9N Headlight Question
Hamish
Post by Hamish »
RUM4MO has actually given me the answer i needed. There are no factory standard HID's that came as standard on a 9N polo.
Not the answer i wanted to hear, nevermind :(
shakt1 wrote: What are 'better' bulbs, iv got whatever they come supplied with from VW. What do you suggest and how much is it likely to cost me in total for the entire changeover?
Have a look at Autoexpress's test stuff, you're looking for bulbs (same type and wattage as standard) that give a whiter light and promise lots more light output. One thing is that these bulbs "burn" at a higher temperature so may not last as long as the standard "long life" bulbs currently fitted to your car. Having said that, the second set that I fitted to my wife's Polo 9N are lasting longer than the first set of the same type. Normaly you will get better deals on-line, so buy both dips and mains together to save postage - my tip would be to stick to mainstream players, ie Philips, Osram etc and avoid "special weather condition bulbs" as you are only after a lot more and whiter light output.
