too busy at the min!
Free beer to whoever does it
Posted: Thu Jul 26, 2007 2:29 pm
by Mouse_GTI
I'm gonna look in Halfrauds for carb cleaner and some BMC filter cleaner, then put up a double DIY guide
Posted: Thu Jul 26, 2007 6:10 pm
by Tim_GTi
sounds good mouse! (just dropping a post so i can keep track of the progress on my emails haha!!)
Posted: Fri Jul 27, 2007 8:11 am
by Mouse_GTI
It was total easy but I'll still post up some pics when I get home. It was quite dirty. Car doesn't feel any different, maybe just a tiny tiny bit more smooth
Posted: Fri Jul 27, 2007 10:29 am
by loud
the throttle body being cleaned is so simple that it hardly even needs a guide. Here is one i wrote for someone ages ago which they understood perfectly:
take off your air box / induction kit
the throttle body is the metal circle on the right that opens with a butterfly
spray carb cleaner on a cloth and wipe it and spray carb cleaner in the guts of it, get in to fiddly bits with cotton buds.
if you reach round the back you can find the cable which opens and closes the throttle body, makes it easier to clean
you might need to reset your ecu if your idling too high or over revving after doing this.
I just drove ~100 miles and my idle sorted itself out without an ECU reset
Posted: Fri Jul 27, 2007 6:18 pm
by Tim_GTi
loud wrote:the throttle body being cleaned is so simple that it hardly even needs a guide. Here is one i wrote for someone ages ago which they understood perfectly:
So is all this done with the car switched off?
Posted: Fri Jul 27, 2007 7:28 pm
by Mouse_GTI
Clean it first as normal then switch it on and get someone to give it blasts of throttle. Keeping the throttle constant won't open the valve
Posted: Fri Jul 27, 2007 7:30 pm
by loud
yea it was done with the car switched off cos u can grab the cable that opens the butterfly valve through the back so holds it open much better than someone hammering on the throttle non-stop
Posted: Fri Jul 27, 2007 7:44 pm
by alexperkins
you must remember to not flood the carb with the throttle body open with the cleaner tho - or the car wont start!!!!
Posted: Fri Jul 27, 2007 8:30 pm
by Mouse_GTI
You just have to give it little bursts. My car cut out twice but was ok again afterwards
Posted: Sat Jul 28, 2007 9:20 am
by Bepe
alexperkins wrote:you must remember to not flood the carb with the throttle body open with the cleaner tho - or the car wont start!!!!
carb? i didnt think these polos had carbs........iam lost
Posted: Sat Jul 28, 2007 10:12 am
by alexperkins
Whatever throttle body
meh!
