@ RHYS
Posted: Mon Nov 17, 2008 7:38 pm
where did u get ur interior from?
Probably the Worlds greatest Polo resource
https://uk-polos.net/
15s are 45sTim_GTi wrote:Think Rhys ment 195/45 here!BIG RHYS wrote:
plus if you go for 195/40 the speedo will not be wrong....
its the rear archliners at fault there a ridiculous shape! do what i did take the liner out heat it up with a heat gun from argos for peasnuts! and then flaten it between two pieces of wood problem solved mine never rubbed down 35mm with 5 lads in on 195 45 16's and i never had rubbing issues down 60mm with 5 in on 195 40 16'salexperkins wrote:The answer is yes. Mine burned through arch liners!Tim_GTi wrote:At standard height with a full car, you may get rubbing with 45s yeh. I couldnt be sure though.
If you haven't got them already, there's nothing stopping you buying 40s! Websites may advertise the wheels with just 45, but jsut phone them up and ask specifically for 195/40s, if they're funny about it they're not worth the hassle.
That's a hell of an idea, to take the lip off the edge of it du mean yeh?stani540 wrote: its the rear archliners at fault there a ridiculous shape! do what i did take the liner out heat it up with a heat gun from argos for peasnuts! and then flaten it between two pieces of wood problem solved mine never rubbed down 35mm with 5 lads in on 195 45 16's and i never had rubbing issues down 60mm with 5 in on 195 40 16's
get the back wheels of and you will se what i mean
