Page 2 of 4
Posted: Tue Aug 05, 2008 9:47 pm
by Si_GTi
Alex - can you add the beep on my GTi at Edition, if you are coming? Pleeeease? :D
Posted: Tue Aug 05, 2008 9:51 pm
by alexperkins
Hehe maaaaybe! Pint ;) haha ye sure si
Posted: Tue Aug 05, 2008 10:10 pm
by owenjt
Yes, but you need an 'activated' copy of vag com to run the module adaptation.
Sorry what does this mean?
Posted: Tue Aug 05, 2008 10:12 pm
by Tim_GTi
Means a full working copy of the program.
Posted: Tue Aug 05, 2008 11:08 pm
by Overseer
I'm looking to get a VAG COM cable. Been searching on eBay and trying to find the right one. Some of them claim to come with the VAG COM software, this is what I want yeah?
Also what does it mean by "Supports VAG-COM 409.1 tools"?
Ta.
EDIT: Is this software compatible with Vista? and is a registered version difficult to get hold of? *Wink* *Wink*
Posted: Wed Aug 06, 2008 8:58 am
by neilGTI
I am using Vista and it was a right pain in the arse to get the cable to work with the laptop.
The program needs to be run in XP programme compatibility mode to work properly (XP compatibility comes part of Vista anyway).
Here is what i had to do to get it to work on Vista:
You have to download the driver from http://www.ftdichip.com/FTDrivers.htm (The V code driver)
Insert the lead into the USB port, go to my computer/properties/device manager, find the usb lead in the list, change the com port settings to 1, 2, 3 or 4 (vag com only looks for ports 1 to 4 and the USB ports on the PC are generally com port 6 upwards hence changing it.)
Then you have to run the XP compatibility program by going to Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
Then you need to select the com port in vagcom (Which was changed earlier on in the process to either 1,2,3 or 4)
The cable will then connect to the software and is ready to use.
Hope this helps :wink:
Posted: Wed Aug 06, 2008 9:05 am
by alexperkins
You also need to change the Baud rate in advanced settings to 9600 in the device manager bit aswell - this will ensure constant communication.
You shouldnt need XP compatibilty at all - I run mine with Vista and it works flawlessly with no backwards compatibility support.
Posted: Wed Aug 06, 2008 10:43 am
by neilGTI
alexperkins wrote:You also need to change the Baud rate in advanced settings to 9600 in the device manager bit aswell - this will ensure constant communication.
I havent made any changes to the baud rate on mine and seems to be working ok, havent had any problems at all and everything seems to be working as it should.
I ran the program on Vista before trying the backwards compatibility and i was having problems getting it pick up the lead, as soon as i used the xp compatibility program it worked fine :?
Posted: Wed Aug 06, 2008 10:45 am
by alexperkins
Certain aspects of vag com will require it to be set to that. Instrument cluster can play up as can other parts if thats not set correctly.
You know now for future reference ;)
Posted: Wed Aug 06, 2008 11:47 am
by neilGTI
cheers for the heads up ;)
Has anyone changed the horn setting from UK to Europe ? Does it do anything ??
Posted: Wed Aug 06, 2008 12:32 pm
by alexperkins
Its for when the alarm goes off. I did change mine, but it didnt make much difference!
Posted: Wed Aug 06, 2008 12:43 pm
by owenjt
So for example would this be a good purchase?
Posted: Wed Aug 06, 2008 1:20 pm
by neilGTI
That is the exact one i bought and from the same seller as well.
Posted: Wed Aug 06, 2008 1:42 pm
by ticki
i want VAG com. How much?
Posted: Wed Aug 06, 2008 2:20 pm
by pip_polo
ticki wrote:i want VAG com. How much?
that link to ebay is about £18 inc delivery.
does anyone know if the 6N2 cable is the same as for the 9N as me and alex are unsure and for him to do stuff to my car i might need a new cable.. :?
