What manifold do i need for my polo gti 2001 plate!
bristolgeezer
Post by bristolgeezer »
GTI wrote:does your raceland manifold sound tinny as after i had mine fitted it does im gonna get some exhaust wrap to see if that makes a difference
i couldnt tell you tbh cause i went from standard exhaust and manifold to stainless manifold and cat back exhaust so it sounds totally different!
ash.
Guest
Post by Guest »
ash.
cheers anyway mate
James
Trottagti
Post by Trottagti »
Cheers mate wicked pics i no its a hard thing lol, so where does the lamba probe go and do u have to move anything and remove the bumper???
brianpologti
Post by brianpologti »
I ve fitted one to my polo gti, first you might want to cut the little bit of tubing off (forgot on mine) ,dont think its used on gti, maybe some other fitting(for 1.4?), also you will have to make up a blanking plate for the other side, I also had to lengthen the wiring for the first lambo sensor, and you should/could (up to you :D ) also wrap the exhaust too, :D (mainly due to sound) I know other people will say to reduce engine bay temp etc, you will have to get the flange that comes in the kit welded to the cat, I did the whole job without the bumper removed, but the sump guard you might need to cut a bit, also I had to get the manifold/down bent a bit due to it being a bit to close to the sump, for my liking,
hope that helps
P.s the 'o' ring is the same as vauxhall one,
Trottagti
Post by Trottagti »
Top notch reply mate, exactly what i wanted to no! Love the forum lol, erm so after my 40mm drop n springs im thinkin a lovely wrapped manifold!! Cheers for the help!!!
Guest
Post by Guest »
how much heat wrap did you use and where abouts did u get it from
Tim_GTi
Post Whore
Post by Tim_GTi »
GTI wrote:how much heat wrap did you use and where abouts did u get it from
http://shop.agriemach.co.uk/product_inf ... 4243bb8d9e
http://motors.search.ebay.co.uk/heat-wr ... acatZ14761
brianpologti
Trottagti wrote:Top notch reply mate, exactly what i wanted to no! Love the forum lol, erm so after my 40mm drop n springs im thinkin a lovely wrapped manifold!! Cheers for the help!!!
make sure when you wrapping the exhaust that you fit the wrap wet, and you use locking wire ,
Trottagti
Post by Trottagti »
Yeah mate iv got black wrap at work iv done a few now on old pre war bentleys!! pp cars as such!
Gotta love a little bit of wire lol!
