6n & 6n2 Suspension
polopowah
- Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
heh yeah i remember when you first joined! asking all the questions that I asked when i first joined :ph4r1s wrote:huh?sorted wrote:I tried to fit Mk4 springs to a Mk5 with Mk4 top mounts - this did not work. In the end - i heated the top of the spring up and pulled it out more as the Mk4 6n is a more tight O at the top than the Mk5 6n2 which is more (_) shapedI don't understand why you used mk4 top mounts, i'm sure the front springs on the mk4 are a different sort of shape but if you had used a mk5 top mount would it not have worked?
Where'd you go to Ben? i remember you being on this forum quite a bit back in the day? and i remember you answering all the stupid questions i had
your car has certainly come along way and im envious over your bonnet bra, how much did that set you back? I really want one
-Ben-
