Posted: Wed Dec 05, 2007 9:40 pm
My car only has 26000 miles on it and trust my thrust bearing is noisy car and clutch perform well even tho it may be worn slightly
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Hi ClaireTDI_Burd wrote:As you know there is quite a lot of Tdi's with this problem mine being one of them and personally im not going to fix it till something stops working in my car, I spoke to a Vw guy and he suggested that where the thrust bearing sits it doesnt sit tight enough against something so thats what lets it have the room to spin and then hear the noise. Did your clutch/gearbox not perform well or that before you started replacing the bits? The noise is annoying but ill put up with it cos my car is going really good the now.
Claire
That's wierd, that it has already had a flywheel change! Maybe the previous owner has had it remapped and that along with rough driving ended up trashing the original DMF. The conversion back to solid flywheel seems to be the chosen route for quite a lot of remapped cars, but it is always acknowledged that the pay-off for haveing a ruggedised clutch was increased noise mainly at tick over, ie in neutral with clutch out. Glad you got it sorted out - now remember to protect that new DFM, I think that means no "hard launches" or shovel fulls of throttle at low speed and high gears.KO wrote:Well car is stripped in the garage, and has already had a new flywheel and clutch fitted...so they now think it's the gearbox...which was sent the gearbox specialist who says its fine but will change a few bearings inside. the only thing they said was that it has a solid flywheel ( i'm assuming this means a single rather than a dual mass flywheel) setup. the only thing i can think of is replace it with the dual mass flywheel kit from LUK that i supplied to them...
your thoughts please......![]()
Hey RUM4MO trust me no hard launchesRUM4MO wrote:That's wierd, that it has already had a flywheel change! Maybe the previous owner has had it remapped and that along with rough driving ended up trashing the original DMF. The conversion back to solid flywheel seems to be the chosen route for quite a lot of remapped cars, but it is always acknowledged that the pay-off for haveing a ruggedised clutch was increased noise mainly at tick over, ie in neutral with clutch out. Glad you got it sorted out - now remember to protect that new DFM, I think that means no "hard launches" or shovel fulls of throttle at low speed and high gears.KO wrote:Well car is stripped in the garage, and has already had a new flywheel and clutch fitted...so they now think it's the gearbox...which was sent the gearbox specialist who says its fine but will change a few bearings inside. the only thing they said was that it has a solid flywheel ( i'm assuming this means a single rather than a dual mass flywheel) setup. the only thing i can think of is replace it with the dual mass flywheel kit from LUK that i supplied to them...
