Posted: Mon Jan 21, 2008 10:53 pm
i think my amp power wire is using that....kc wrote:best way to route the pipes if through the grommet where the bonnet latch will come through on LHD cars, plenty of room to play with
Probably the Worlds greatest Polo resource
https://uk-polos.net/
get rid then, excess weight, not neededdavid burton wrote:i think my amp power wire is using that....kc wrote:best way to route the pipes if through the grommet where the bonnet latch will come through on LHD cars, plenty of room to play with
that's why I was asking if you can get ones that convert the pressure to an electrical signal before sending it to the gauge.Gti_Lew wrote:get rid then, excess weight, not neededdavid burton wrote:i think my amp power wire is using that....kc wrote:best way to route the pipes if through the grommet where the bonnet latch will come through on LHD cars, plenty of room to play with
I drilled it out for the power cable - but maybe I've got the wrong end of the stick - I used the hole on the passenger footwell for this, and there was already a pipe through there (washer?), so that's why I had to widen it.kc wrote:mine uses that as a amp cable too cheif, but its only a 1mm vacuum that you need to get through and it will fit... unless your running 0awg power cable...... which in that case... it will still fit!!
