is it just sleeping???
LogIK
Post by LogIK »
If I lived near you, I'd love to give you a hand with it, coz ive done this kind of thing before.
All else fails, you could fit your own alarm.
ereeiz
Post by ereeiz »
undo the alarm (horn shaped thing) from the car and have a good look at it. the key may be to turn the siren on or off. alternatively, look under the steering column area or generally hidden behind the dash for the little box of tricks that controls the alarm (more commonly known as the immobiliser :wink: . It may have a key hole for it there.
But if you dont have the FOB for it it's a waste of time 'cuz you can't arm or disarm it anyway! :roll:
DanW
Post by DanW »
But i could probably get one from sumwhere. even if it cost £100 for the key in the long term it would be worth it, in terms of insurance. Hmm I just gotta find the box-o-tirx sum where now.
I've got this under the passengers side too, standard?
[72 and 19]
pettsy
Moderator
Post by pettsy »
think those are standard. try looking behind the carpet on the passenger side footwell. thats where my alarm box (vag alarm!) is situated
Gilex
Drives: 6R 1.4 (2010) & 6R 1.2 TSI (2012)
Post by Gilex »
Yep those to are standard parts 72 and 19 are both relais thingies :lol:
19 is used by the front window wipers (is that the correct word ??)
number 19 does set the fixed interval setting.
I changed it with the number 99 (golfmk2/mk3) and I do now enjoy a programable time setting of the wipers :)
DanW
Post by DanW »
Gilex wrote:Yep those to are standard parts 72 and 19 are both relais thingies :lol:
Wooow! That could be quite cool, how do you mean programable?
There is a VAG box just above those relays, I'm sure that's whats connected to the wires in the front too. I'm sure I've broke something when I took it off. :roll: Whoops
Gilex
Post by Gilex »
It works the same way like in the Golf mk2/mk3, pull the wiper handle down to start the programming, a single wipe and up with the handle, and now just pull it down when you wish. so instead of the standaard 8 sec interval you can set your own desired timing.
that´s all :lol:
DanW
Post by DanW »
hey thats quite handy :) ,Might go and scrounge one from the scrappy :roll:
Tahrey1043
Post by Tahrey1043 »
Mines got a Moss alarm honker next to the washer tank as well, and a little LED by the screen heater switch... but that's had it's wires chopped at the light, and the cables pulled out at the honker. Don't know where the rest of the kit is. Perhaps they just went bad after a while (battery drain, going off at random etc)?? Think if we run a survey they may turn up to be quite common on old MkIIIs..
No key apart from the one I was given with the car (no key for the big yellow cast-iron steering lock, or locking fuel cap either - one of which can be operated with a house key and some jiggling, the other is just jammed open). Quite a mystery. Car runs fine..
Also found out today that the starter interlock is busted ie i can make the starter run with the engine going (found out by accident after stalling). Oops... o_O... well, the history seems clean and all, but maybe there was an attempted theft?
(HOW much for a new dizzy?!)
DanW
Post by DanW »
£21 from the scrappie, and £150 brand new from the dealers. (Guess which one I chose)
